cronustr75
Evga Z370 FTW bios 08, Evga CLC 28 aio not reading cpu temp? All drivers are installed. Cable is connected to the CPU1_FAN, set to MAX at bios. Flow control software not reading cpu temp, all other tools are working and readin???? Flow control v2.10... Only reading cooler temp. Attached the pic.
cronustr75
Re: Evga Z370 FTW bios 08, Evga CLC 28 aio Flow Control not reading cpu temp?
2018/11/22 04:45:51
cronustr75
2018/11/26 11:20:15
Az3D
post edited by AMDSY3D - 2020/07/15 13:34:02
2018/12/02 11:35:06
I'm using ver 2.0.8 Please Confirm the FAQ listed requirements "No PWM on header" & use header marked Pump if MB has one FAQ ID # 59704 (excerpt, underline added for clarity) If you are receiving an error message when trying to install EVGA Flow Control or have disconnecting issues while using the software please try the following steps: We recommend connecting the CLC fan header to the CPU1 or CPU2 header on your motherboard. Make sure the fan header setting in BIOS is set to MAX or 100%. Do not use a PWM fan curve for the header you connect the CLC to. If your motherboard has a fan header designated for a "Pump" you should connect the CLC fan header to this specific location. If you continue to have this issue or have a related problem without a solution, please contact EVGA support Thank you
2018/12/02 11:49:41
Double click on the Graph "Coolant Temp" & "Pump Speed" - the CLC interface Does a box open with more hardware being monitored ? What is at the top of the List on left & Right column ?
Az3D
post edited by AMDSY3D - 2020/07/15 13:34:17
2018/12/02 11:52:08
Have you saved to a profile ?
Az3D
post edited by AMDSY3D - 2020/07/15 13:34:43
Az3D
post edited by AMDSY3D - 2020/07/15 13:34:50
2018/12/02 12:09:26
Kind of basic - just covering all bases You downloaded the Correct OS 7/8-8.1 /10 and 32 or 64 bit --> there are 6 different files During install - All background software was Off ? (even Security software - go off line first) Installed as Admin ? in an Admin account / log On ?
Az3D
post edited by AMDSY3D - 2020/07/15 13:34:56
2018/12/02 12:13:56
Your MB including BIOS ver, CPU and OS details
Az3D
post edited by AMDSY3D - 2020/07/15 13:35:03
Az3D
post edited by AMDSY3D - 2020/07/15 13:35:10
