EVGA hybrid 2080ti kit question. And repasting 2080Ti XC Ultra.
STR8_AN94BALLER
2019/03/21 21:07:53 (permalink)
Can i just remove the XC Ultra cooler and put on the AIO alone? Without the heatsink and shroud?
Thanks in advance for the answer.
Also, did anyone repaste on stock cooler of XC Ultra and see any temp improvement?
Thanks.
4 Replies Related Threads
    Re: EVGA hybrid 2080ti kit question. And repasting 2080Ti XC Ultra. 2019/03/21 21:44:06 (permalink)
    Wouldn't recommend it. Why would you want to do that?
    STR8_AN94BALLER
    Re: EVGA hybrid 2080ti kit question. And repasting 2080Ti XC Ultra. 2019/03/22 13:23:30 (permalink)
    But is it possible to install the AIO alone without the accompanying heatsink and shroud? Because it's so much easier that way and doesn't require full disassembly.
    I have a good airflow setup that can cool the VRM/VRAM no trouble.
    Re: EVGA hybrid 2080ti kit question. And repasting 2080Ti XC Ultra. 2019/03/22 13:26:18 (permalink)
    STR8_AN94BALLER
    Yep.
    STR8_AN94BALLER
    Re: EVGA hybrid 2080ti kit question. And repasting 2080Ti XC Ultra. 2019/03/22 15:47:30 (permalink)
    STR8_AN94BALLER
    Yep.
    Ok thanks Sajin.
    I'll go ahead and get the AIO cooler from a retailer. Any you suggest that don't charge tax?
