Intoxicus
Flagged as Spam (1)
I've seen too many people reporting dead 3080s and 3090s where a daisy chain power cable is in use.
In the interest of data collection post here if you use daisy chains and if you've had to RMA your GPU for any reason. Or post if you don't use them and had issues, use them and had no issues, etc. If you've ever had an issue using a daisy chain on any other GPU throw it in here also because why not. The focus is on 3080 and 3090 though.
The idea is to get a decent sample to see if there is a correlation worth looking into deeper. Maybe it is an issue, maybe not. We won't know for sure until we start looking into it though.
I'll start with myself:
3080 FTW3 Ultra, now on Hybrid Kit since Tues(12/29) and GPU itself installed on 11/13/2020. No daisy chain used, no issues. (I'm using only one plug of a daisy chain for the third connection because the PSU doesn't come with 3 single cables, that's fine though. The 2nd connection not in use doesn't do anything except be annoying for cable management.) I am OC'ed on on the 450W XOC bios now, I stayed on stock bios until I installed the hybrid kit.
Although on my previous 2070 non super I used a daisy chain when I first got it. I had not OC'ed yet either(I did later, I always run at stock for at least a week, sometimes more, to make sure it works properly before I apply any OC). I had issues with instability and crashes until I stopped using a daisy chain. The PSU is the same 1000W EVGA Supernova Gold G3 I'm using now. Also it should be noted the crashes and instability came over time, it was not immediate. And it all stopped immediately when I stopped using a daisy chain.
"Humans are not rational animals, humans are rationalizing animals." -Robert A Heinlein
Intoxicus
Re: Do you use daisy chain power cables? Did your GPU die or have issues?
2020/12/31 08:15:53
https://imgur.com/a/fzK6iGv edit by Cool GTX - fixed photo - (use copy image location - when using a host site & place in the Insert/Edit image tool) Thanks, it's not obvious or intuitive how to find that.
post edited by Intoxicus - 2020/12/31 09:02:07
transdogmifier
- Ribbons : 17
2020/12/31 08:17:18
Nope...It's a bad idea, really I always use two separate cables.
- Ribbons : 84
2020/12/31 08:24:41
I've used two separate cables for my RTX 3090 FTW3 Ultra. I also recently upgraded my Corsair PSU from 850 watts to 1000 watts.
flg2010
2020/12/31 08:44:18
I have 3 separate PCIE cables, full replacements certified for my PSU. I use a Phantek 1200 Watt Revolt-X PSU. 3090 FTW3 Ultra
---Main Rig Build ---CPU: AMD Ryzen 9 5950X, CPU Cooler: NZXT X73 360, GPU: EVGA 3090 FTW3 Ultra, MB: ASUS CH VIII Formula, RAM: 64GB G.Skill Trident RGB 3600, Storage: 2TB Adata M.2, 2TB WD SSD, 500GB WD SSD, Case: Thermaltake ARGB View51
Kyrlen
2020/12/31 09:05:51
You can daisy chain lower power devices like fans and some hard drives if you're careful. NEVER daisy chain any card requiring an additional power connector beyond the slot it sits in. Basically, if you have even the slightest doubt, don't do it. Wait for the cables or new power supply to come in. It's not worth the damage to your component.
blaise
- Ribbons : 5
2020/12/31 09:14:06
Three separate PCIe power cables - Corsair AXI 1200W using CableMod Pro ModMesh C-Series cables (PSU set to Single Rail OCP) 3090 FTW Ultra using the standard OC BIOS - no issues
- Ribbons : 270
2020/12/31 09:30:38
Yet another one of these threads?
