Hey all,
I've noticed since I recently picked up my 1000w g1+ power supply, there's a unfamiliar sound that will occasionally happen. It doesn't always coincide with when I'm doing something intensive with my machine either, could be while browsing the web (no videos, etc.).
Typically when the sound happens, it does seem like the fan in the power supply kicks on, or at least runs a bit faster than it did before but only briefly.
It's not the typical tick noise or clicking I've seen posted about. It's almost like an electronic noise when an old computer would turn on. I can only describe it as an electronic revving up or turning on, lasts about 5 seconds and goes away. It happens so irregularly I don't think I'd ever be able to capture a video of it either. I've spent a while trying to find anyone else mentioning if this is normal behavior or not.
I'm not overly concerned about it but would like to get some insight if this is at all normal or known as typical behavior.
Thanks in advance for any tips.
