Will PX1 ARGB header work with an ARGB hub connected?
DigitalBoy0101
2020/02/16 13:47:46 (permalink)
Hello all,
I have an upcoming build that I'm trying to nail down the details of ahead of time. Last time I built a PC (2014), LED was a thing, but even plain RGB wasn't :p Needless to say, I have learning to do.
I plan to build in Lian Li PC-O11 Dynamic XL with ALL the fan locations populated. That's a lot (10). GPU will be 08G-P4-3377KR 2070 Super FTW+ with the faster VRAM.
I'd actually rather use PX1's ARGB control (if it works) rather than ASUS AURA, simply so there's 1 less application to install and worry about. I'd be looking at 10 fan locations, CPU AIO block, and of course the GPU for 12 total Devices.
I believe I can make it all work using powered hubs.....but will the PX1 SOFTWARE handle it? And by handle, I mean reliably, with all Devices accounted for. If not, I can of course use AURA, I'd just rather not if I don't have to.
I don't currently even have a system I can check PX1 on, hence all my questions which might seem rather obvious.
Thanks for any answers!
3 Replies Related Threads
    DigitalBoy0101
    Re: Will PX1 ARGB header work with an ARGB hub connected? 2020/02/19 02:20:02 (permalink)
    Aww, noone knows if the ARGB header on the side of RTX cards will work with PX1?
    Along the same lines, I'd like to wire the bottom 3 Intake fans of my case to the card's PWM header so they're synced with the GPU's fans. The other 7 fans I'd sync with CPU.
    post edited by DigitalBoy0101 - 2020/02/19 02:26:03
    • Ribbons : 84
    Re: Will PX1 ARGB header work with an ARGB hub connected? 2020/02/19 03:09:33 (permalink)
    I think you'll need to contact EVGA tech support to answer this.
    • Ribbons : 122
    Re: Will PX1 ARGB header work with an ARGB hub connected? 2020/02/19 11:27:47 (permalink)
    PX1 does not control other hardware - just the GPU
    You'll need to get aRGB Controller/ hub or MB with the feature
