Hot!RTX 2080 Ti XC ultra temps high after another repast and bad frames and not bosting on beam np
Landvader07
2024/11/07 10:16:20 (permalink)
My 2080 ti has given me trouble recently because of the high vram to gpu usage in beam mp. It will stay at stock speed while it uses 8gb of ram. It will get 15 frames and I tried a ddu and reinstalling beam mp. I also played the normal beam ng and that worked perfectly. (Beam mp is a multiplayer mod for beam ng). I tried my ASUS GTX 770 directCU II OC 2gb gpu and that worked perfectly fine. Also my temps are still high after another repaste. I can’t afford ptm7950 so I used Noctua-H1 thermal paste and it was at 70 degrees Celsius in beam ng with an overlock.
post edited by Landvader07 - 2024/11/07 10:18:13
4 Replies Related Threads
    Re: RTX 2080 Ti XC ultra temps high after another repast and bad frames and not bosting on 2024/11/07 22:23:07 (permalink)
    If temps are too high it won't boost. Sounds like another repaste is in order. Save up and get the PTM7950.
    • Ribbons : 123
    Re: RTX 2080 Ti XC ultra temps high after another repast and bad frames and not bosting on 2024/11/09 13:50:09 (permalink)
    making sure the cooler is sitting flat & making good contact with the GPU die is crucial, also the entire GPU die needs to be covered with paste
    if you replaced thermal pads on the card - they need to be the correct thickness & hardness .... pads that are too hard or too thick will prevent proper contact between GPU die & cooler
    Have you confirmed fans are spinning on cooler?
    Set a custom fan curve for better cooling.
    case fans, you need to get the hot air out of the case before the GPU recycles it?
    Landvader07
    Re: RTX 2080 Ti XC ultra temps high after another repast and bad frames and not bosting on 2024/11/09 22:57:32 (permalink)
    Fans are spinning, I have set a custom fan curve in Precision X1. I have not replaced the thermal pads. I have cleaned the card multiple times. I have 7 case fans so I don't have to worry about that.
    • Ribbons : 123
    Re: RTX 2080 Ti XC ultra temps high after another repast and bad frames and not bosting on 2024/11/11 10:23:42 (permalink)
    using OC software, try limiting Voltage to GPU to between 90% - 95%
    The lower V will reduce temps & usually does not impact performance much; because, Nvidia Boost will clock a cooler GPU faster
