007vsMagua
I'm currently building using the EVGA RTX 2060 Super SC and it has one 8-pin power connector. The only PCIe 8-pin cable that came with my Seasonic PSU modular only shows 6-pin's to be active. Is this the correct cable to use?
"Life is like stepping onto a boat which is about to sail out to Sea and sink." _Shunryu Suzuki Roshi EVGA __ RTX 3070 FTW Super --- INTEL __ i7-7700K MSI __ Z270 Gaming M7 --- GSKILL __ 16GB TridentZ 3200NZXT __ Kraken X62 / HUE+ / GRID+ v2 / AER Fans x2 / USB HubSAMSUNG __ 850 EVO 500GB --- WD __ 1TB Black / 1TB Blue EVGA __ 850 G3 --- NZXT __ S340 Elite (White) - [/siz
altonadavid
Re: 8-Pin Power Connector?
2019/11/25 11:26:13
Your power supply should have 6 pin PCIe or 8 pin PCIe or a 6+2 pin PCIe cable I would think, which power supply do you have?
altonadavid
2019/11/25 11:30:33
Most seasonic will be an 8 pin that plugs into the powers supply and the other end should be the 6, 8, or 6+2 pin PCIe connections. They should be labeled.
007vsMagua
2019/11/25 11:36:43
altonadavid Your power supply should have 6 pin PCIe or 8 pin PCIe or a 6+2 pin PCIe cable I would think, which power supply do you have?
I'm using the Seasonic Focus GX-550 80 Plus Gold
- Ribbons : 123
2019/11/25 11:38:21
007vsMagua
2019/11/25 11:43:48
altonadavid Most seasonic will be an 8 pin that plugs into the powers supply and the other end should be the 6, 8, or 6+2 pin PCIe connections. They should be labeled.
My cable is 6+2 and all the ends that go into the card have metal connectors, but the 8-pin end that gets plugged into the PSU only shows 6 pins with metal connectors.
altonadavid
2019/11/25 12:09:00
According to the specs and photos it shows it has 2 PCIe connection cables included, both are 8 pin for the power supply side and 6+2 pin for the video card end. Are you saying all the wires are individual metal ends instead of being in a single plug?
007vsMagua
2019/11/25 13:56:47
altonadavid According to the specs and photos it shows it has 2 PCIe connection cables included, both are 8 pin for the power supply side and 6+2 pin for the video card end. Are you saying all the wires are individual metal ends instead of being in a single plug?
If you look into the ends my PCIe power cord, the end that goes into the GPU has two parts and all 8 ports show a metal connection. The end of the 8-pin power cord that gets plugged into the PSU only shows 6 ports with a metal connection. The cord is labeled PCI-E RG33. I guess my question is_ Do all eight power connections on my card need power? Or does it only need six?
- Ribbons : 123
2019/11/25 14:09:38
PSU Mfg .... Custom wire Their power cords.... so that the PSU (which is Not standardized) ... can be Safely Joined to the Device end - (Whis Is Standardized)
EVGA_Lee
Moderator
- Ribbons : 14
2019/11/25 14:49:46
007vsMagua
According to the spec sheet posted above, you should have two 6+2 PCIe connectors on a single cable. You would plug in one of those 6+2 connectors, and the other one would not be connected to anything.
altonadavid
2019/11/25 15:03:25
007vsMagua
The end with 6+2 you just put them together and then all 8 plug into the video card. Then the other end plugs into the powers supply port marked PCIe
007vsMagua
2019/11/25 15:06:45
Cool GTX PSU Mfg .... Custom wire Their power cords.... so that the PSU (which is Not standardized) ... can be Safely Joined to the Device end - (Whis Is Standardized)
EVGATech_LeeM
According to the spec sheet posted above, you should have two 6+2 PCIe connectors on a single cable. You would plug in one of those 6+2 connectors, and the other one would not be connected to anything. Do all 8 contacts on this card require power?
flyinion
- Ribbons : 9
2019/11/25 15:06:59
I think you're ok. I was initially confused as well about this when I got my full length custom cables for my Seasonic Prime series. After looking up the pinouts it made sense. Only 3 lines are actually power on the connector. The rest are grounds. On the GPU end Seasonic is splitting one wire into 2 pins on the grounds in two spots. Just means for whatever reason they were able to meet the needed spec without connecting up all 8 pins on the PSU end of things. Edit: So if you look closely at both ends of the cable you should see either on the GPU end that 1-2 wires are split into two pins or on the PSU end that 1-2 pins that are split into 2 wires. edit 2: So if I'm remembering the PCIE pinout correctly, 6 pin is actually 2 power 4 ground, and 8 pin adds one extra line of each for 3 & 5. edit 3: Actually those extra +2 pins are just ground. Weird, but yeah.
