Helpful ReplyRTX 3090 FTW3 Ultra - Fan Speed Issue
raiden2a
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/05 10:31:46 (permalink)
Legit, thanks Lee.  The beta version has fixed the 3rd fan from going nuts.
#31
SilentSenpai
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/05 13:19:19 (permalink)
EVGATech_LeeM
I have a beta PX1 version for you guys to try to fix the fan issue.  I'll PM you guys shortly.
I'd like to try this version as well. Fan 1 seems to be fine. Fan 2 shows no RPM in the hardware monitor, even when spinning. It will spin constantly, whether I set fan speed to 0 or 100. The fan speed slider has no effect either way. Fan 3 constantly fluctuates in a pulsing fashion. (like Monolyth's pic posted earlier). This is on a 3090 FTW3 Gaming.
#32
EVGA_JacobF
  • Ribbons : 26
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/05 13:45:00 (permalink)
For anyone experiencing this, please use this version of PX, note this is a BETA release:
https://www.evga.com/EVGA/GeneralDownloading.aspx?file=EVGA_Precision_X1_1.1.0.7.exe
#33
aldur80
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/05 14:09:25 (permalink)
EVGA_JacobF
I installed this beta a few hours ago and I have to say it's mostly fixed the fan problems for me. The previous version 1.1.0.2 had Fan 3 fluctuating around 5% of the custom automatic fan setting. Now it's fluctuating 1% of the custom automatic fan setting. Fans 1 and 2 fluctuate a little, a couple of RPMs, but they stay within 1%.
Much better improvement, but that 1% fluctuation is killing my ADHD.
#34
vgerik1234
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/06 06:31:01 (permalink)
So I thought wasn't having this issue. I was using a 0db fan profile I made and kept hearing spin up. Turn outs fan 3 was jumping all over the place and I never noticed it till now. It looks like this fixed it and everything is staying where I set it w/ custom curve.
#35
aldur80
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/06 07:41:50 (permalink)
Ok, looks like the fan 3 issue is back. I have the automatic fan control setting fan 3 at 20% and it's ranging from a low of 14% to a high of 25%... Really annoying to say the least :/
#36
EVGA_Lee
Moderator
  • Ribbons : 14
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/06 10:53:07 (permalink)
We are still working out a number of things in PX1, so it's possible you'll see an update soon that will help.
#37
aldur80
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/06 11:18:33 (permalink)
EVGATech_LeeM
Sounds good, thanks!
#38
JayManB
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/06 13:22:08 (permalink)
What is the behavior of the fans without PX1 installed?  Do they work correctly?
The reason I ask is because I don't want to have to run PX1 in the background just to make my fans work correctly.
#39
EVGA_JacobF
  • Ribbons : 26
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/06 13:23:44 (permalink)
JayManB
Yes, you can actually just install PX1 and even uninstall it the firmware still applies.
#40
JayManB
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/06 13:32:58 (permalink)
Oh I see when you keep having them install different versions of PX1 you are actually reflashing the GPU bios each time.
#41
johnnytimmer1991
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/08 19:48:56 (permalink)
As somebody who’s just getting a 3080 should we install 1.0.0.2 or this one linked here (0.7)?
#42
sparetimepc
  • Ribbons : 27
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/08 22:11:42 (permalink)
johnnytimmer1991
The newest version for the 30 series cards is 1.1.0.9 If you go to px1 download in evga products you will see there is 2 different versions of px1, rtx 30 series and then the original px1 for previous gen cards.
#43
chumeniuk
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/09 17:33:53 (permalink)
After isntalling the latest version of PX1 and updating the firmware on my card, the 3rd fan is stuck at 100% after waking from sleep.  I have to close out of PX1 and restart it to get it to respond.  When it opens, the fan is showing 100% even though it's in line with the others.  I have to click Default to get the sliders and fan 100% reading to reset.
3090 FTW Ultra
#44
EVGA_Lee
Moderator
  • Ribbons : 14
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/09 17:37:32 (permalink)
chumeniuk
3090 FTW Ultra
That will be worked on.  The SW team was working on fixing a different sleep fan issue, and it seems like it created a new issue for you, instead.  I've recommended elsewhere, but please try to first uninstall the program, go to %LocalAppData%\EVGA_Co.,_Ltd\ and delete all setting files that start with "PrecisionX_x64".  Next, reboot and reinstall PX1 v1.1.0.9 and let me know if the issues continue to occur.
Also, please post a screenshot of the information page.
#45
chumeniuk
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/09 18:50:46 (permalink)
Here's the info page.  Will do the troubleshooting in the morning.  Thanks!
#46
chumeniuk
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/14 05:09:50 (permalink)
EVGATech_LeeM
chumeniuk
3090 FTW Ultra
The issues are still happening.
#47
Robob
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/14 09:01:55 (permalink)
with my 3090 I never heard a fan speed difference but I have used custom curve since day 1.