ex90ranger
2020/12/31 09:32:17
2 factory cables, one daisy chained, to my 3080 FTW3 Ultra
Main system Intel 6850k / Asus Rampage Extreme V Edition 10 / 32g 3200 Corsair Dominator RGB / EVGA RTX 3080 FTW3 Ultra / Samsung 950 pro NVME 500g / Samsung 850 Evo 1t / Samsung 850 Evo 1t https://pcpartpicker.com/b/J4CLrH Media system AMD 3400g / Asus Strix B450-i / 16g 3600 Corsair Dominator RGB / Samsung 970 Evo 500g / Samsung 850 Evo 500g https://pcpartpicker.com/b/vyf9TW Both systems installed in Phantex Enthoo 719 Dual system case powered by Phantex Revolt X 1200 dual system PSU
transdogmifier
- Ribbons : 17
2020/12/31 09:33:37
ty_ger07 Yet another one of these threads?
Ad nauseum until the end of times.....people don't search (myself included)
Intoxicus
2020/12/31 09:36:29
Yes, until we have a definitive answer. If using daisy chains is causing issues it would add value to get correct information out there. If I'm wrong and proven wrong with facts and evidence I'll stfu.
transdogmifier
- Ribbons : 17
2020/12/31 09:47:01
Intoxicus
It's pretty simple...the cables aren't rated to carry the power the inputs request/are spec'd for. You daisy chain it and exceed the power the cable is designed to carry, you got problems. Don't.....Do....It.
Intoxicus
2020/12/31 10:33:18
transdogmifier
Intoxicus
Agreed. EVGA Jacob is telling people it's safe and it's confusing the issue.
jankerson
2020/12/31 11:07:02
Intoxicus
transdogmifier
Intoxicus
Agreed.
Well most of the issue, well all of the issue really is that NVIDIA came out with that 750W PSU spec. But the Founders Edition only takes 2X 8 Pin PCIe connections to their 12 Pin adaptor. So looks like the rest just followed NVIDIA with the 750W recommendation. And most of that is related to marketing, selling the cards, would be hard for them to tell people to get a 850W PSU. 750W was already bad enough with all those morons out there from day one telling people 750W was too much. And that was before the cards even released and any actual testing was done. Now to the issue: Almost no 750W PSUs have separate 3x 8 Pin PCIe connections from the PSU. So that would mean a real min of 850W PSU for the 3x 8 Pin cards, not 750W PSU. NOW, will using 2x 8 Pin PCIe cables work for the 3x 8 Pin connections, with one daisy chain? Yes, it will work, not the best solution by any means however.
i9 9900K @ 5.0 GHz, NH D15, 32 GB GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q, Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W. i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W. i7 8700K, AORUS Z370 Ultra Gaming, 16GB 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
EVGATech_AdamB
2021/01/06 10:05:22
Unlocked by me. Moderators - please do not lock again.
Like our service? Please provide feedback for us at the link HERE.
- Ribbons : 270
2021/01/06 10:18:39
RickJamesBish
2021/01/06 11:08:09
The poll I did, while not definitive, shows more cards that were wired with dedicated cables to each block died vs those daisy chained.
mx353
2021/01/06 11:40:40
rz22g The poll I did, while not definitive, shows more cards that were wired with dedicated cables to each block died vs those daisy chained.
You think people are gonna admit that they daisy changed a GPU?
RickJamesBish
2021/01/06 12:04:40
mx353
Yes there are people in the poll that stated they daisy chained. Its anonymous so its not like EVGA is going to look at their username and say they voided their warranty.... using the split cable we provided you with our EVGA power supply ;) And I will admit it. My 2080TI has been since release.
post edited by rz22g - 2021/01/06 12:09:08
badboy64
2021/01/06 12:23:43
I never will do it with my eVga 3090 FTW3 Ultra and never did it with my eVga 2080Ti FTW3 Ultra either. Just way too risky.
