be quiet! Announces Pure Loop All-in-One Liquid CPU Cooling Solution
  • Ribbons : 85
2020/09/22 05:42:56 (permalink)
https://www.techpowerup.com/272428/be-quiet-announces-pure-loop-all-in-one-liquid-cpu-cooling-solution
be quiet!, market leader for PC power supplies in Germany since 2007, is introducing a brand-new product line of all-in-one water cooling solutions. Pure Loop is the water cooling unit of choice for all price-conscious users that seek high performance and silent operation. Features like a doubly decoupled pump, noise-optimized Pure Wings 2 fans, an easy-to-access refill port and flexible sleeved tubes make the Pure Loop silent, reliable and versatile, while the white LED illumination on the cooling block and the black design set high standards in appearance. To match individual cooling requirements, Pure Loop will be available with four different radiator sizes: 120 mm, 240 mm, 280 mm, and 360 mm.
Pure Loop water cooling units have a doubly decoupled pump to reduce the transfer of vibrations. By being mounted on the tubes, the pump case is decoupled from the CPU cooling block and radiator. On top of that, rubber pads inside the housing of the pump unit add an additional layer of decoupling. Additionally, be quiet! includes up to three Pure Wings 2 fans, which feature nine airflow-optimized fan blades for a perfect airflow and a low noise level. A nickel-coated cold-plate ensures efficient cooling performance for all mainstream desktop processors and allows the use of liquid metal thermal compound.
The highly flexible sleeved tubes allow for a convenient installation even in cases with restricted space and increase the lifespan of the Pure Loop by preventing tube fractures, even over time. As a testament to the reliability of the new water cooler series be quiet! has implemented an easy-to-access refill port on the radiator, so the cooling liquid can be topped up every two years or when required, for maximum performance over a long lifespan. A 100 ml bottle of coolant is included in the retail box and should last for at least six top-ups.
Thanks to a convenient mounting system, Pure Loop supports all current desktop processors from Intel and AMD, with the exception of AMD Threadripper (Socket TR4/sTRX4). Pure Loop will be available in four different sizes with model recommendations based on the intended platform usage:
  • Pure Loop 120 mm Intel Core i3, AMD Ryzen 3 (or lower)
  • Pure Loop 240 mm Intel Core i5, AMD Ryzen 5
  • Pure Loop 280 mm Intel Core i5/i7, AMD Ryzen 5/7
  • Pure Loop 360 mm Intel Core i7/i9, AMD Ryzen 7/9
Pure Loop will be available for purchase from October 6 at a suggested retail price of $84.90/£82.99/€84.90 (120 mm), $94.90/£92.99/€94.90 (240 mm), $104.90/£102.99/€104.90 (280 mm) and $119.90/£114.99/€119.90 (360 mm).
I think the prices are reasonable provided the warranty is equally good.
7 Replies Related Threads
    aka_STEVE_b
    EGC Admin
    • Ribbons : 69
    Re: be quiet! Announces Pure Loop All-in-One Liquid CPU Cooling Solution 2020/09/22 05:55:49 (permalink)
    Wonder how good the control software is for them..?
    AMD RYZEN 9 5900X  12-core cpu~ ASUS ROG Crosshair VIII Dark Hero ~ EVGA RTX 3080 Ti FTW3~ G.SKILL Trident Z NEO 32GB DDR4-3600 ~ Phanteks Eclipse P400s red case ~ EVGA SuperNOVA 1000 G+ PSU ~ Intel 660p M.2 drive~ Crucial MX300 275 GB SSD ~WD 2TB SSD ~CORSAIR H115i RGB Pro XT 280mm cooler ~ CORSAIR Dark Core RGB Pro mouse ~ CORSAIR K68 Mech keyboard ~ HGST 4TB Hd.~ AOC AGON 32" monitor 1440p @ 144Hz ~ Win 10 x64
    Nereus
    Captain Goodvibes
    • Ribbons : 58
    Re: be quiet! Announces Pure Loop All-in-One Liquid CPU Cooling Solution 2020/09/22 13:39:29 (permalink)
    Interesting. They make extremely good fans, so I expect these AiO units would be high quality. Nice touch adding the fill port and the in-line pump near the radiator. Software not mentioned - it may just be a pump that runs 100% 24/7 and plug the fans into your motherboard and use in-built BIOS fan controls for them, which is exactly how I run my EVGA AiO CPU cooler.
    post edited by Nereus - 2020/09/22 13:41:49
      BUILD 1 2   |   MINI-ITX BUILD   |   MODSRIGS $1K WIN   |   HEATWARE 111-0-0   |   ASSOCIATE CODE CSKKXUT5Q9GVAFR
    GTXJackBauer
    • Ribbons : 48
    Re: be quiet! Announces Pure Loop All-in-One Liquid CPU Cooling Solution 2020/09/23 06:07:33 (permalink)
    Everytime I see 'Be Quiet' products, this song comes to mind.  Better yet, this should be their themed song.
    LMD3DNZM9LGK8GJ
    Nereus
    Captain Goodvibes
    • Ribbons : 58
    Re: be quiet! Announces Pure Loop All-in-One Liquid CPU Cooling Solution 2020/09/23 06:30:26 (permalink)
        totally
    loyalty4life
    Re: be quiet! Announces Pure Loop All-in-One Liquid CPU Cooling Solution 2020/09/24 21:00:50 (permalink)
    I like the look.
    Yesterdays_news
    Re: be quiet! Announces Pure Loop All-in-One Liquid CPU Cooling Solution 2020/09/26 21:12:59 (permalink)
    looks slick
    ccoyne83
    Re: be quiet! Announces Pure Loop All-in-One Liquid CPU Cooling Solution 2020/09/27 22:17:07 (permalink)
    Does have a good simple look. People who hate RGB should like them
