alexymik
Sunday, November 25, 2018 12:28 AM
I recently put together a system with a GTX 1060 SSC. When I power on the computer, the white EVGA logo lights up and then fades off after a second. Once the system is booted up, all LED options are grayed out in EVGA Precision XOC and the Nvidia LED Visualizer doesn't do anything. Any way to get it to stay on?
post edited by alexymik - Tuesday, November 27, 2018 5:42 PM
alexymik
Re: GTX 1060 SSC White LED Does Not Illuminate/Stay On
Tuesday, November 27, 2018 5:32 PM
- Ribbons : 135
Tuesday, November 27, 2018 6:08 PM
alexymik Bump
alexymik I recently put together a system with a GTX 1060 SSC. When I power on the computer, the white EVGA logo lights up and then fades off after a second. Once the system is booted up, all LED options are grayed out in EVGA Precision XOC and the Nvidia LED Visualizer doesn't do anything. Any way to get it to stay on?
What driver do you have installed?
alexymik
Tuesday, November 27, 2018 6:27 PM
HeavyHemi What driver do you have installed?
It is whatever the GeForce Experience suggests is the latest driver. It has been updated twice since I assembled the computer. I would have to get back to you for the specific driver version. However there was still no change in the LED Visualizer after each update and I cannot find a way to control the lights directly in the GeForce experience.
alexymik
Tuesday, November 27, 2018 11:33 PM
It's driver version 417.01.
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
Tuesday, November 27, 2018 11:39 PM
Led visualizer isn’t letting you control the led?
Precision XOC is looking for an RGB controller, but doesn’t directly do white led for some reason.
alexymik
Tuesday, November 27, 2018 11:43 PM
The LED Visualizer looks like it should work, it detects the card. However nothing I do lights the card up.
Wednesday, November 28, 2018 1:09 AM
Have you inspected the cards pcb to make sure all the fan/led cables are fully seated to the power headers on the card?
alexymik
Wednesday, November 28, 2018 1:50 AM
Sajin Have you inspected the cards pcb to make sure all the fan/led cables are fully seated to the power headers on the card?
Yes, I did pull the card back out and inspected what I believe is the two-pin power connector for the LED. I poked at the connector and it does seem firmly seated. So far I've only seen it light up for one second on cold boot, so I wonder if the setting is stored on the card's BIOS somehow? Possible a firmware/BIOS update might help?
Wednesday, November 28, 2018 2:03 AM
I don't see a vbios update helping your issue.
alexymik
Wednesday, November 28, 2018 3:04 PM
Sajin I don't see a vbios update helping your issue.
Any idea what would, then?
Wednesday, November 28, 2018 6:18 PM
You could try powering the cooler leds from a header on your motherboard.
alexymik
Wednesday, November 28, 2018 6:47 PM
Sajin You could try powering the cooler leds from a header on your motherboard.
Does the LED board have a voltage/current regulator? Don't want to hook up 12v direct to the LEDs and blow them out, then they really won't light up! Looks like a regular JST connector so I could probably rig something up if the PCB isn't providing power.
Wednesday, November 28, 2018 6:55 PM
gamernut78
Wednesday, November 28, 2018 8:32 PM
I thought you cannot change the LED on the 1060 6GB card? Are you able to download a software for that and change that? I thought you need a 1070 and up for this LED change? Am I wrong?
Please help me earn some bucks to save money in the future as a team player and gamer! My Rewards Program Code: 6JD2JTSGVP
alexymik
Wednesday, November 28, 2018 8:34 PM
gamernut78 I thought you cannot change the LED on the 1060 6GB card? Are you able to download a software for that and change that? I thought you need a 1070 and up for this LED change? Am I wrong?
There are no RGB lights which is likely why it's greyed out in XOC but there should be a white LED that illuminates the EVGA logo. https://www.evga.com/products/specs/gpu.aspx?pn=9682ad92-958f-48d6-abd4-d605dbbef656
And it does come on but only for a split second when first starting the system.
