AnsweredFix for appearance/thermal led tabs being blacked out
virmire88
Re: Appearance LED Block out Sunday, July 01, 2018 8:31 PM (permalink)
@ virmire88
Completely shutdown your pc, unplug psu cable from wall socket, hold case power on button for 30 seconds, plug psu cable back into wall socket, start pc, start precision. See if that fixes your issue with the power & memory temps not showing.
Hey Sajin, just tried what you suggested. The power temp and memory temp are still blanked out.
#31
Re: Appearance LED Block out Sunday, July 01, 2018 8:34 PM (permalink)
In that case try this...
1) Uninstall precision xoc.
2) Delete the evga folder located in c:\program files (x86)
3) Reboot PC.
4) Install the latest version of xoc.
#32
virmire88
Re: Appearance LED Block out Sunday, July 01, 2018 9:16 PM (permalink)
3) Reboot PC.
Hey Sajin, tried the above, no joy here either.
I've even tried a clean install of windows. Then installed latest version of XOC (6.2.7).  Still no Power Temp or Memory Temp.
Still can't use LED Sync or Sensor... greyed out.
#33
virmire88
Re: Appearance LED Block out Sunday, July 01, 2018 9:35 PM (permalink)
Hi everyone,
Just to let you know I've fixed my issue.
I reinstalled the latest graphics drivers through GeForce Experience. Everything is back like a charm now on XOC.
Hope this helps others with this issue in the future
#34
Re: Appearance LED Block out Sunday, July 01, 2018 9:44 PM (permalink)
#35
virmire88
Re: Appearance LED Block out Sunday, July 01, 2018 10:38 PM (permalink) ☄ Helpfulby Cool GTX Tuesday, July 24, 2018 6:26 PM
Just as a final update to this problem. I located the software that was causing the issue, it was the Origin client. I reinstalled origin and the tabs and LED settings greyed out. They reappeared if I uninstalled the client... weird. But hey, worth flagging for future versions of XOC.
#36
  • Ribbons : 123
Re: Appearance LED Block out Tuesday, July 24, 2018 5:52 PM (permalink)
virmire88
Good Catch thank you for sharing
BR awarded
#37
  • Ribbons : 115
Re: Appearance LED Block out Sunday, July 29, 2018 6:49 AM (permalink)
virmire88
Thanks for the info. Should help others experiencing the same issue.
            My Affiliate Code: 8WEQVXMCJL
 &nbsp
#38
Nod_Guitar_Dude
Re: Appearance LED Block out Friday, March 08, 2019 8:12 PM (permalink)
Still getting nowhere with this :/ .... I don't have Origin installed either.... I suspect it could be some other 'client' application/process
I do have Uplay though?
#39
  • Ribbons : 123
Re: Appearance LED Block out Friday, March 08, 2019 8:43 PM (permalink)
Nod_Guitar_Dude
What are your Card Temps ?
What are your LED set points ?
#40
Cordorb
Re: Appearance LED Block out Wednesday, January 01, 2020 4:01 AM (permalink)
for GTX 1080 FTW2 and 1080 Ti   - I have had better luck using  XOC 6.1.16
BUT some of my system also have a mix of EVGA CLC and EVGA case or all three.
When using a ALL glass case - I had to set all LEDS ( fans-GTX cards and CLC cooling to RED only )
I almost put a red film on the outside of the glass on a Corsair case  build :-)
#41
Paddy32
Re: Appearance LED Block out Sunday, August 09, 2020 6:10 PM (permalink)
I'm in the same situation as you. I just installed the card on a brand new build with an ryzen 7 3700x. I can't click on "appearance LED". I tried with EVGA Precision XOC and EVGA Precision X1. I need help !
My GPU is  EVGA GTX 1070 Ti SC GAMING ACX 3.0. Here's a photo :
MB : MSI X570 TOMAHAWK WIFI CPU : Amd Ryzen 9 5900X CPU Cooler : Noctua NH-D15
GPU : EVGA RTX 3080 FTW3 (Undervolt : 1905MHz 875mV)
PSU : Seasonic Focus 850W Platinum RAM : 16Gox2 3200Mhz
Pictures of my build
#42
  • Ribbons : 123
Re: Appearance LED Block out Sunday, August 09, 2020 8:08 PM (permalink)
Paddy32
 I see you started your Own thread for this issue:  https://forums.evga.com/FindPost/3068962
--> Best organize the members answers --> in Your Thread
All members Replies to this issue should be in your thread - link above
#43
