x299 Dark Audio vs Nu Audio
RobsterSF
2019/04/16 20:36:55 (permalink)
Hi all,
Curious if anyone with an x299 Dark upgraded to the Nu Audio card. Better? Same? I'm using the built in sound with just left right and sub for the time being. Curious to hear people's thoughts.
Cheers
Rob Pomon
Intel I7- 7820X, Dual GTX 1080Ti, EVGA x299 Dark, 32 GB Corsair Vengeance, EVGA DG-87 Case, EVGA CLC 280, 1TB Samsung 970 Pro PCIe NVMe, EVGA Super Nova1600 T2+ titanium, P3D v4.4, PMDG 737NGX, 747, 777, Win 10 x64
4 Replies Related Threads
    GGTV-Jon
    • Ribbons : 15
    Re: x299 Dark Audio vs Nu Audio 2019/04/16 21:49:39 (permalink)
    I am using the NU on my X299 Dark. I had just been using the onboard with my headphones and felt the Dark just didn't have enough omph to push them. If you are using powered speakers then volume wise there will be no change, and going with an NU there will be no 2.5 sound as you are using now.
    The NU is geared more for people that tend to use headphones or powered speaker setups that work with SPDIF/TOSlink
    With the Nu installed now I can see where my headphones are lacking when listening to music - has made me have to start shopping for new headphones
    RobsterSF
    Re: x299 Dark Audio vs Nu Audio 2019/04/16 21:51:38 (permalink)
    Hi Jon,
    Thank you for the feedback. I figured that might be the case. Great to hear from someone using the real deal.
    Cheers
    jeffro66
    • Ribbons : 8
    Re: x299 Dark Audio vs Nu Audio 2019/04/17 03:54:49 (permalink)
    I just added a nu to my dark huge difference after I got it dialed in with Sennheiser headphones best sound I've heard in awhile
      case;Evga DG-87,Evga Dark X299,7820X 8 core cpu,4x16 64gig gskill v,Evga clc280 aio cpu cooler,evga gtx1080 TI King Pin,Evga 1200 platinium p2 power supply,SAMSUNG 960 PRO M.2 2TB NVMe,windows10
    RobsterSF
    Re: x299 Dark Audio vs Nu Audio 2019/04/17 11:58:43 (permalink)
    Thank Jeff,
    I primarily use speakers as I use the rig as a Flight Sim. Thanks for the info!
    Rob
