Project: Aluminum Water Cooling Case
Spotswood
  • Ribbons : 7
Sunday, April 17, 2011 10:30 PM (permalink)
This is a project/build log for an aluminum case designed specifically for a large water cooled rig, specifically:
  • 3 x 140x4 radiators
  • 1 140x3 radiator
  • 10-slot motherboard tray
Stay tuned!
96 Replies Related Threads
    zophar
    • Ribbons : 26
    Re:Project: Aluminum Water Cooling Case Sunday, April 17, 2011 10:34 PM (permalink)
    SWEET!!!! I'd be interested in the cost of such a case.
    Spotswood
    • Ribbons : 7
    Re:Project: Aluminum Water Cooling Case Friday, April 22, 2011 4:11 AM (permalink)
    The basic frame of the case is done, which consists of .5x1-inch u-channel with its ends plugged with blocks (pictured in the first post), press-fitted and pinned with a #4 screw along with some 1-inch angle:
    The assembled case frame is too tall to fit in the camera frame.  hehe
    The frame looks kind'a "meh" until I bolt on the gorgeous anodized quarter rounds.
    Halo_003
    • Ribbons : 51
    Re:Project: Aluminum Water Cooling Case Friday, April 22, 2011 4:24 AM (permalink)
    Mind PMing me the cost of this case? Both materials and what you're charging? Always looking to expand my list of 10 slot cases.
    i7 7700K - ASUS Maximus IX Apex - 16GB G.Skill TridentZ RGB 3466MHz C16 - 5700 XT 50th Anniversary
    farthestkris
    • Location: Crunching Location .......... Location Not Found
    • Ribbons : 12
    Re:Project: Aluminum Water Cooling Case Friday, April 22, 2011 1:30 PM (permalink)
    ^ +1 if i could get a PM too please :) 4
    DMIINC
    • Ribbons : 32
    Re:Project: Aluminum Water Cooling Case Friday, April 22, 2011 3:19 PM (permalink)
    Very nice again.
    Stuey 1122
    Re:Project: Aluminum Water Cooling Case Friday, April 22, 2011 4:28 PM (permalink)
    Looking excellent man, can't wait to see more!
    Spotswood
    • Ribbons : 7
    Re:Project: Aluminum Water Cooling Case Sunday, May 15, 2011 10:13 PM (permalink)
    The two shelves were cut from a .10-inch thick 5052 via my trusty router, a straight edge and a downcut spiral bit.
    At the back corners of the shelves, two .5x1-inch cutouts were routed out via a temporary router jig.
    The rounded inside corner left by the .5-inch flush router bit were filed square.
    FWIW, here's the difference in the thickness of the aluminum sheeting I use compared to everyone else.
    Finally, a mockup of the shelf inside the frame of the case:
    Krony
    Re:Project: Aluminum Water Cooling Case Sunday, May 15, 2011 10:34 PM (permalink)
    This looks good, i too would be interested in pricing plz.
    {uZa}DOA
    • Ribbons : 15
    Re:Project: Aluminum Water Cooling Case Sunday, May 15, 2011 11:56 PM (permalink)
    Looking great so far! Can't wait til it's complete! Good luck with the build!!
    Spotswood
    • Ribbons : 7
    Re:Project: Aluminum Water Cooling Case Friday, June 03, 2011 4:47 AM (permalink)
    The 5.25-inch drive bay rails finally came back from a local fabricator.
    And a 140x4 rad arrived in the shop.
    Gone Cruising
    • Ribbons : 45
    Re:Project: Aluminum Water Cooling Case Friday, June 03, 2011 10:44 AM (permalink)
    WOW!! 33" tall WOW!!!!! I've been waiting for you to build this monster!!!!! I'll be sitting here admiring your progress as usual!!!
    Gigabyte Z390 Aorus Ultra
    Intel Core I9-9900K
    Corsair 32gb DDR4
    EVGA RTX 2070 Super
    EVGA 850W Gold
    2 x 1TB Samsung SSD
    2 x 3TB HD's in Raid 1
    Kustom Case
    https://www.heatware.com/u/67033/to
    strife01013
    Re:Project: Aluminum Water Cooling Case Friday, June 03, 2011 1:46 PM (permalink)
    Amazing!
