[1080 Ti SC2 Hybrid] How to reduce annoying pump noise at idle without voiding warranty?
gregts
Re: [1080 Ti SC2 Hybrid] How to reduce annoying pump noise at idle without voiding warrant 2018/03/08 05:54:43 (permalink)
OK, just thought of something else to avoid all this (don't know if it's possible though).
Could I flash my card with the Asus 1080ti Strix vbios?
That would allow me to control both my card's fan and pump speed based on the GPU's temp (both are connected to my mobo's fan headers) within AI suite.
ROG STRIX Z270E GAMING  | 7700K | EVGA 1080ti FTW3 Hybrid | 16GB Gskill 3200 | 960 EVO 512GB | 850 PRO 512GB
#31
gregts
Re: [1080 Ti SC2 Hybrid] How to reduce annoying pump noise at idle without voiding warrant 2018/03/09 05:27:17 (permalink)
@HeavyHemi
Got it sorted with the above method.
Flashed my card with the Asus vbios and now the system and specifically Asus AI Suite sees the card as an ASUS STRIX 1080ti.
I can control both the fan speed and the pump speed through it correctly, as it allows me to add the GPU temp as it's source.
Much better this way instead of installing more software to get the job done...
#32
SirKronan
Re: [1080 Ti SC2 Hybrid] How to reduce annoying pump noise at idle without voiding warrant 2018/03/13 22:44:32 (permalink)
So I have a 1080 Ti FTW3 Hybrid. Since day one it has always been silent, even with half of my case fans turned off when temps are low enough. Today I added a fan and moved another fan to a different spot. I was extremely careful with the case and didn't drop or jolt anything on or near the 1080 ti. The settings were unchanged and the radiator fans are set up exactly as they were before I noticed the noise.
With the additional fans, I have a total of thirteen fans in my case, and even with all of them spinning, I still hear the pump hum over the top of all of them, with or without the case side panel shut or open. You can trace the vibration making the noise. I have systematically disabled fans, including the one I just put in, and it is not any of the fans making this noise. My hearing is most definitely NOT just suddenly better than it was yesterday or last week. This is a new hum, and you can straight up feel the vibration when you touch the card. It was NOT doing this before. I am afraid I'm going to have to RMA this card, much to my chagrin. I will give it a little time and wait and see if it's just pump break-in or something. I've had it for about two or three weeks, if memory serves... "Break in" was suggested by the EVGA tech I called. How long does this break in period last for these pumps?
Current Temp Rig: Modded cheapo HP SFF gaming PC with AMD Ryzen 3600 + Arctic Freezer 7X, 32GB Crucial DDR4, 512GB NVMe SSD, incoming EVGA 3060 12GB. 400w HP Platinum PSU, 43" Asus XG438Q Gaming Monitor
#33
bryanwilson437
Re: [1080 Ti SC2 Hybrid] How to reduce annoying pump noise at idle without voiding warrant 2018/03/14 00:36:09 (permalink)
gregts
HeavyHemi You should be able to use AI Suite to control the header you have it plugged into. It's basically the same as running a two wire 12V fan. Most recommend only running it as slow as you need to reduce the noise.
That's what I plan to do when I receive the cable. I am going to route it from the pump to the CPU_OPT header on my motherboard (it's the only free header) and control it through AI Suite.
The only problem with AI Suite is it only allows you to regulate the percentage based on the CPU temps...that's why I asked if someone has found a software that allows you to specify what temps the curves are based on.
AI Suite is great overall but only allows you to read GPU temps off their own cards (asus rog strix)
In AI Suite/Fan Xpert you can change it to dc by selecting the header you want to control and changing it from smart mode to fixed rpm mode.
#34
gregts
Re: [1080 Ti SC2 Hybrid] How to reduce annoying pump noise at idle without voiding warrant 2018/03/14 06:39:41 (permalink)
bryanwilson437
Thanks for the reply Bryan!
I ended up connecting both pumps via a Y splitter pwm cable to my mobo's AIO header and set a custom fan curve.
The solution you propose would mean that I would have to raise the rpm's every time before gaming to keep the card cool.
Can't post pics or links here due to the forum's post limit but up until 45C both pumps operate at 70% and are inaudible.
They only kick in when I game and the CPU goes over 45C (the PC is solely for gaming - I work on a mac).
I found that 45C covers light usage in windows (for my case setup with Silent Wings 3 fans everywhere in a Fractal Meshify C) with me hearing the pumps.
#35
gigah
Re: [1080 Ti SC2 Hybrid] How to reduce annoying pump noise at idle without voiding warrant 2018/03/14 13:48:10 (permalink)
Flashing the card with the Asus BIOS seems handy if it gives you software control over the pump and radiator, but does this affect the warranty?
#36
AHowes
  • Ribbons : 27
Re: [1080 Ti SC2 Hybrid] How to reduce annoying pump noise at idle without voiding warrant 2018/03/14 14:00:01 (permalink)
gigah
As long as it's the slave bios.. don't touch the master bios and your fine.
Asus Z390 ROG Extreme XI MB
#37
gregts
Re: [1080 Ti SC2 Hybrid] How to reduce annoying pump noise at idle without voiding warrant 2018/03/14 14:01:07 (permalink)
I don't do it for the overclocks, the FTW3 is powerful enough, I don't need a tweaked firmware. I actually undervolt the card (0.900) and run it at a lower speed.
I only use it on my slave bios to control the pump and I can reflash it back to the original bios at any time.
#38
gigah
Re: [1080 Ti SC2 Hybrid] How to reduce annoying pump noise at idle without voiding warrant 2018/03/14 14:30:31 (permalink)
Hmm, the 1080Ti SC2 Hybrid only has 1 BIOS chip as far as I can tell. Are you both using the 1080Ti FTW Hybrid?
#39
Re: [1080 Ti SC2 Hybrid] How to reduce annoying pump noise at idle without voiding warrant 2018/03/14 14:52:42 (permalink)
gigah
Yes, it will void the warranty if your card only has 1 vbios chip. You'll need to flash the original back onto the card before rma'ing it if you ever have to send it in for replacement.
#40
