boobatchka
I just put my got my new rig running with an EVGA GeForce RTX 2080 Ti XC ULTRA GAMING in there.
I can't control the RGB using Precision X OC 6.2.7. When I click on "LED Sync" and chose a new setting, the card doesn't change at all. The only thing I can think of that might be wrong is if Precision X OC is in conflict with my Gigabyte motherboard, with RGB Fusion.
But I'm not even talking about getting the graphics card to actually sync with the Gigabyte. I'm just talking about Led Sync itself does nothing. The card stays a static green no matter what settings I put in Led Sync.
I'm going to be disappointed if I have to return this card for such a reason, but I'll do it if I can't fix it :(.
Re: EVGA RTX 2080Ti: Led Sync doesn't work at all
2018/10/01 20:19:50
boobatchka
2018/10/01 20:25:52
2018/10/01 22:31:26
bfkrogermoore
2018/10/02 22:37:18
Fixed my derping also. Thanks!
xtaylor1
2018/10/09 11:06:33
2018/10/09 11:07:23
xtaylor1
2018/10/09 11:09:41
you guys should fix precision x oc 6.2.7 because its junk
Tech_RayH
- Ribbons : 7
2018/10/09 12:22:33
PX1 should supercede that software (with a GTX supported version release in the future), PX1 should address any issues that you are having with PXOC. But that said, if you outline any issues you are having Precision XOC, we may be able to resolve those now
...an untrammeled flow of words in an open forum. - Adlai E. Stevenson
daywalker33309
2018/10/23 19:08:40
I installed X1 on EVGA RTX 2080, as soon as i finished the installation the LEDs shut off and never turn back ON. Also i notice on the program unter the LED tap There is no color selection. Even after selection static On: I only can see the Brightness bar. Pressed Apply and nothing happens. Before installing Software LEd was on, With Green color. PLease need help with this problem. I never thought a $800 GPU with have RGB software problems.
astorvick
2018/10/23 19:45:51
daywalker33309 I installed X1 on EVGA RTX 2080, as soon as i finished the installation the LEDs shut off and never turn back ON. Also i notice on the program unter the LED tap There is no color selection. Even after selection static On: I only can see the Brightness bar. Pressed Apply and nothing happens. Before installing Software LEd was on, With Green color. PLease need help with this problem. I never thought a $800 GPU with have RGB software problems.
Have you updated the LED firmware ? https://forums.evga.com/Precision-X1-and-EVGA-RTX-2080-LED-issue-m2871726.aspx
i7-6950X- All cores 4Ghz Rampage V Edition 10 Corsair Dominator Platinum 3000Mhz 64GB Samsung NVMe 950 Pro 512GB, EVOs-Raid 0 1TB EVGA Geforce RTX 2080 XC Ultra (SLI) EVGA SuperNOVA 1000 P2
daywalker33309
2018/10/24 04:05:05
I have installed new firmware and LEDs are working fine ,Thank you. But i still cannot select colors on software. I have X1 V.0.3.3.0.
2018/10/24 11:37:41
daywalker33309 I have installed new firmware and LEDs are working fine ,Thank you. But i still cannot select colors on software. I have X1 V.0.3.3.0.
Reinstall the program.
HugoVictoria
2020/04/10 04:37:36
Is there any MCU update for RTX2080ti Black??? My Led´s are not chaging at all, PX1 doesn´t even has LED option and LED Sync is not deteting hw card... It has work for a few days only... Try to uninstall, clean all registry, install again and still not working..
ASUS z490 E-Gaming Strx, 32GB Gskill RGB 3600MHZ, RTX 2080 Ti Black EK Watercooled, i7 10700K 5.2GHZ, PSU Corsair RM850i v2, nVME Intel 1TB + nVME Sabrent 2TB, Full EK WaterCooled Rigid Tube..
2020/04/10 11:37:05
HugoVictoria Is there any MCU update for RTX2080ti Black??? My Led´s are not chaging at all, PX1 doesn´t even has LED option and LED Sync is not deteting hw card... It has work for a few days only... Try to uninstall, clean all registry, install again and still not working..
You should contact evga support... https://www.evga.com/about/contactus/
BolbiBoi
2021/02/08 16:27:07
Did you ever figure out this issue? I have an RTX2080Super and the LED option has disappeared from Precision X1 and I've tried a lot of troubleshooting without any success.
