It will be a few weeks before i can make any significant changes while i wait for some custom stuff to arrive but i will continue to improve while i wait -
I have placed an order for the following items -
I ordered a XSPC 120mm rad a few weeks ago and never used it so because of that i have an extra Corsair SP120mm fan left over. I am going to put it to good use by going with a XSPC 480 rad in place of my current XSPC multiport 360 rad.
XSPC EX480 Copper Quad-Fan Radiator
I currently have a Swifttech radbox supporting my rear 360 rad/3 fans and although i like the looks of it i desire something with more flexibility and strength.
As you can see here the radbox bolts to the top section of the 360 rad -
With the Koolance rad bracket i can bolt it to the 2cd section of the rad to even out the weight load. I will raise the rad up in the process but i will be using 2 45 degree rotary fittings to fix that issue.
Koolance Radiator Mounting Bracket with Quick-Release
I currently have 1 MCP655/D5 bolted to a Koolance RP-452X2 dual bay res. I want close to total silence with this build but unfortunately i am getting some vibration noise with the pump on setting 2 or higher. I recently lowered the pump speed setting to 1 and although i hear no vibration now my temps have suffered up 2 10c under certain loads. I will be purchasing an additional Swifttech D5 pump so i can run them both at speed 1 and hopefully solve this issue.
Swiftech MCP655 Series 12 VDC Water Pump - With Speed Control
These leds will be used to light both individual Koolance bay res chambers -
Mod/Smart Dual LED 3mm - Green with black sleeving.
Since this build is now being themed after the ninja turtles "secret of the ooze" movie,i will be using Mayhems Pastel Mint Green which is the closest match to this -
Mayhems Pastel Mint Green Concentrate -
