- Ribbons : 123
Re: Ready to try water cooling. Where to start? Library of links-basics to expert
Saturday, January 19, 2019 0:44 PM
☄ Helpfulby Cool GTX Thursday, January 30, 2020 4:04 PM
To "do the Math to compute heat loads" TDP & Calculating Delta-T (excerpts) First tip: Google is your best friend to help find TDP (Thermal Design Power) of your components to be cooled in your loop. (CPU watts @load + GPU watts @load + GPU watts @load+ pump watts) x 0.85 = Loop TDP watt estimate To help calculate a full system TDP, you can download the interactive TDP and radiator estimation sheet (link) I* put together to help you. (I*= the Author - from the link)
batboy88
Tuesday, January 22, 2019 6:16 AM
Despite I've Killed **** with Blocks and doing it again...yeah it's Fine. It's better than the CLC. But still though BIG AIR has it's Merit's with Simplicity.
7700k/5.2ghz-1.34v/ FTW K/ custom Loop/ Crucial/Micron Ballistix- 3200mhz/ Vega 56 Reference/ Cooler Master GXII Pro 750w 2600x/MSI X470 4.3ghz
- Ribbons : 123
Wednesday, January 29, 2020 8:25 PM
spit051261
Re: So, your ready to try water cooling. Where to start. Library of links to good informa
Thursday, January 30, 2020 9:47 AM
stalinx20 Mods should make this a sticky.
+1 With all the other links Some time spent gathering that info Cool GTX .
post edited by spit051261 - Thursday, January 30, 2020 9:49 AM
Gaming Rig - Lian Li Dynamic XL, MSI Z490 Godlike, i9 10900k (SP 88) delidded with Rockit IHS, G-Skill 4266 RAM 2X8 , MSI Z Trio 2080ti, Aorus RGB 360 AIO, EVO 2Tb 970 Plus Nvme,1600watt P2, Acer Predator X27 Monitor, K95 Platinum, G502,G560, ST100 RGB, Void RGB Elite.OC Rig - Lian Li T70, Apex XII , i9 10900k (SP 93) delidded with direct die cooling, G-Skill 4000 2X8 Cl15-16-16 RAM , Evga KPE 2080ti, 2 x 1 Tb Evo 970 Plus Nvme, Evga 1600watt P2, EXC 800 Chiller.
tattude69
- Ribbons : 7
Friday, April 03, 2020 6:25 PM
Thank you for your effort. it was very helpful.
- Ribbons : 123
Saturday, April 04, 2020 6:38 PM
tattude69 Thank you for your effort. it was very helpful.
I'm glad this thread can help others on their journey, to learn about Custom water loops
telehog
Monday, May 11, 2020 10:14 AM
Any problem with mixing dual pass radiators with xflow raditors. Iknow flow rate is higher with the Xflow over dual pass. Planning a new build with 2 loops and if I mix the radiator types it would shorten up water lines. 2 x480, and 2x360.
sparetimepc
- Ribbons : 27
Monday, May 11, 2020 10:31 AM
telehog Any problem with mixing dual pass radiators with xflow raditors. Iknow flow rate is higher with the Xflow over dual pass. Planning a new build with 2 loops and if I mix the radiator types it would shorten up water lines. 2 x480, and 2x360.
I don't see any reason you can't mix them, but i suppose maybe the movement in the xflow radiator might get slowed down a bit but probably not enough to make a noticeable difference in temps.
telehog
Monday, May 11, 2020 5:40 PM
kougar
- Ribbons : 22
Tuesday, May 12, 2020 1:54 AM
As long as you aren't mixing metals when mixing radiators you'll be fine!
Have water, will cool.
Detleg
Tuesday, May 19, 2020 6:50 AM
What's everyone's preferred cooling loop? Pump/Reservoir -> Card/CPU -> Radiator. Or Radiator -> Card/CPU -> Pump/Reservoir? I got a separated loop
DEJ915
- Ribbons : 11
Tuesday, May 19, 2020 11:38 PM
Only bit of loop order that really matters is that your pump is at the bottom or being fed by the reservoir. I just tube mine up so the runs are the most convenient.
kougar
- Ribbons : 22
Wednesday, May 20, 2020 8:24 PM
The only part I do is radiator -> reservoir -> pump. CPUs and GPUs are throwing around the same wattages again, so it doesn't really matter. Whichever order makes for less tubing tends to be best.
