gsrcrxsi
- Ribbons : 5
Wednesday, July 14, 2021 9:30 PM
I think all XC3 will have this problem, and since it’s not a temperature problem, nothing about the HC would help the situation. I can understand why the HC isn’t being treated any differently. The limiting factor has nothing to do with it being a watercooled card. The HC card is basically identical to any other XC3 card, just with a waterblock and some different capacitors to make the waterblock fit better.
talon951
Wednesday, July 14, 2021 9:31 PM
Based on the tests you guys posted, it really does appear the pcie slot may be set to a 66w limit. They may have done that when they went to an 8 amp fuse on the pcie. That's only 96w. So if they had the more typical 75-80w limit, it would be cutting it close.
It's possible my FTW3 is 66w too, but it never goes over 60w even with the max power limit set.
gsrcrxsi, it might be worthwhile to measure the real power draw on the 8 pins with a clamp meter like I did with my FTW3. All of those tests you posted with varying max power draw look very similar to how my card behaves (except its in the 400-450w range). But when I've measured the true power draw (and added in the indicated pcie wattage) I show the card is actually running much closer or even higher than the power limit.
KingEngineRevUp mentioned this before I think. I'm still skeptical you'll get the same result but it's possible. Clamp meters aren't very expensive.
gsrcrxsi
- Ribbons : 5
Wednesday, July 14, 2021 9:33 PM
My power cables aren’t separable between power and ground, so I can’t clamp them anyway. It’s a Corsair HX1000i with flat/bonded VGA cables
post edited by gsrcrxsi - Wednesday, July 14, 2021 9:35 PM
talon951
Wednesday, July 14, 2021 9:38 PM
gsrcrxsi My power cables aren’t separable between power and ground, so I can’t clamp them anyway.
Just use some cheap extensions that are separate with looms.
kram36
The Destroyer
- Ribbons : 72
Wednesday, July 14, 2021 9:54 PM
gsrcrxsi I think all XC3 will have this problem, and since it’s not a temperature problem, nothing about the HC would help the situation. I can understand why the HC isn’t being treated any differently. The limiting factor has nothing to do with it being a watercooled card. The HC card is basically identical to any other XC3 card, just with a waterblock and some different capacitors to make the waterblock fit better.
IMO, EVGA sold me, you and everyone a crap card. I'm not going to let them do it again on another 3080 Ti XC3 card they sent an email to purchase on today and I'll warn other not to buy this card.
gsrcrxsi
- Ribbons : 5
Wednesday, July 14, 2021 10:01 PM
kram36
unfortunately this behavior isnt going to encourage EVGA to do anything, they know they will sell the cards anyway. it really needs broader exposure from someone with a platform that can reach thousands or millions of people.
kram36
The Destroyer
- Ribbons : 72
Wednesday, July 14, 2021 10:02 PM
gsrcrxsi
kram36
I'm exposing EVGA right now on the XC3 cards. https://forums.evga.com/FindPost/3427753 https://forums.evga.com/FindPost/3427752 https://forums.evga.com/FindPost/3427751 https://forums.evga.com/FindPost/3427763
post edited by kram36 - Wednesday, July 14, 2021 10:12 PM
Aruzedragon
Oh damn, three mega threads
kram36
The Destroyer
- Ribbons : 72
Wednesday, July 14, 2021 10:13 PM
Aruzedragon Oh damn, three mega threads
Just added the 3080 XC3 HC cards too, but will still track the 3080 FTW3 HC cards.
Cats4Life
Wednesday, July 14, 2021 10:17 PM
kram36
gsrcrxsi
kram36 So why would EVGA limit a Hydro Copper card?
They aren’t limiting the HC more than the others from what I’ve seen. Some do better than others it seems. Nothing singling out the HC card to hold them back specifically. Just that all 3080Ti XC3 cards seem to be held back.
I like my HC card still. It fits my case, I didnt have to worry about sourcing a waterblock for my custom loop, and in the loads I’m doing, the performance is OK and still better than a 3080.
That's what I'm saying, a Hydro Copper should not be limited like this for any of the XC3 card. FTW3 cards are blowing XC3 Hydro Copper cards out of the water and they should not be doing that. We are talkin 12% better for a FTW3 card at a min. I got a GTX 1050 card here that requires no pcie power plugs, gets all it's power from the pcie slot. I'll run a test to see what this card pulls from the pcie slot.
That’s a good idea, please let us know how it goes.
Aruzedragon
Wednesday, July 14, 2021 10:20 PM
kram36
To be honest, if EVGA just offers some kinda investigation or offers some reason why the cards are being so limited that would have been amazing but still silence on my tickets too.
Cats4Life
Wednesday, July 14, 2021 10:21 PM
We need to try to do something to get evga to help fix this. Create like a petition or something.
post edited by Cats4Life - Wednesday, July 14, 2021 10:31 PM
KaosEvga
Wednesday, July 14, 2021 11:10 PM
This thread has me worrisome for the XC3 Gaming version... But ugh...it's the one i am closest to...
12G-P5-3953-KR 6/30/2021 6:30:26 AM PT Yes 12G-P5-3967-KR 6/3/2021 7:58:06 AM PT Yes 08G-P5-3797-KL 6/10/2021 6:09:10 AM PT Yes 08G-P5-3783-KL 6/30/2021 6:31:20 AM PT No
kram36
The Destroyer
- Ribbons : 72
Wednesday, July 14, 2021 11:13 PM
Cats4Life We need to try to do something to get evga to help fix this. Create like a petition or something.
