Recently I got a very good deal on HP H240 HBA card + LTO 5 tape drive and I am having issue getting it to work with my current build. Everything works just fine until I plug in the HBA card in PE3. Before the purchase I checked the manual about PCIe lanes distribution and I figured its gonna be plug and play. But obviously that's not the case here.
I installed HBA card on purpose in PE3 because its shares PCIe lanes with PE2 where my GPU is and I am aware and happy with the GPU working with only 8 lanes because I use GPU only for some occasional gaming.
The issue that I am having is that as soon as I plug HBA card in the motherboard in PE3, I lose 3 NVMe SSDs out of 4, and in the BIOS for that slot it shows that is working only with 4 lanes - in other words only 1 NVMe SSD is visible to the Windows. When I take out the HBA card out, all 4 NVMe SSDs in the ASRock Hyper M.2 card are back.
Motherboard: EVGA X299 FTWK
CPU: i7 9800X
GPU: 3060 12GB in PE2
Memory: in total 48GB DDR4 2666
Storage: 256GB NVMe in M.2 Socket 3 Key-M 110mm; 4x2TB Asrock Hyper quad M.2 card in PE5
Audio: EVGA NU Audio in PE6
BIOS is on latest version 1.29.
To save you the time of looking at the manual, here is the PCIe lanes distribution list and where and which device I have plugged in.
PCI-E Lane Distribution (44 Lane SKX CPU’s)
Not used - PE1
x4 (Gen3, x4 lanes from PCH)
EVGA 3060 12GB PE2
x16 (Gen3, x16 lanes from CPU, x8 shared with PE3)
HP H240 HBA card PE3
x16 (Gen3, x8 lanes from CPU, shares 8 of PE2’s 16 lanes)
Not used - PE4
x16 (Gen3, x8 lanes from CPU, shares 8 of PE5’s 16 lanes)
Asrock Hyper quad M.2 card PE5
x16 (Gen3, x16 lanes from CPU, x8 shared with PE4)
EVGA NU Audio sound card PE6
x1 (Gen3, x1 lane from PCH)
Not used/Disabled in BIOS
U.2 1 – Gen3, x4 lanes from CPU (No Shared Lanes)
Transcend TS256GMTE110S M.2 Key-M (110mm)
x4 CPU lanes (No Shared Lanes)
Not used
M.2 Key-M (80mm) – x4 PCH lanes (No Shared Lanes)
Killer Wireless-AC 1550 9260NGWM.2 Key-E (32mm)
x1 PCH lane (No Shared Lanes)
Help me out, just cant understand why its not working.
Thank you.
EVGA X299 FTWK; Intel i7-9800X; EVGA 3060 12GB; Be Quiet DARK ROCK TF2; 48GB GSkill DDR4 2666; ASRock HYPER QUAD M.2 CARD; EVGA NU Audio; EVGA X20 mouse; EVGA SuperNOVA 850 P6;
