BigBlake1205
Hi, so I currently have a 3080 FTW3 hybrid card with the kit installed. And I was wondering if I switched to ml 120’s (2400 rpm version) would there be any noticeable Gains over the stock fans running at 3000rpm?
- Ribbons : 84
Re: I am looking for replacement fans for the hybrid kit radiator fans
2021/09/20 04:02:20
I don't know if changing the fans will void the warranty, so please contact EVGA first. Hopefully this will be OK. What type of gains are you looking to achieve?
BigBlake1205
2021/09/20 07:38:26
Well I’m trying to drop from low 60’s to mid 50’s with a lower rpm
andross182
2021/09/20 08:03:23
I have my 3080ti FTW3 Hybrid in a push/pull with the Corsair ML120 Capellix fans and they are fantastic so far. Replacing the fans will not void your warranty.
Jugorwski
2021/09/20 08:13:19
Phanteks T30 are really Good. And noctua a12x25
kevinc313
- Ribbons : 22
2021/09/20 08:15:37
BigBlake1205 Hi, so I currently have a 3080 FTW3 hybrid card with the kit installed. And I was wondering if I switched to ml 120’s (2400 rpm version) would there be any noticeable Gains over the stock fans running at 3000rpm?
Agree with everything people already posted. If you have the ML120's, run them push pull with the stock fans and seal the fans to the rad with gaffing tape. If you use top exhaust, make sure you have plenty of other unobstructed intake fans pressurizing the case.
BigBlake1205
2021/09/21 03:48:31
Would the ml120s be better then the stock fans right out the gate?
charlesborner
2021/09/21 04:03:54
BigBlake1205 Would the ml120s be better then the stock fans right out the gate?
Without actually doing extensive testing, nobody's going to be able to tell you for sure. In general, moving to a push-pull configuration will probably net you better thermal control and noise profile. Especially if you thermally control the fans.
Ryzen 5950X, Alphacool Eisbaer 420mm, ASROCK Taichi Razer, NVIDIA 3070 Ti FE, 3x Samsung 980 Pro 1TB, 64GB Trident Neo Z DDR4000, Seasonic Focus GX-1000, Total Noctua Fan Swap (8x Redux NF-P14S, 2x Chromax A20), 4x10TB WD Gold in Synology 920+, Thermaltake Core X9
- Ribbons : 270
2021/09/21 04:13:16
andross182 Replacing the fans will not void your warranty.
It will if you get rid of them, lose them, or damage them.
kevinc313
- Ribbons : 22
2021/09/21 05:22:28
No, they would be virtually the same. Kinda loud at higher speeds, the stock fans are faster but the ML120 are sealed better by design. If you already have the ML120's, if you can fit them you NEED to run push pull. This is the way. You can get good temps at lower volume or turn them up as needed and get 5-9C improvement in temps. Note other air flow in the case when configuring, or even better post pic of your rig.
BigBlake1205
2021/09/21 06:08:17
So I’ve got a 4000x Rgb case. I’ve got a 360mm rad with ml120s front mounted in pull so it’s drawing in cold air from the front of the case but it doesn’t make it past the radiator. I’m running the hybrid kit as top exhaust with ml120s pushing the air out of the radiator from the inside of the case with a rear ml120 as additional exhaust. I’m thinking about mounting ml 120s in push pull on front mounted radiator so the cold air goes through the radiator to the case.
BigBlake1205
2021/09/21 08:01:22
Could I use the 2400rpm ml 120s in push pull with the stock fans until I manage to get more ml120s to match and have good temps?
bladexngt
2021/09/21 08:49:00
I am using SL120s in my O11D all around. Works well. Temps with an overclock never get above 65.
kevinc313
- Ribbons : 22
Flagged as Spam (2)
2021/09/21 09:08:33
austin86 EVGA is grate that way.
EVGA is the bets. We harte EVGA.
kevinc313
- Ribbons : 22
Flagged as Spam (1)
2021/09/21 09:12:01
BigBlake1205 Could I use the 2400rpm ml 120s in push pull with the stock fans until I manage to get more ml120s to match and have good temps?
YES. Are you feeling ok buddy?
venstan
Flagged as Spam (1)
2021/09/21 09:17:06
andross182 I have my 3080ti FTW3 Hybrid in a push/pull with the Corsair ML120 Capellix fans and they are fantastic so far. Replacing the fans will not void your warranty.
theoretically not but if fans is not stock or/and compatible and have traces then this avoid the warranty
kraade
- Ribbons : 7
2021/09/21 09:20:49
The artic A12s you can get a five pack for the same as 1 Noctua but they top out at 1800 but are super quiet for the amount air they move.
