RTX 2080 Ti FTW3 Ultra Water Block
Moneywaster
2020/08/25 02:34:23 (permalink)
Hello folks,
I was looking for a water block for my 2080 Ti and unfortunately didn't find anything that would actually work except the Hydro Copper which is currently out of stock anywhere I looked. Is there something alternative that could work, either from EK water blocks or anything similar that looks as neat as the Hydro Copper series. Any chance that the Hydro Copper water block going to be in stock soon?
Looking forward to your comments.
5 Replies Related Threads
    sparetimepc
    • Ribbons : 27
    Re: RTX 2080 Ti FTW3 Ultra Water Block 2020/08/25 04:21:50 (permalink)
    Moneywaster
    Hello folks,
    More then likely you will only find a hydro copper on ebay or something since the 2000 series cards are now pretty much end of life. Here is the block from EKWB that would fit.   https://www.ekwb.com/shop/ek-quantum-vector-ftw3-rtx-2080-ti-d-rgb-nickel-plexi    I order alot directly from EKWB and there shipments usually arrive in good time.
    post edited by sparetimepc - 2020/08/25 04:23:58
    DeadlyMercury
    • Ribbons : 14
    Re: RTX 2080 Ti FTW3 Ultra Water Block 2020/08/25 05:11:29 (permalink)
    Actually EKWB have 2 waterblocks for 2080 ti ftw3. Transparent (pleksiglass) and black one (acetal):
    https://www.ekwb.com/shop/catalogsearch/result/?q=ftw+2080+ti
    https://www.ekwb.com/shop/ek-quantum-vector-ftw3-rtx-2080-ti-d-rgb-nickel-acetal
    "An original idea. That can't be too hard. The library must be full of them."
    Stephen Fry
    clone
    Re: RTX 2080 Ti FTW3 Ultra Water Block 2020/08/31 02:53:57 (permalink)
    Just be aware if you do fit a evga hydro copper make sure you put thermal paste on the gpu die and block.
    I fitted said block on my 2080 super ftw3 ultra and did the large pea size blob in the centre,my card keeped getting errors so I took the block back off and found the paste did not cover the whole die so did both die and block and it's now running great now.
    Asus Rog Maximus XII Formula
    10700K @ 4.8ghz 1.20v
    16Gb 8Pack 3600hz
    EVGA 2080 Super FTW3 Ultra
    Watercooled
    Phantek Evolv X
    ShawnB420
    Re: RTX 2080 Ti FTW3 Ultra Water Block 2020/09/01 08:01:20 (permalink)
    Ek or Hydrocopper are the only options. Optimus has said they will make a FTW/Kingpin model but since they can't even get the normal 2080ti block out I wouldn't hold your breath for them.
    Moneywaster
    Re: RTX 2080 Ti FTW3 Ultra Water Block 2020/09/02 04:47:42 (permalink)
    I consider it kinda unfair that 400-HC-1489-B1 is out of stock everywhere and is marked as end of life. There is still a hydrocopper available for some of 2080 series and the 1080 Ti as well. Any chance that it’s gonna be in stock ever again? Those who are still selling the HC waterblock are offering it for up to $400. The EVGA 2080 Ti FTW3 Ultra is still very pricy though.