tattude69
- Ribbons : 7
Thursday, August 27, 2020 2:11 PM
Do Rad ports on top or bottom affect loop performance (custom loop)? Using a Bitspower S1 Piump. I am told its basically a Laing DDC pump Cpu Block, 2 240mm x 30mm Rads, 1 120mm x 45, bitspower flow indicator restrective Eiswolf GPX block w Internal DC2600 lt pump
post edited by tattude69 - Thursday, August 27, 2020 4:12 PM
kougar
- Ribbons : 22
Saturday, August 29, 2020 2:30 AM
tattude69 Do Rad ports on top or bottom affect loop performance (custom loop)? Using a Bitspower S1 Piump. I am told its basically a Laing DDC pump Cpu Block, 2 240mm x 30mm Rads, 1 120mm x 45, bitspower flow indicator restrective Eiswolf GPX block w Internal DC2600 lt pump
Port orientation matters only so far as the pump intake. The pump cannot be sucking on air. If the pump is in the bottom of the loop, or has a reservoir on top of it then it doesn't matter... but if the pump intake is from your radiator and it will be sucking on air at the top of the rad, then you need to orient the ports down. Gamer's Nexus did a video explaining this with CLCs/AIOs if you still have questions
kcwiro
Thursday, September 24, 2020 1:15 PM
slow and steady when it comes to watercooling is the idea
themlharris
Monday, September 28, 2020 8:47 PM
thefinalhope
Tuesday, September 29, 2020 9:56 PM
Great compendium on watercooling for beginners. If anyone is worried about trying it, don't be. As long as you take your time, you'll be fine. It's worth it too in my opinion if you have the cash to spare ;)
meoxley
Saturday, October 24, 2020 8:49 PM
Anyone interested in discussing chillers or save that for a separate thread?
ivanson13
Thursday, November 19, 2020 5:13 PM
Is watercooling absolutely needed? Got a 5950x and 3090 but alot of the parts are out of stock that i would need to water cool. Would a good fan suffice?
- Ribbons : 123
Monday, November 23, 2020 5:42 PM
ivanson13 Is watercooling absolutely needed? Got a 5950x and 3090 but alot of the parts are out of stock that i would need to water cool. Would a good fan suffice?
Colder hardware = faster hardware New hardware - just launched is always hard to find blocks for .... Yes, air cooled can be OC however the Voltage & heat issues would limit your Max performance .... & all those fans @ 100% may be on the loud side ... depends on your room temp
venia
Saturday, December 19, 2020 3:41 AM
Chiller + inlet air flow FTW-24/7
SLINKY PC 3DMARK HALL OF FAME CATZILLA MASTER OC 5-WR Single GPU (More3D4Less) Use associate code 4RGGO7A3KJ92XHW on checkout for up to 10% discounts on all EVGA purchases or click on banner
Mifune
Monday, December 21, 2020 6:51 PM
Thanks so much for posting and maintaining this thread. It’s been several years since I’ve built a water cooled system and this has been very helpful in reorienting myself.
Dabadger84
- Ribbons : 10
Saturday, February 20, 2021 7:49 AM
I would find this thread AFTER I already put my new loop together and it's leak testing... lol
kougar
- Ribbons : 22
Saturday, February 20, 2021 10:38 AM
☄ Helpfulby Cool GTX Saturday, February 20, 2021 7:08 PM
- Ribbons : 123
- Ribbons : 123
Saturday, February 20, 2021 7:14 PM
Dabadger84 I would find this thread AFTER I already put my new loop together and it's leak testing... lol
happens, always in the last place you look  share the link with others Tags added to make the thread easier to find
- Ribbons : 123
Saturday, February 20, 2021 7:15 PM
Dabadger84
- Ribbons : 10
Sunday, February 21, 2021 3:28 AM
Well it seems like I did everything correct, temps are better than the AIO by over 10C on all cores... unfortunately, looks like the RGB/LED portion of my CPU block is a dud... out of everything that came with the kit, the ONE THING I did not test, the lighting on the CPU block, is the one that that's not working. What are the odds?
kougar
- Ribbons : 22
Monday, February 22, 2021 2:59 AM
Oof, that sucks. It's always the one thing that doesn't get tested though... never fails