PX1 has updated the card firmware twice now so hopefully it isn't an issue
CPU - Intel i7 10700K @ 5Ghz / 1.29v
Heatsink - EVGA 280mm CLC
Motherboard - EVGA Z490 FTW (V1.10)
RAM - 32Gb Corsair LPX DDR4 3200Mhz
GFX - EVGA RTX 3090 FTW3 Ultra (10Ghz Mem/2100Mhz Core)
SSD - Samsung 970 Pro 512GB M.2
PSU - EVGA G3 750w
Case - Corsair Carbide 678C
Monitor - LG 27GN950B 4k@144Hz
OS - Win 10 Pro x64
HID - Corsair K70 / EVGA X17
HMD - Valve Index & Controllers
Past EVGA MB - 680i/750i/Z68
Past EVGA GFX - 8800/275/560Ti/680SC/Titan(Kepler)/1080Ti
#48
shogun168
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/29 14:59:35 (permalink)
Experiencing the same issue here. Fan 3 is always roughly 25% off the other two fans. My info pane screenshot:
Using the 1.1.0.7 beta version that Jacob posted earlier in the thread.
#49
EVGA_JacobF
  • Ribbons : 26
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/29 15:03:25 (permalink)
Which driver version? We are aware of a current bug affecting fanspeeds with latest driver.
#50
shogun168
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/29 15:06:28 (permalink)
Oh that's weird, it stripped out my imgr link ...
Display driver: 457.09
Bios: 94.02.26.48.15
Firmware: 2.1.14
#51
EVGA_JacobF
  • Ribbons : 26
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/29 15:11:30 (permalink)
#52
jsrob0
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/29 15:16:13 (permalink)
Hello,
I have been a member since 2014, but I have 0 posts and 0 score so I can't send a PM.
I have a 3080 FTW3 Ultra and my Fan 3 is also jumping RPMs towards the lower end of the curve (20%) and I was hoping I could get the beta PX1 to see if it resolves my issue. @EVGATech_LeeM if you see this, could I get a download link for the beta PX1? I am currently running the version 1.1.0.11 and info attached.
Thanks in advance for any help.
post edited by jsrob0 - 2020/10/29 15:19:21
shogun168
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/29 15:19:17 (permalink)
Ah OK, I'll sit tight. I feel like the previous driver was a few % off on fan 3 and not the 25% that I have now although purely anecdotal and from memory. I was actually trying to fix a separate problem before finding this thread. I had the whole Precision X1 not being able to start. Deleted cfg and still didn't work, this beta worked to get the app launched.
#54
mikercbsh
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/30 15:04:14 (permalink)
Apologize this is my first post, looks like I messed up my board info image attachment above.
#55
mikercbsh
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/30 15:23:32 (permalink)
My info is:
Display device:  Gefore RTX 3090
Display driver:   456.71
BIOS version:    94:02:26:48:F8
Firmware:          2.1.14
#56
mikercbsh
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/30 16:54:56 (permalink)
Hi EVGA Team / All,
   I am having an issue with auto fan control. When GPU temperature reaches 83 degrees, fan 2 stops spinning and fan 3 goes to 99%. I see this in PX1 on my second monitor while gaming on my first monitor.
I have been having this issue on previous versions of Nvidia drivers and original bios / firmware.
Thanks you in advance for all your help, Mikhail.
My info is:
Firmware:          2.1.14
#57
Scamid
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/10/31 02:25:17 (permalink)
I am having the issue with a 3080 ftw3 ultra. Fan 2 is just stuck at 100%. No way to controll it.
I will check the new pc1 beta version today.
I have tested both 456... And 457.09. Both have the issue for me.
post edited by Scamid - 2020/10/31 02:50:42
#58
Vaidas666
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/11/05 10:49:04 (permalink)
I have just noticed also strange fan behaviour once trying to set manual fan curves...FAN 1+2 running at different ratios than FAN 3
Does this work as intended or is this a bug?
For example to set all fans to spin at ~1500rpm (which is ~50% speed) I have to set:
Fan 1: 65%
Fan 2: 65%
Fan 3: 50%
PX1: v1.1.0.11
GTX 3090 FTW3 Ultra
457.09
94.02.26.48.F7
2.1.14
#59
wilbaur
Re: RTX 3090 FTW3 Ultra - Fan Speed Issue 2020/11/05 11:00:35 (permalink)
I am experiencing a similar issue.
With fan speed set to locked 51% for all 3 fans I get the following speeds:
Fan 1: 30%
Fan 2: 30%
Fan 3: 51%
Even if I run a fan curve, Fans 1 & 2 still lag behind by about 20%.
PX1 v1.1.0.11
EVGA 3090 FTW3 Ultra
457.09
94.02.26.48.15
2.1.14
post edited by wilbaur - 2020/11/05 11:50:38
#60
