Hi,
I've got an EVGA 1070 (no factory OC). It has quite headroom for OC as it can sustain ingame +250 on the core / +400 on the Ram. I didn't wanted to go too far on the OC so I settled at plus 200 / 400 making it run stable ingame at 2050 with peaks at 2088. However the cards runs hotter and I struggle to find the good fan curve for it not making too much noise.
With no overclock I used to set the fans at 60% for 60° and 100% for 70° which made the GPU run at 62° max in most scenarios. I believe core clock don't boost as much past 63° so it was a good setup.
With OC the temps will raise over 60° too often and the GPU makes too much noise. I tried to lower the fan curve and obviously I get higher temps but the core clock don't seem to throttle.
I have some airflow in the case but it's not great.
So I have a few questions:
- what temperature would you let the GPU run in such an OC config?
- what fan curve would you apply?
- at what temperature do the GPU really stop boosting at max / throttle?
- knowing that I got a GPU with no thermals pads (issue with first batches), is my OC safe?
Thank's for any answer.
