Tweaked
- Ribbons : 29
I know there are a few musicians here in the forums, so I thought I'd start this thread since I am just getting into working on guitars. I purchased this used cheap guitar as a platform to upgrade and learn how to do fretwork. My plan is to transform this "beginners" guitar into a player grade monster on a budget. So here's what I've got so far, and the progress I've already made. Guitar is a Donner DST-100R that I picked up used at Guitar Center for $89. I have on order a set of Wilkinson EZLock tuners, and a used set of Fender Player Series pickups.
post edited by Tweaked - 2021/02/04 09:27:58
EVGA DG-77/ EVGA 750 G2/ Gigabyte B450/ AMD Ryzen 5 3600/ 16gb Crucial Ballistix DDR4-3600/ RTX-2080 XC/ Dell S2716DG / Windows 11 64
Tweaked
- Ribbons : 29
Re: Project guitar build thread.
2021/02/04 09:21:24
As you can see by the photos, I have shielded the pickup cavity. I also plan to shield the underside of the pickguard, replace all the electronics with quality parts and rewire the entire thing.
post edited by Tweaked - 2021/02/04 09:25:53
Tweaked
- Ribbons : 29
2021/02/04 09:22:06
I'm replacing the cheap, small bridge and trem block with a Musiclilly upgraded version.
post edited by Tweaked - 2021/02/04 09:28:12
STR1D3R_2
- Ribbons : 13
2021/02/04 21:11:01
Popcorn is popping! Do you have any audio from before to compare to the after when completed? I love threads like these
Affiliate code E1HEL4HYPS
- Ribbons : 84
2021/02/05 01:00:24
Looking forward to seeing the completed project. One day I really need to get back into playing again.
Tweaked
- Ribbons : 29
2021/02/05 05:59:50
No, I didn't think to record it, but I still could since I have not done disabled the pick guard and rewired it yet.
Tweaked
- Ribbons : 29
Delirious
- Ribbons : 61
2021/02/05 07:45:23
"Be quick to listen, slow to speak and slow to anger" Affiliate Code XZUMV9TJW5 Associate Code: 7PM43CU71IB2IAP education may be expensive but wait until you get the bill for ignorance A wise man once said that we can't make anyone feel or do anything. We can throw things into the wind, but it's up to each person to decide how they want to react, where they want to stand when things fall.
Nekro-DtoF
2021/02/07 22:49:33
This looks like fun lol How much you got in shielding? Being left handed gives me minimal options sadly I modified my Lefty Schecter C-1 Elite Diamond Dimebucker on bridge Jazz humbucker on neck position (Both Seymour Duncans) Used 500k Seymour Duncan pots also Annoying this is getting wiring diagrams and having to flip everthing backwards so the volume and tone knobs are being turned the correct way lol Next up Is upgrading two Ibanez 1560L most likely I'll go with Dimarzio's One might be dropped tuned to d Other standard e
post edited by Nekro-DtoF - 2021/02/07 22:50:58
Tweaked
- Ribbons : 29
2021/02/09 06:14:32
Nekro-DtoF
2021/02/11 00:57:47
Thanks I'm not a fan of scalloping the fretboard. I just dont press hard enough to touch the wood lol But is this something you would try on this?
syphonzero
2021/02/11 01:27:08
Anything custom in increments makes it way more memorable. I am impressed. Bold to be digging into a new field shows your thirst for knowledge. Deffinalty looking forward to following your progress. Nekro-DtoF ... Being left handed gives me minimal options sadly ...
As a fellow left-handed individual, I agree. I resorted to learning right-handed *sighs*
Tweaked
- Ribbons : 29
2021/02/11 09:46:33
Just finished wiring everything last night, but I'm having a really weird problem. I've got signal from all pickups, and the switch is working properly, but the volume pot is not reducing the signal into the amp despite when I measure with my multimeter I get the full resistance of the pickup with volume wide open, and infinite resistance when the volume is all the way off.
Nekro-DtoF
2021/02/12 00:28:50
- I recommend many that have asked me if they should learn lefty...i tell them no lol then they say...but im lefty. I tell them...ur body doesn't know left from right on playing a guitar lol learn right handed and dont frustrate urself that theres no options out there lol Tweaked- Any chance you didn't over heat volume pot? Them things are delicate lol
syphonzero
2021/02/12 06:47:29
This might sound super lowbrow; I am just speculating with no real knowledge of this field. Measure the resistance at the guitar cable on the end that plugs into the amp - if nothing else - to see if it yields a different result.
bill1024
- Ribbons : 65
2021/02/12 07:53:09
notfordman
- Ribbons : 28
2021/02/12 09:43:03
Looks like a real fun project Tweaked. I hope you figure out the switch/knob thing. It's going to be really nice. Then there will only be one problem..... The talk with the wife about getting the band back together.