I've contacted EVGATech_LeeM and pointed him to this thread asking for this issue to be addressed.
post edited by kram36 - Wednesday, July 14, 2021 11:15 PM
Aruzedragon
Wednesday, July 14, 2021 11:20 PM
KaosEvga This thread has me worrisome for the XC3 Gaming version... But ugh...it's the one i am closest to...
If you get it, think of it as a 3080. A underpower GPU is better than no GPU
ashleyblazevic
Wednesday, July 14, 2021 11:32 PM
Has anyone done any gaming benchmarks to check how much the performance is affected?
KaosEvga
Wednesday, July 14, 2021 11:38 PM
Aruzedragon If you get it, think of it as a 3080. A underpower GPU is better than no GPU
I guess that could be the case if i had no GPU. I have a 3080 FE, but wanted an EVGA+3080 TI card. It's already a slim "upgrade" so a slimmed down slim "upgrade" is just rough.
Cats4Life
Wednesday, July 14, 2021 11:39 PM
kram36
That will help hopefully. We might need to get more traction for them to really do anything about it. Hopefully he can help.
Cats4Life
Wednesday, July 14, 2021 11:42 PM
Aruzedragon
That’s true, only problem is that the 3080 ti costs quite a bit more. If we’re paying a premium for the Ti over the regular 3080, we’re kind of expecting more performance.
kram36
The Destroyer
- Ribbons : 72
Thursday, July 15, 2021 0:58 PM
Cats4Life
Aruzedragon
Exactly, you're not getting what you paid for. Plus if EVGA doesn't correct this issue, trying to sell it down the road and people knowing this card performs more like a overclocked 3080 then a 3080 Ti, you are going to be on the short end of the stick money wise there too while the whole time you had the card you never got the true 3080 Ti performance.
gsrcrxsi
- Ribbons : 5
kram36
I don't think it's the first time this thread has been sent to him. EVGA's MO is silence, never admit there's a problem, deny deny deny, etc. he never responded last time, don't think it'll be any different this time.
Cats4Life
Thursday, July 15, 2021 1:26 AM
It’s always either no response or something along the lines of “We don’t guarantee power delivery”. With the performance that we’re getting out of them, they must as well be called 3080s and be $300 cheaper to match the price of a 3080 ftw3. Some people have said that their 3080 ti xc3 falls short compared to a 3080. Someone even said that their 3070 ti ftw3 outperformed their 3080 ti xc3. This is ridiculous. I paid for a 3080 ti, please give me the performance of one.
post edited by Cats4Life - Thursday, July 15, 2021 1:27 AM
kram36
The Destroyer
- Ribbons : 72
Thursday, July 15, 2021 1:41 AM
Well I put my XC3 into Step-Up for a FTW3. Not the card I wanted and I'll be stuck with a used XC3 Hybrid kit.
ChaoticKinesis
Thursday, July 15, 2021 1:50 AM
kram36 Average GPU clock speed for my card on Fire Strike Ultra was only 1,837MHz and that as with a healthy oc on the GPU as you can see it was 2,175MHz. https://www.3dmark.com/fs/25899073 The FTW3 card my nephew got from me beats the piss out of my XC3. Whish I had not sold it to him.  https://www.3dmark.com/fs/25895356
I could be wrong but, looking at that first score with the XC3, I imagine that Intel Core i5-7500T can bottleneck the 3080 Ti graphics performance. I don't know that it would amount to a difference of 10% but it probably is a clear non-zero amount.
12G-P5-3968-KR 6/3/2021 7:42:36 AM PT Yes
kram36
The Destroyer
- Ribbons : 72
Thursday, July 15, 2021 1:56 AM
ChaoticKinesis
It would have an affect on the score yes, but not the GPU clock speeds, if anything the GPU clock speed would be up higher as it's waiting on information from the CPU. My GPU clock speeds are as good....eh er as bad as gsrcrxsi's Hydro Copper.
post edited by kram36 - Thursday, July 15, 2021 2:16 AM
KaosEvga
Thursday, July 15, 2021 2:03 AM
kram36 Well I put my XC3 into Step-Up for a FTW3. Not the card I wanted and I'll be stuck with a used XC3 Hybrid kit.
That might be the play i do xD. does the wheel code and associate code affect the "MSRP" when stepping up?
kram36
The Destroyer
- Ribbons : 72
Thursday, July 15, 2021 2:05 AM
KaosEvga
AFAIK, you can not use any type of discounts on a Step-Up. I could be wrong, but pretty sure.
KaosEvga
Thursday, July 15, 2021 2:08 AM
kram36
KaosEvga
I think i worded it wrong, if i used the elite code+associate code on a xc3 would the "step up" cost be $200 or would the difference be more like $400+ with the discounts?
kram36
The Destroyer
- Ribbons : 72
Thursday, July 15, 2021 2:13 AM
KaosEvga
kram36
KaosEvga That might be the play i do xD. does the wheel code and associate code affect the "MSRP" when stepping up?
You get to claim EVGA Bucks, but I'm not sure about the wheel spin discount and Associate Code usage. I think EVGA considers those a rebate and is excluded.
post edited by kram36 - Thursday, July 15, 2021 2:37 AM
Cats4Life
Thursday, July 15, 2021 3:22 AM
KaosEvga
kram36
KaosEvga
I'm pretty sure that if you use your elite discount + the associate code then it uses that. So, by stepping up to a 3080 ti ftw3 ultra, you'd still have to pay all $1400 and your elite code would basically be negated.
