SR-3 Dark Power Mgmt Issues?
MackWage
2020/08/30 13:29:47 (permalink)
I'm running into an interesting quirk that I wonder if it may perhaps be a bios bug. I've been experiencing this issue periodically since I did this build.. it just took a bit to narrow this behavior down and isolate it from a few other things.
I am running the SR-3 DARK with the 3175x, 2080 TI hydro copper, 1300w P2 psu, and an ekwb loop. I have applied a light/conservative OC to the CPU (4.3ghz. used to be 4.5 but lowered to 4.3 to see if this issue went away). What I find is that if Windows power mgmt is set to Balanced, I will run into one of the two below issues within 24 hours of the system being online. If I set it to High Performance, it can run for weeks fine and this issue never occurs.
The two things which manifest on Balanced:
  • The computer blue-screens with a cpu watchdog error
  • Computer hard freezes and requires holding in power button to reboot
Has anyone else experienced this?
7 Replies Related Threads
    bob16314
    • Ribbons : 761
    Re: SR-3 Dark Power Mgmt Issues? 2020/08/30 18:46:38 (permalink)
    Yeah..Increase the Vcore some..Maybe 0.05v or so.
    MrTooth
    Re: SR-3 Dark Power Mgmt Issues? 2020/08/31 17:45:30 (permalink)
    Too small vcore
    I9-7920X @ x45/30 / 1.125 V @ Delid/Copper IHS | EVGA Micro2 x299 | 4x16 GB Kingston Predator 3000 MHz
    M2.NVMe - [WDS500G3XHC] 500GB | M2.NVMe [WDS100T2X0C] 1TB | EVGA RTX 2070s Black 8GB
    EVGA P2 1200W | SONY ~ KDL-32R420A | Lian-Li 011D Dynamic | 9x SW3 BL066 | OS : 19041.508 | NV : 452.06
    Custom LC : 2x Watercool Heatkiller | 2x Alphacool NexXxos ST30/360 | Alphacool VPP655 PWM
    Aquacomputer Aqualis | Mayhems Ultra Clear | 12x Alphacool Eiszapfen SK 10/16
    Monstieur
    Re: SR-3 Dark Power Mgmt Issues? 2020/09/25 16:52:12 (permalink)
    You might need to increase Vcore Offset by 10 or 20 mV instead of Vcore. The voltage ripple from load to idle is probably too great, causing it to dip too low. Increasing Vcore will affect only the load voltage (which may already be stable). Increasing the offset will increase both idle and load voltage.
    post edited by Monstieur - 2020/09/25 16:54:17
    Baasha
    Re: SR-3 Dark Power Mgmt Issues? 2020/10/06 18:41:15 (permalink)
    Very interesting. I run into the same issue (same board and CPU) only if I set the power mgmt to "High Performance" - Balanced works fine but I do get the hard freeze if I set it to High Performance and leave the PC idle for ~ 10 minutes or more.
    I set it to Balanced and never looked back but the V-Core Offset suggestion in the post above is something I will try out.
    4K, 5K, and 8K gaming - ThirtyIR
    UberRig (C622): W-3175X @ 4.50Ghz | RTX 3090 Ti FE SLI | EVGA SR-3 Dark | Trident Z Royal 4000Mhz (96GB) | Corsair AX1600i | Asetek 690LX-PN | Intel 905P (960GB) | Sabrent NVMe (8TB) | Phanteks Enthoo Elite | Dell AW5520QF | Dell UP3017Q | Audeze LCD-X (2021) | Schiit Gungnir Multibit | Schiit Mjolnir 2
    Z690 Rig (Z690): 12900KF @ 5.20Ghz | EVGA RTX 3090Ti FTW3 Ultra | ASUS MXIIIE | Arctic Liquid Freezer II 280 | Trident Z RGB 6000Mhz (32GB) | Samsung 980 Pro (1TB) | Sabrent Rocket Plus 4TB RAID-0 | EVGA 1600T2 | Corsair Carbide Air 540 | ASUS PG32UQX | Gigabyte AORUS FI32U | Sennheiser HD800 | Schiit Jotunheim 2 | Schiit Bifrost 2
    iamjanco
    Re: SR-3 Dark Power Mgmt Issues? 2020/10/07 16:43:00 (permalink)
    Glad I caught this post, though don't know how much the issue will affect me. I've got an SR-3 as well, with a W-3265 scheduled to show up Friday.
    While you can beat a dead horse as much as you like,
    you might have a tough time arguing with one.
    DEJ915
    • Ribbons : 11
    Re: SR-3 Dark Power Mgmt Issues? 2020/10/08 07:47:19 (permalink)
    iamjanco
    With that CPU I don't believe you should have an issue since you aren't able to overclock it.
    iamjanco
    Re: SR-3 Dark Power Mgmt Issues? 2020/10/08 07:54:43 (permalink)
    DEJ915
    iamjanco
    Yeah, I knew about the cpu's locked status going in. Going to use it in a workstation. Overclocking wasn't the primary consideration in the use case.