post edited by badboy64 - 2021/01/06 12:26:27
14th Intel® Core™ i9 14900KF CPU 3.2GHz@6.0ghz, Memory 2x24GB GSkill Trident Z Trident Z5 7200 mhz DDR5 Ram,4,000 GB MSI M480 PRO 4TB , Motherboard eVga 690 Dark , Operating System Windows 11 Pro 64-Bit, Msi Suprim X24G 4090, Monitor Acer CG437K, Logitech G910, Razer Lancehead Tournament Edition, Thermaltake View 91 RGB plus, eVga 1600w P2 PSU, Custom watercooling. Speed Way Score 11,055 points. https://www.3dmark.com/sw/1112818
Intoxicus
2021/01/06 13:10:25
mx353
Why not? Most people that use them refuse to accept any possibility they could be bad idea so I doubt they will find anything negative about posting here. If anything people will want to prove me wrong by showing me their daisy chain works. It doesn't void the warranty so there is nothing for anyone to worry about that way. If anything we might have reported user bias in that people that do have issues will not want to post to avoid an "I told you so." I'm not judging anyone for what they post here. This is purely information gathering.
Intoxicus
2021/01/06 13:13:42
- Ribbons : 270
2021/01/06 13:18:07
Intoxicus (probably because of you reporting it.)
Because of me reporting it? What? That's a baseless accusation. Anyway, this other thread has a lot more interesting discussion going on, so please let one of them die. Choose one or the other.
Intoxicus
Flagged as Spam (1)
2021/01/06 14:44:48
You are not a moderator. If you want to be a mod apply/volunteer.
SinisterGamer
2021/01/06 18:58:00
Intoxicus
transdogmifier
Intoxicus
Agreed.
This is why. and I will be honest, when I was building mine and looked at the daisy chain cables evga puts in the box. ANywho, I switched mine out yesterday but i've been running a 3090 for over a month with no issues.
TitusTroy
2021/02/13 11:28:32
Intoxicus EVGA Jacob is telling people it's safe and it's confusing the issue
this is also the part that is confusing to me...EVGATech_PeterN is telling people to not daisy chain and use 3 separate cables while EVGA_JacobF is saying it's OK (in the case of a 3 8-pin connection) to daisy chain 1 and use 1 other separate cable is there a definitive answer to this...I recently bought an EVGA 3080 FTW3 Ultra...I also have a Corsair RM850x PSU (comes with 4 daisy chained PCIe 8-pin connectors)
post edited by TitusTroy - 2021/02/13 11:47:59
Dwarfy
- Ribbons : 5
2021/02/13 12:46:27
If the cable cannot carry the power it would not damage the card in any way other than physical due to cables overheating. Once the physical limit of the cables current capacity is reached it would burn out like a very slow fuse, on a modular psu that burn out damage is just as likely at the psu connector as it is at the gpu connector. Insufficient power would likely mean unstable system and complete system crashes (the gpu isn't the only draw on the 12v line)
enkrypt3d
2021/02/13 14:27:33
I dont think ANYONE is daisy chaining power cables. I've had 2 dead 3090's and they both had separate power cables directly from the PSU. This thread is dumb.
AMD 5950X CPU Corsair H150i 360mm AIO EVGA 3090 FTW3 Ultra MSI X570 Prestige Creation 32GB DDR4-3600Mhz G.skill Neo Trident 4 x 2TB Samsung EVO 970 Plus in RAID0 EVGA SuperNova 1300W G2 PSU
kraade
- Ribbons : 7
2021/02/13 17:48:10
I did on my 3080 FTW3 Ultra out of necessity until I got a new power supply, it worked with 1 &3 chained, I think it would be fine if you are not running the most taxing games like MSFS2020 or when running and Undervolt profile to be safe; Ampere architecture is amazing, I have an 850 MV profile that can Port Royal 11442 and only draw 267 Watts
RickJamesBish
2021/02/13 19:29:26
There are at least two threads where it is stated by an EVGA Tech that it is acceptable to daisy chain if the cable was included by the manufacturer of the PSU. This has been beaten into the ground and sprouted back up so many times and not one incident of it being a problem has been presented.