post edited by flyinion - 2019/11/25 15:15:16
AMD Ryzen 5950X | Asus Crosshair VIII Hero | Gigabyte Gaming OC 4090 w/EK Vector2 | GSkill Trident Z Neo 2x16GB DDR4-3600 | WD SN850 2TB | Samsung 970 EVO Plus 500GB & 860 Evo 2TB | Phanteks Enthoo 719 | Seasonic Prime Ultra Gold 1000W | Steelseries M750 TKL | SteelSeries Prime Wireless | SteelSeries Arctis Pro + GameDAC | Kanto YU2 + Yamaha sub | Schiit Magni 2 Uber & Modi 2 Uber | LG 34GN850 | Asus PG279Q | Win 11 Pro | Custom water loop
Hoggle
2019/11/25 15:28:39
The 2060 Super SC has 8 pins on the card and the cable from the PSU should have 8 pins also. Normally it's the 6+2 that is most common cable but sometimes cables will just be an 8 pin. The card would expect to have the 8 pins of power to run properly.
007vsMagua
2019/11/25 15:52:55
flyinion I think you're ok. I was initially confused as well about this when I got my full length custom cables for my Seasonic Prime series. After looking up the pinouts it made sense. Only 3 lines are actually power on the connector. The rest are grounds. On the GPU end Seasonic is splitting one wire into 2 pins on the grounds in two spots. Just means for whatever reason they were able to meet the needed spec without connecting up all 8 pins on the PSU end of things. Edit: So if you look closely at both ends of the cable you should see either on the GPU end that 1-2 wires are split into two pins or on the PSU end that 1-2 pins that are split into 2 wires. edit 2: So if I'm remembering the PCIE pinout correctly, 6 pin is actually 2 power 4 ground, and 8 pin adds one extra line of each for 3 & 5. edit 3: Actually those extra +2 pins are just ground. Weird, but yeah.
Yeah, it does seem weird. It does seem the six plug side has 3 hot wires and 3 ground connections. I assume the card only needs 3 hot wires.
flyinion
- Ribbons : 9
2019/11/25 16:24:35
007vsMagua
I did a bit more looking. Apparently what really happens is in the 8 pin config the GPU end moves the ground from one of the original locations in the 6 pin to the two extra pin section and then re-purposes that original location in the 6 pin area and the last remaining of the +2 section as "sense" wires so that it can tell whether an 8 or 6 pin connector is installed and change its power mode appropriately.
007vsMagua
2019/11/25 17:16:32
flyinion
007vsMagua
Thanks man, happy Thanksgiving
GTXJackBauer
- Ribbons : 48
2019/11/26 00:48:39
Don't worry too much since the cables have different shapes so you can't input the cable in the wrong way.
flyinion
- Ribbons : 9
2019/11/26 10:02:58
GTXJackBauer Don't worry too much since the cables have different shapes so you can't input the cable in the wrong way.
He was concerned about that fact that the seasonic cables don't have wires in all the connector pins on the PSU side. I had noticed the same thing a couple months ago when I swapped out my stock PSU cables for some cablemods custom ones and was initially worried that they hadn't put wires to all the pins and some were Y'd off of one. That was when I found those pinouts etc. and realized it wasn't an issue.
007vsMagua
2019/11/26 11:51:36
flyinion
When I built my desktop two years ago I used custom cables, so I still have leftover cables from the EVGA 850 G3. They look better than the Seasonic cables and I'm going to swap them out. The EVGA PCIe VGA G3 cable does show all connector pins on the PSU side have wires. I assume all PSU's are designed the same?
davevt31
- Ribbons : 7
2019/11/26 12:07:05
No, all PSU's are not the same. Don't mix cables from different manufacturers.
bdary
- Ribbons : 118
2019/11/26 12:11:33
davevt31 No, all PSU's are not the same. Don't mix cables from different manufacturers.
+1. Even different PSU's from the same Mfg'r can be pinned different. Never a good idea to swap cables...
007vsMagua
2019/11/26 12:23:10
bdary
OK, Thanks. Both my EVGA and Seasonic PSU's are modular and I would have thought the cables would be universal.
flyinion
- Ribbons : 9
2019/11/26 13:46:51
007vsMagua OK, Thanks. Both my EVGA and Seasonic PSU's are modular and I would have thought the cables would be universal.
Definitely not. It's only universal on the component connection side. That's why when you get full replacement cables you need to select them by what brand and model PSU that you have.
007vsMagua
2019/11/26 15:48:18
flyinion
Alrighty Then, I do remember when I ordered my custom cables they were for the 850 G3. I'll let sleeping dogs lay and not use different cables.
