Looks like the 20 series cards don't include this feature anymore. Why was it removed?
post edited by Sajin - 2018/09/04 13:48:45
kram36
The Destroyer
- Ribbons : 72
Re: Thermal display system
2018/09/04 13:42:49
What thermals are you talking about? EVGA's 20 series iCX2 cards will have the extra thermals like they do on the 10 series iCX cards according to the picture of the new Precision X1.
2018/09/04 13:44:56
kram36
The Destroyer
- Ribbons : 72
2018/09/04 13:51:10
Dunno, maybe EVGA didn't think people where finding that feature useful. Was this feature also on the GTX 1080 Ti FTW3 cards?
6dracing
2018/09/04 13:51:24
I really liked the look of the 10 series cards. Those LEDs were something i loved.
2018/09/04 13:52:12
kram36 Was this feature also on the GTX 1080 Ti FTW3 cards?
Yep.
2018/09/04 13:52:45
6dracing I really liked the look of the 10 series cards. Those LEDs were something i loved.
+1
fearpoint
2018/09/04 14:12:32
Maybe they changed it to an overlay display? I use the feature too, but if they made an overlay that appeared when preset temp settings trigger it would essentially be the same thing and actually more useful.
kram36
The Destroyer
- Ribbons : 72
2018/09/04 14:19:28
Yep.
Ah, I see them on the GTX 1080 Ti FTW3 iCX card. How do you know for sure the RTX 2080 TI iCX2 cards will not have them?
2018/09/04 14:29:01
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
2018/09/04 14:35:53
They don’t mention rgb in that video either, but it looks like an rgb or 4 pin fan header on the end of the pcb near the power plugs. Since those were mock up/early boards, I would say a lot will change before they are released.
Last gen, evga said the 1080ti sc2 would only have white leds aside from the three temp leds and it came with rgb after a couple of weeks, so I wouldn’t put off the fact that it may have them on the production model.
2018/09/04 14:43:02
the_Scarlet_one They don’t mention rgb in that video either, but it looks like an rgb or 4 pin fan header on the end of the pcb near the power plugs. Since those were mock up/early boards, I would say a lot will change before they are released.
Guess we will see.
GTXJackBauer
- Ribbons : 48
2018/09/06 14:26:00
Worst comes to worse, pick a sensor and run your RGBs off of it.
2018/09/07 18:57:05
No thermal leds...
ilukeberry
2018/09/08 18:47:02
wow this is one ugly cooler :/
Intel i9 13900KS | EVGA Z790 Classified | Corsair Vengeance 4x16GB 6600MHz | NVIDIA RTX 3080 Ti FE | Corsair MP600 PRO 2TB | PHANTEKS Glacier One 360 T30 Gen2 AIO | Seasonic PRIME TX-850 | PHANTEKS Enthoo Evolv X
