JackCrackerMan
This is strange... I was gaming and noticed that my core freq dropped for a second. Looking at monitoring software, it appears the power limit hit 122% and the "Power limit" showed a value of '1' (IE: hit the built in power limit). The thing that's strange is I've got it cranked up to 150% power limit, but it still maxed at 120? It's the GTX 1080ti K|NGP|N Hydro Copper... as you can see temps are well in operating temperatures as well so no thermal throttling should have occurred. I'm running the Extreme Liquid cooling OC Bios on the LN2 switch as well.
MOBO: Asrock x370 Taichi || CPU: Ryzen 1800x || RAM: G.SKILL 32GB DDR4 3200 (14 CAS) || Graphics: EVGA 1080Ti Hydro Copper K|NGP|N || PSU: Corsair HX1000 || Storage: WD M.2 512GB SSD, 2 x 500GB Samsung EVO, 1 x 4TB WD HDD
Re: Even with Power limit at 150%, GPU shows power limit hits at 120%
2018/08/09 14:43:32
a 150% power limit is not happening on a stock 10 series card -- that would require harware modification - as far as I've seen Moving to OC section
JackCrackerMan
2018/08/09 16:00:33
Cool GTX a 150% power limit is not happening on a stock 10 series card -- that would require harware modification - as far as I've seen Moving to OC section
there's no hardware modification outside of a BIOS that enables (or so it says) a 150% power limit. Again, it's the K|NGP|N... so it's built for extreme OC without any hardware mods.
2018/08/09 16:32:06
2018/08/09 23:52:40
That is going to happen from time to time. It's normal. Don't worry about it. One little spike isn't anything to worry about.
JackCrackerMan
2018/08/10 00:10:54
Sajin That is going to happen from time to time. It's normal. Don't worry about it. One little spike isn't anything to worry about.
Thanks, just caught me by surprise. It was in Civ 6 of all things.
2018/08/10 10:22:46
JackCrackerMan
2018/08/10 11:18:45
I guess I'm still wondering why it hit power limit at 120% even though it's set to 150%?
2018/08/10 11:28:56
JackCrackerMan
2018/08/10 11:50:58
I see, thank you for the explanation!
2018/08/10 13:38:07
Danteazazel
2018/09/16 01:08:26
If your power limiting your need to reduce your over clock, i made a youtube video for this exact thing so people can watch how to overclock, heres the link - https://youtu.be/opq3dvXfJMU
- Ribbons : 270
2018/09/16 11:21:26
It's a feature. That's what you get for your $1000. 'It's just a glitch. Don't worry about it.' If it were me, I would be unsatisfied with the glitch or needing to lower my overclock in order to avoid hitting a limit which shouldn't be triggering.
2018/09/16 12:34:46
Danteazazel If your power limiting your need to reduce your over clock, i made a youtube video for this exact thing so people can watch how to overclock, heres the link - https://youtu.be/opq3dvXfJMU
Nah, the op just needs to flash the xoc vbios to his card to disable power & temp limits.
- Ribbons : 270
2018/09/16 22:22:12
Thanks ASUS!
2018/09/17 01:06:21
Thanks ASUS!
The xoc vbios I'm talking about isn't from asus.