Tweaked
- Ribbons : 29
2021/02/12 10:46:54
I got the volume working properly. It was a bad ground on the outer lug of the pot.
post edited by Tweaked - 2021/02/12 21:27:28
Nekro-DtoF
2021/02/13 00:14:58
I've only done HH Les Paul Wiring 2Volume 2Tone pots and HH 1Volume 1Tone pots lol That looks like...fun lol Can Imagine my Ibanez HSH 5way switch wiring
Joshdb2010
2021/02/13 09:50:37
Tweaked
- Ribbons : 29
2021/02/15 07:41:49
Now I've got another issue with the wiring. Depending on how I have the middle pickup wires, either position 2 or 4 is out of phase and sounds incredibly thin and harsh sounding. Plus, I'm having a hard time getting the string slot height in the nut correct. It pulls out of tune on open chords. More work to do.
Tweaked
- Ribbons : 29
2021/02/19 06:23:27
So, I figured out the issue with the string slot height. It really wasn't the string slots. The nut slot was not cut perfectly flat, so the nut was not resting on the flat bottom, instead the slot narrowed from top to bottom causing the nut to be wedged slightly above the flat surface. Also, the bottom was not completely flat, so I had to file that down a bit. Still fighting with that Bridge/Middle position wiring. I've tried reversing the wiring on the middle pickup and that fixed the bridge/middle position, but caused the neck/middle to sound bad so I put it back the way it was. I then tried reversing the wiring on the humbucker, but that had the same issue as before. There are a ton of wiring diagrams on the internet, so I'm going to try a few more to see if I can find a sound I like.
2021/02/19 08:41:49
Its always the last thing you try that fixes it Nice project
Joshdb2010
2021/02/21 09:14:29
Keep up the good work it will be awesome when your done!
EVGATech_DavidR
EVGA Tech Support
2021/02/21 14:39:46
Looks nice. Not really a "build" persay, but I've been meaning to upgrade the pickups in a 1989 Made in USA Squire Strat for a long time. Ended up getting it for free back in '04 from some random dude.
Nekro-DtoF
2021/02/21 23:53:12
What radius is the fretboard? I was gonna ask maybe the nut or bridge isn't matching the rest of the neck radius
Tweaked
- Ribbons : 29
2021/02/22 12:54:07
Nekro-DtoF What radius is the fretboard? I was gonna ask maybe the nut or bridge isn't matching the rest of the neck radius
The fretboard has a 12" radius. I got the wiring figured out. I changed to a different Wiring plan that doesn't split the humbucker in the 4th position. I'm using a wiring from Seymour Duncan. I'm pretty well finished except the nut. I cut it way too low and the high E was fretting out on the first fret. Now I'm trying to decide if I want to just get another blank and recut it, or find a precut that is tall enough to fit the nut slot.
CraptacularOne
- Ribbons : 222
2021/02/22 13:25:35
Good stuff, and yeah wiring is always my least favorite part of any build, be it PC or guitar I'm redoing a guitar of mine too as coincidence would have it. This was a old BC Rich Warlock Platinum that I got over 20 years ago back when I was still playing in a band. This thing was used and abused but I still love it, the way it sounds and plays. But I recently stripped it down and am redoing the paint and upgrading the hardware. It's the guitar on the bottom in this pic that I'm redoing. I'm going for a cosmic look with it, but more just kinda abstract.
wmmills
- Ribbons : 40
2021/02/22 14:37:57
@Tweaked: You wanna really make that cheap guitar sing.....buy a new neck for a neck-thru design! Maybe even add a new rare wood layer to the whole body too. @Crap: I like it! Very cool look and it really makes you want to look at it. That should look pretty good in the end once its sealed and buffed. You guys are killing me with all these guitar projects....makin me want to buy a bass to destroy..... i mean mod.
Nekro-DtoF
2021/02/24 10:03:37
wmmills @Tweaked: You wanna really make that cheap guitar sing.....buy a new neck for a neck-thru design! Maybe even add a new rare wood layer to the whole body too.
lol buying a neck-thru would mean a whole new guitar since his is a bolt-on