BigBlake1205
2021/09/21 09:54:34
Becuase the stock fans are 3000rpm lol I was going to mount the stock fans on top of the radiator in pull and at the bottom with the ml120’s (the radiator is being mounted in an exhaust position.) So my current temps max at around 65c while playing games with the fans on max (3000rpm). Would I be able to get down to mid 50’s at a lower rpm and noise level in general with push pull?
kevinc313
- Ribbons : 22
2021/09/21 10:27:10
Just do it already dude. This isn't Reddit, we know what we are talking about. BigBlake1205 So my current temps max at around 65c while playing games with the fans on max (3000rpm) Would I be able to get down to mid 50’s at a lower rpm and noise level in general with push pull?
No. How would that be possible.
post edited by kevinc313 - 2021/09/21 10:28:36
Kasque
Flagged as Spam (4)
2021/09/23 06:36:51
there is some improvement yes
Jugorwski
2021/09/23 06:57:09
I have the Phanteks T30 in Push/Pull and they keep my 3090 ftw3 Hybrid really cool. 1450rpm will Result in 62c(Metro Exodus EE 450watts). With this Speed they are really quiet and they can Go up to 3000rpm.
kevinc313
- Ribbons : 22
2021/09/23 09:04:14
Jugorwski I have the Phanteks T30 in Push/Pull and they keep my 3090 ftw3 Hybrid really cool. 1450rpm will Result in 62c(Metro Exodus EE 450watts). With this Speed they are really quiet and they can Go up to 3000rpm.
Ooooooo nice. Looking forward to getting mine set up.
bavor
- Ribbons : 6
2021/09/23 16:48:53
kraade The artic A12s you can get a five pack for the same as 1 Noctua but they top out at 1800 but are super quiet for the amount air they move.
I'm not sure if theya re any better than the stock EVGA fans and might actually be worse in terms of static pressure and volume of air moved. The arctic 120mm fans really have an awfully annoying buzz/hum right around 1100 RPM. Some of the reviews have covered this. Out of the 10 arctic fans I bought in two 5 packs, 4 of them died within a year. The good news is that Arctic has good warranty support and sent me a 5 pack for warranty replacement.
03whitegsr
2021/09/23 16:58:00
I'm running the Artic P12s on a 3080Ti XC3 hybrid. With them set to 70%, temps sit below 50C while gaming. Benchmarks at 360W put it around 56C. It's very quiet at this setting.
post edited by 03whitegsr - 2021/09/24 11:48:07
kevinc313
- Ribbons : 22
2021/09/23 17:10:17
From what I understand the P12's do really well for the money and are relatively very effective at lower RPM's like 1500 rpm or less, but lack the top end of the faster fans and aren't as quiet as the A12 or T30. Part of the effectiveness of the P12 is due to the tiny hub, which limits speed and quietness. The A12 has a big hub and the T30 splits the difference. The GT2150 is more powerful and a bit louder, the ML120 is powerful but loud. The A12 is somewhat powerful but very quiet, the T30 is similarly quiet but with way more top end, but TBD durability.
post edited by kevinc313 - 2021/09/23 17:13:48
03whitegsr
2021/09/24 12:01:31
Depending on which version of the 3080/Ti you have, I'm not sure there is a lot of benefit going to something more powerful then the P12. For the power limited XC3 cards, I'm not sure running it cooler then 50c will do much for you in game.
With an FTW3 card though, the extra 50-100W though could probably benefit for more air.
I was thinking about messing around with it some this weekend though. Maybe I'll see if I can get some more out of it using the stock fans in a push/pull setup and run them all off the motherboard.
Chiyeji
2021/09/24 15:19:44
kevinc313
Why does one need to "seal the fans to the rad with gaffing tape"?
kevinc313
- Ribbons : 22
2021/09/24 17:39:39
Chiyeji
kevinc313
It's just something I personally like to do, the fans are creating pressure (push) and suction (pull) against the radiator, they leak air at any gaps in the mating which wastes air flow and makes noise. I've never tested it vs. not so it's possible it doesn't have any measureable effect, but I have the opinion if you make enough small tweaks they will eventually add up to an improvement. But if OP does the above and runs the fans at about 2000RPM with other fans feeding it fresh air, temps should be under 55C gaming at ~400w with 20C ambient.
post edited by kevinc313 - 2021/09/24 17:44:51
