I'll go into a little more detail on what I tried before finally deciding to grab a new video card to replace the 2080. I built my system about 1.5 yrs ago and it was running superbly until about 3 weeks ago when all those
nvlddmkm started showing up.
1. used DDU to remove drivers and install new ones --
no luck2. used DDU to remove drivers and install older drivers that folks had luck with --
no luck3. made sure no overclock was happening, made sure nothing was overheating --
no luck4. decided to re-install windows 10 (home edition) --
no luck5. at this time I also upgraded to windows 10 pro --
no luck6. has an old gtx970 lying around - put that in and has zero issues while running that card --
SUCCESS7. figured it might be power related since I know my PSU was about 7 yrs old so I bought a new PSU 850w and installed that --
no luck8. said to hell with it and bought an Intel I5 10600k and mobo and put the 2080 in that system and it still produced those errors --
no luck9. took the 2080 and swapped that in my daughter's system and within 30m of doing that started seeing all those
nvlddmkm errors --
no luck10. at this time I went to my local microcenter and luckily they had a bunch of 3070's and 3090's in-stock even though their website said they were out of stock
and installed that. I've been now running for close to 24 hrs without an issue. --
SUCCESS11. I took the back plate off my 2080 cuz I noticed a darker spot than others on the back of the card - it looked almost wet and it was dark around a lot of the chips on the back of the card. I don't know what happened but my 2080 ended up in the trash bin.
12. also forgot to mention I tried other things with power options in windows 10 (high performance, etc) and that all failed --
no luck
As you can tell I essentially built and entire new system (only thing I didn't replace was the memory and hard drives) and it all came down to a faulty/bad GPU.
Not sure this helps you or not but thought I should go into detail on everything I tried to get this working.
thanks,
Grimmel
post edited by grimmel95 - 2021/02/04 07:09:58
