fans and oil
Rei1007
Saturday, February 22, 2020 7:22 PM (permalink)
my card is 2080ftw3.sometimes I open precisionx1 it only shows 2 of 3 fans,then i close and open x1 it probably shows me 3 fans.
i found there is some liquid look like oil on the back of the card.I’m sure the liquid not from my cooler
7 Replies Related Threads
    sparetimepc
    • Ribbons : 27
    Re: fans and oil Saturday, February 22, 2020 7:34 PM (permalink)
    More then likely just oil residue from thermal pads bleeding, its normal and harmless. It can be wiped off with a rag and rubbing alcohol/fingernail polish remover.
    • Ribbons : 135
    Re: fans and oil Saturday, February 22, 2020 7:45 PM (permalink)
    Rei1007
    The oil is likely seepage from the thermal pads. Unfortunately a common thing on EVGA GPUs. They really should be more proactive in what supplier they use. DO NOT USE FINGERNAIL POLISH or ACETONE on your GPU. 90% or higher IPA or alcohol is fine. Could you elaborate on the fan issue? Are all the fans working properly and just when opening Precision they don't all show or are you having actual fan issues.
    Rei1007
    Re: fans and oil Saturday, February 22, 2020 7:46 PM (permalink)
    Do you have any idea about the fans
    Rei1007
    Re: fans and oil Saturday, February 22, 2020 7:55 PM (permalink)
    All the fans work well by the temperature.but I can not control the fan not show in px1. Restart px1 can resolve it always.
    Rei1007
    Re: fans and oil Saturday, February 22, 2020 7:57 PM (permalink)
    • Ribbons : 135
    Re: fans and oil Saturday, February 22, 2020 8:03 PM (permalink)
    Rei1007
    This seems to be an ongoing issue with Precision. Are you using Precision at boot? Or just using it intermittently to monitor the GPU?
    https://forums.evga.com/2...ision-X1-m2914824.aspx
    Rei1007
    Re: fans and oil Saturday, February 22, 2020 8:07 PM (permalink)
    intermittently
