I hate the way the EVGA Radiator Fans sounds at the back of my Lian Li PC-o11D xl case. I am using push-pull config with the radiators mounted on the side position with 3 Lian Li sl120s on the opposite side, most interior of the case. The lowest RPM I can get on the radiator is 790 rpm @ idle, yet the sound it makes is irritating me af.
Will there be a problem if I switch out the 2 fans on the radiator to two Lian Li Uni sl120s? By doing this, I will be ditching the push-pull config to just a normal radiator side-mounted in a pull config.
