GTX 660 TI 3GB SuperClocked Fan Power
Levi Rutherford
2018/06/14 22:52:29 (permalink)
How much power does the fan use on the card? The bottom of it doesn't have a sticker, but I assume it uses 12 volts. Not a clue how many milliamps it uses. I'm considering aftermarket coolers and I want to keep it at or under so it doesn't damage the card.
2 Replies Related Threads
    bob16314
    • Ribbons : 761
    Re: GTX 660 TI 3GB SuperClocked Fan Power 2018/06/14 23:33:52 (permalink)
    It seems to have a DELTA BFB0712HF 65mm, 12V, 1.8A fan.
    I don't know what the maximum amp rating is for the fan control circuit is.
    Re: GTX 660 TI 3GB SuperClocked Fan Power 2018/06/15 12:52:16 (permalink)
    Since it comes with a 1.8a fan the limit would most likely be 2 amps. To confirm contact evga support... https://www.evga.com/about/contactus/
