Re: [1080 Ti SC2 Hybrid] How to reduce annoying pump noise at idle without voiding warrant
2018/03/13 22:44:32
So I have a 1080 Ti FTW3 Hybrid. Since day one it has always been silent, even with half of my case fans turned off when temps are low enough. Today I added a fan and moved another fan to a different spot. I was extremely careful with the case and didn't drop or jolt anything on or near the 1080 ti. The settings were unchanged and the radiator fans are set up exactly as they were before I noticed the noise.
With the additional fans, I have a total of thirteen fans in my case, and even with all of them spinning, I still hear the pump hum over the top of all of them, with or without the case side panel shut or open. You can trace the vibration making the noise. I have systematically disabled fans, including the one I just put in, and it is not any of the fans making this noise. My hearing is most definitely NOT just suddenly better than it was yesterday or last week. This is a new hum, and you can straight up feel the vibration when you touch the card. It was NOT doing this before. I am afraid I'm going to have to RMA this card, much to my chagrin. I will give it a little time and wait and see if it's just pump break-in or something. I've had it for about two or three weeks, if memory serves... "Break in" was suggested by the EVGA tech I called. How long does this break in period last for these pumps?
Current Temp Rig: Modded cheapo HP SFF gaming PC with AMD Ryzen 3600 + Arctic Freezer 7X, 32GB Crucial DDR4, 512GB NVMe SSD, incoming EVGA 3060 12GB. 400w HP Platinum PSU, 43" Asus XG438Q Gaming Monitor
