NVIDIA Claims 16-Pin Power Connector Issues are Over, No More Melting
  • Ribbons : 86
2025/01/22 03:10:13 (permalink)
https://www.techpowerup.com/331432/nvidia-claims-16-pin-power-connector-issues-are-over-no-more-melting
During a recent press event in South Korea, NVIDIA addressed concerns about power connector safety for their upcoming RTX 5090 graphics card. The new GPU will consume 575 watts of power, marking a massive 225-watt increase from its predecessor, the RTX 4090. The previous generation RTX 4090 faced significant issues with melting 12VHPWR power connectors, especially with third-party adapters, where incomplete connections led to overheating and connector damage. When questioned about potential risks with the RTX 5090's higher power draw, NVIDIA representatives stated they've implemented an updated 12V-2×6 power connector across the RTX 50 series. Unlike the 12VHPWR 16-pin connector, the new 12V-2x6 has sense pins having recessed further back to ensure proper contact before the GPU can request higher power outputs.
"It is expected that such issues will not occur with the RTX 50 series," a company representative explained during the Q&A session. "After about two years, we believe these problems have been resolved." While the company maintains that user error was the leading cause of failures, the extended timeframe required for developing and shipping revised connectors raised questions about the initial design's reliability. Despite NVIDIA's assurances, the RTX 5090's exceptional power requirements could potentially amplify any unexpected technical issues. The company's previous experience showed that problems became more pronounced in cards with higher power demands, as demonstrated by the RTX 4090 having more incidents than the lower-powered RTX 4080 series. So, more power means more trouble, but the company has worked on it to ensure no future problems arise.
Hopefully this issue is put to rest
4 Replies Related Threads
    donta1979
    Primarch
    • Ribbons : 73
    Re: NVIDIA Claims 16-Pin Power Connector Issues are Over, No More Melting 2025/01/23 08:45:43 (permalink)
    Been on my 4090 shortly after launch and a lot of the time I am over 600w... If a 4090 owner was mindful didn't use an adapter, did not touch the 90-180 degree adapters, didn't bend the 12vhpwr Cable in the wrong spot and made sure all cables at the psu and at the card were fully seated they had nothing to worry about.
    Heatware
    Retired from AAA Game Industry
    Jeep Wranglers, English Bulldog Rescue
    USAF, USANG, US ARMY Combat Veteran
    My Build
    14900k, z790 Apex Encore, EK Nucleus Direct Die, T-Force EXTREEM 8000mhz cl38 2x24 Stable"24hr Karhu" XMP, Rog Strix OC RTX 4090, Rog Hyperion GR701 Case, Rog Thor II 1200w, Rog Centra True Wireless Speednova, 35" Rog Swift PG35VQ + Acer EI342CKR Pbmiippx 34", EK Link FPT 140mm D-RGB Fans. Rog Claymore II, Rog Harpe Ace Aimlabs Edition, Cyberpunk 2077 Xbox One Controller, WD Black SN850x/Samsung 980+990 PRO/Samsung 980. Honeywell PTM7950 pad on CPU+GPU
    • Ribbons : 271
    Re: NVIDIA Claims 16-Pin Power Connector Issues are Over, No More Melting 2025/01/26 07:57:01 (permalink)
    donta1979
    In other words, it is an inferior design. Engineering controls are supposed to make it so the users don't have to follow a recipe for success. The previous solution was better and more robust.
    transdogmifier
    • Ribbons : 18
    Re: NVIDIA Claims 16-Pin Power Connector Issues are Over, No More Melting 2025/01/26 08:33:33 (permalink)
    I have to agree here...poorly engineered if the end user has to worry about it...
    and I work in engineering.
    AMD Ryzen 7900x3d
    Deepcool LT720
    Gigabyte Aorus Elite AX X670 (Might change..don't like this board)
    eVGA GeForce RTX 3090 FTW3 Ultra Gaming (Hybrid kit on it)
    Asus ROG Swift PG43UQ 4k Monitor
    eVGA 1600W Supernova T2 PSU
    32GB Kingston 6000 DDR5 (2x16GB) Fury
    Corsair MP600 Pro 2TB (Boot)
    Corsair MP600 2TB (Games/Data)
    Phanteks P500A Case
    Nereus
    Captain Goodvibes
    • Ribbons : 58
    Re: NVIDIA Claims 16-Pin Power Connector Issues are Over, No More Melting 2025/01/27 21:32:55 (permalink)
    *snip*
    Touch wood...
      BUILD 1 2   |   MINI-ITX BUILD   |   MODSRIGS $1K WIN   |   HEATWARE 111-0-0
