nirvashone
Can't seem to get control on the leds. They're greyed out in precision. Clean install. USB header isn't wired. Tried with it and it does nothing.
post edited by nirvashone - 2017/09/18 16:39:46
Re: 1080ti kingpin
2017/09/18 14:15:01
Try reseating the card/moving the card to a different pci-e slot.
_Gir_
Re: 1080ti kingpin
2017/09/18 15:35:51
Are you using Precision XOC?
nirvashone
Re: 1080ti kingpin
2017/09/18 16:36:37
Yes, using xoc. The options for LED control are greyed out. As well as the independent fan controls. Everything else lights up fine. The logo the Kingpin on the PCB. The only things that don't work are the three LEDs that tell me the current temperature state of the hardware
post edited by nirvashone - 2017/09/18 16:38:46
nirvashone
Re: 1080ti kingpin
2017/09/18 16:39:26
I also noticed that the sensors button is unclickable as well.
nirvashone
Re: 1080ti kingpin
2017/09/19 16:52:55
Anyone else having an led and sensors issue with their KPE?
_Gir_
Re: 1080ti kingpin
2017/09/19 18:41:05
Any other OC tools running? MSI AB etc? Does XOC say KINGPIN in the middle circle? For the clean install did you use the DDU driver uninstaller? Also completely remove reinstall XOC? Did you try an alternate PCIE slot? Also try changing it to the KPE OC BIOS.
post edited by _Gir_ - 2017/09/19 18:44:04
nirvashone
Re: 1080ti kingpin
2017/09/19 19:01:29
I did a clean install of drivers using the GeForce experience. Xoc was uninstalled, then computer was restarted, then I went and remove the folder manually. In the middle circle of x OC when you right-click where it normally says precision yes it does say Kingpin. I have no clue as to how to change the BIOS. No other overclocking software is running.. didn't put it in another pcie slot though, I don't know why that would make any difference because my 970 FTW Plus was in the same slot that I'm using now and I had no issues with it
post edited by nirvashone - 2017/09/19 19:04:25
nirvashone
Re: 1080ti kingpin
2017/09/19 19:02:29
The name plate on the side and the Kingpin logo on the PCB both light up just fine in white I just can't change the color within x OC
_Gir_
Re: 1080ti kingpin
2017/09/19 20:12:44
☄ Helpfulby nirvashone 2017/09/19 22:44:11
Check to see if your motherboard BIOS and drivers are up to date? KPE OC BIOS- inside the green box on the attached photo is a little 3 position switch. With your computer completely off/depowered- switch it to OC and then simply boot. Changing PCIE slots is just another way to eliminate possible issues. If those don't cut it- recommend following this guide to a "T"
nirvashone
Re: 1080ti kingpin
2017/09/19 22:39:19
I'll try those as soon as I get home. Thanks for your help.
CriticalHit_NL
- Ribbons : 17
Re: 1080ti kingpin
2017/09/20 08:25:58
Sajin Try reseating the card/moving the card to a different pci-e slot.
nirvashone Yes, using xoc. The options for LED control are greyed out. As well as the independent fan controls. Everything else lights up fine. The logo the Kingpin on the PCB. The only things that don't work are the three LEDs that tell me the current temperature state of the hardware
Sajin, did you need to install a firmware update via Precision XOC to get full control over your 1080Ti FTW3 Kingpin? Nirvashone, it could be handy to post a screenshot of the current state of Precision XOC main window, and show what things are greyed out. Since you said independent fan controls are also greyed out I would think that you're missing some firmware patch to get full control over the GPU, something Precision XOC should offer. (but I don't know if this counts for Kingpin, hence why I ask Sajin)
i7 3930K 4.4Ghz - EVGA 1080Ti FTW3 - 32GB Corsair Dominator DDR3-1866 - Asus Sabertooth X79 - Samsung 840 Pro 256GB - Samsung 860 Pro 2TB - 3x HGST 7K4000 Deskstar 4TB - 3x HGST Ultrastar He10 8TB - Corsair AX1200i - Asus PG279Q + BenQ BL2411 - Razer Viper Mini/SBF98 - Logitech Z906 & G35 - Windows 10 Professional
BrandonS
- Ribbons : 5
Re: 1080ti kingpin
2017/09/20 08:34:21
I believe Saijin may have the right idea here. If the problem is related at all to some of the problems I've encountered with the 1080 Ti FTW3, you will need to uninstall the driver, uninstall Precision X and delete the folder in Program Files x86, and then shut down the system. Remove the card and re-insert it, and then turn on the system, re-install the driver and install Precision X. If this doesn't fix the problem, inserting the card in a second system will almost always fix this.
nirvashone
Re: 1080ti kingpin
2017/09/20 08:37:11
I'll be going home here shortly I'll try it then going to uninstall everything with ddu and truly start over from a clean slate.
nirvashone
Re: 1080ti kingpin
2017/09/20 10:41:40
used DDU, Removed XOC, re-seated the card. BAM!!! Thanks guys for all your help.
_Gir_
Re: 1080ti kingpin
2017/09/20 10:46:45
nirvashone used DDU, Removed XOC, re-seated the card. BAM!!! Thanks guys for all your help.
Awesome! Have fun
Re: 1080ti kingpin
2017/09/20 11:36:10
CriticalHit_NL Sajin, did you need to install a firmware update via Precision XOC to get full control over your 1080Ti FTW3 Kingpin?
Nope.
Re: 1080ti kingpin
2017/09/20 11:36:22
DeathAngel74
- Ribbons : 10
Re: 1080ti kingpin
2017/09/20 11:41:17
Glad you got it sorted out!
Carnage specs: Motherboard: ASUS ROG STRIX X299-E GAMING | Processor: Intel® Core™ i7-7820x | Memory Channels#1 and #3: Corsair Vengeance RGB 4x8GB DDR4 DRAM 3200MHz | Memory Channels#2 and #4: Corsair Vengeance LPX Black 4x8GB DDR4 DRAM 3200 MHz | GPU: eVGA 1080 TI FTW3 Hybrid | PhysX: eVGA 1070 SC2 | SSD#1: Samsung 960 EVO 256GB m.2 nVME(Windows/boot) | SSD#2&3: OCZ TRION 150 480GB SATAx2(RAID0-Games) | SSD#4: ADATA Premier SP550 480GB SATA(Storage) | CPU Cooler: Thermaltake Water 3.0 RGB 360mm AIO LCS | Case: Thermaltake X31 RGB | Power Supply: Thermaltake Toughpower DPS G RGB 1000W Titanium | Keyboard: Razer Ornato Chroma | Mouse: Razer DeathAdder Elite Chroma | Mousepad: Razer Firefly Chroma | Operating System#1: Windows 7 SP1 Ultimate X64 | Operating System#2: Linux Mint 18.2 Sonya (3DS Homebrew/Build Environment)
- Ribbons : 115
Re: 1080ti kingpin
2017/09/20 20:12:26
That's great.
