Hello, I just purchased a 650 G5 Supernova PSU after my computer randomly shut off without warning and would not turn back on. I replaced my old 450BT PSU with this one as I thought the PSU was the issue. However, I am still hearing the same faint beeping coming from the PSU every 5 seconds, and now I see that the light on the back is flashing at the same time as the beep. Normally a light on my motherboard would turn on even if the computer was off but the PSU was on, but that light is no longer turning on. My questions are, A, what do the beeping and the flashing light mean on the PSU, B, is this a power supply problem or a motherboard problem, and C, is there a way to fix this problem without having to take advantage of the warranty or replace the motherboard or PSU.
My Build:
4TB Hard Drive, not sure of the make
MSI B350M PRO-VDH motherboard
650 G5 Supernova Power Supply
2x4GB Ballistix RAM
2x16GB Corsair Vengeance RAM
ASUS DUAL GTX 1060 O3G
Not Sure what model specifically, but an AMD Ryzen 5 CPU
Thanks a ton!
