EVGA Cable Kit 8PIN EPS connector - doesn't split - can I put it in a 4 pin EPS?
Clausewitz
2021/07/21 18:27:29 (permalink)
I have two EPS connectors on my motherboard one 8 pin and one 4 pin. I own an EVGA Cable Kit which doesn't allow me to split the cable headers on the CPU cables - they are both 8 pin. Can I plug one 8 pin into the 4 pin with the remaining 4 pins hanging off or is this not advised?
4 Replies Related Threads
    Re: EVGA Cable Kit 8PIN EPS connector - doesn't split - can I put it in a 4 pin EPS? 2021/07/21 18:39:55 (permalink)
    Play it safe, and don't use it if you're not sure. Never tried it myself, so I don't know. Contact evga tech support and ask if it's ok. You sure you don't have the cable plugged in backwards? An eps is suppose to split into 4+4 at one end of the cable while the solid 8-pin plugs into the psu output.
    bob16314
    • Ribbons : 761
    Re: EVGA Cable Kit 8PIN EPS connector - doesn't split - can I put it in a 4 pin EPS? 2021/07/22 02:27:53 (permalink)
    Clausewitz
    Yeah..You can plug an 8-pin CPU power connector from your PSU into a mobo 4-pin CPU power socket and leave the other 4-pin part hanging out, if there's room to do that and nothing obstructs the 8-pin from being plugged in..It will fit and work fine..The positive/negative power and ground pinout is the same..Only 1/2 of the 8-pin connector will be keyed to fit properly in a 4-pin CPU power socket..Been there, done that..Not an issue.
    EVGATech_JaesonW
    EVGA Tech Support
    Re: EVGA Cable Kit 8PIN EPS connector - doesn't split - can I put it in a 4 pin EPS? 2021/07/22 06:50:03 (permalink)
    Like bob16314 said, plugging in half the 8 pin connector should be just fine if it will physically do so on your motherboard. Also check your manual, usually you only need the extra 4 pin if you're overclocking or using certain top end CPUs, you might not even need it.
    EVGA Customer Service Manager
    Have a moment? Please rate our service
    Clausewitz
    Re: EVGA Cable Kit 8PIN EPS connector - doesn't split - can I put it in a 4 pin EPS? 2021/07/22 08:16:45 (permalink)
    EVGATech_JaesonW
    It's an ASUS Z590-E STRIX and it does say you can use either the single 8 pin or both. It doesn't specify the reasons why but many people have stated it's for extreme overclocking - like you said.
    I did some searching and buildzoid stated the second 4-pin is pointless because a single 8pin EPS is rated for 480w?
    Here is the video - I started it at that point: https://youtu.be/SPQZUayYbBM?t=290
    It seems strange that they would include the extra connectors. I understand it might be for LN2 but if you're going to use LN2 I doubt you'd purchase that board.
    Further, some people have said the second connector adds stability but I'm not sure how. Any further input would be appreciated.