    Case: Antec 1200 V3  Monitor: Samsung S27A550H 27" x2 (Dual Monitors)  MB: ASUS P8P67 Deluxe B3
    CPU:
    Intel i7 2600k 3.4GHz (OC'd @ 4.4GHz) & Corsair Hydro H60 CPU Cooler  HD: Samsung 840 Evo (250GB) SSD (C Drive) & WD Caviar 1TB 7200RPM x 2 (Storage)  GPU: EVGA 460GTX 1GB SC EE X2 SLI  RAM: Corsair Vengeance 16GB DDR3 1648MHz
    PSU: Corsair 850HX  Sound Card: HT Omega Claro Plus+  Speakers: Logitech 5.1 X-530  DVD Burner: ASUS DRW-24B1ST
    Blu-Ray Burner:
    ASUS BW-12B1LT  OS: Windows 7 x64 Ultimate
    mcyhanick
    Re:Project: Aluminum Water Cooling Case Friday, June 03, 2011 2:27 PM (permalink)
    I wish I could do with metal as I can with wood and acrylic. GLWP / can't wait to see it through completion!
    nickbaldwin86
    Re:Project: Aluminum Water Cooling Case Friday, June 03, 2011 4:05 PM (permalink)
    WOW 3 - 4 x 140 WOW
    WATCHING!!!
    -EGC-Ripley
    My Affiliate Code: QJPC2FGYYT
    Add3r
    Re:Project: Aluminum Water Cooling Case Friday, June 03, 2011 8:32 PM (permalink)
    Very impressive work with the sky as the limit for the cooling potential.  I love it, solid fabrication and construction and excellent design! Good luck with this build and I will DEFINITELY be following this one to the very end, just like all of your other, truly stunning case builds.
    SrzBznz Build (My White Antec 1200 Build)
    http://www.evga.com/forums/tm.aspx?m=947409
    -Comment and Critique- Anything appreciated! :D
    chris619
    Re:Project: Aluminum Water Cooling Case Friday, June 03, 2011 9:31 PM (permalink)
    this is amazing when can we get pricing ? can't wait to see it fully built.
    Spotswood
    • Ribbons : 7
    Re:Project: Aluminum Water Cooling Case Saturday, June 04, 2011 4:06 PM (permalink)
    I won't lie to you...building these cases one at a time is expensive.  Someday I hope to build a small batch of 'em, but how many?
    PM sent.
    seabigbear
    The Polar Rig Master
    • Ribbons : 61
    Re:Project: Aluminum Water Cooling Case Saturday, June 04, 2011 4:14 PM (permalink)
    Want more pics!
    mcyhanick
    Re:Project: Aluminum Water Cooling Case Sunday, June 05, 2011 1:38 PM (permalink)
    whats the thickness of the aluminum stock that you use?
    Spotswood
    • Ribbons : 7
    Re:Project: Aluminum Water Cooling Case Sunday, June 05, 2011 1:55 PM (permalink)
    mcyhanick
    .10 inch
    mcyhanick
    Re:Project: Aluminum Water Cooling Case Sunday, June 05, 2011 3:12 PM (permalink)
    oh ok, thought that was just the brackets. Nice man, can't wait to see the build progress unfold!
    Sum1uNo83
    • Ribbons : 12
    Re:Project: Aluminum Water Cooling Case Monday, June 06, 2011 0:01 PM (permalink)
    very nice so far. looking forward to more pics.
    #23
    v1ral
    Re:Project: Aluminum Water Cooling Case Monday, June 06, 2011 0:05 PM (permalink)
    Question.
    How did you make those "end blocks" for the pieces?
    I was scouring the net for some kind of case build of this nature to follow for my pedestal I want to build for my HAF 932*so I don't buy a case that I don't need :P.
    I have the measurements that I want for the pedestal, but to make a frame for it has gotten me baffled,
    #24
    Spotswood
    • Ribbons : 7
    Re:Project: Aluminum Water Cooling Case Monday, June 06, 2011 0:11 PM (permalink)
    v1ral
    Question.
    Easy.  I just cut some flat bar, drilled a hole and pinned them inside the u-channel with a flathead screw.  Since then, I now pin the blocks with split pins.  For more build techniques see another log of mine here
    #25
    v1ral
    Re:Project: Aluminum Water Cooling Case Monday, June 06, 2011 0:14 PM (permalink)
    Holy mackeral..
    Just what I was looking for.
    How hard is it to implement one of those motherboard trays onto a home made panel?
    Only that would hinder this for me is my lack of tools haha.
    How much would you charge for making a simple Cube structure just frame, I can assemble it when it arrives
    Say 14"x22"x10", W x D x H, and in inches
    post edited by v1ral - Monday, June 06, 2011 0:31 PM
    #26
    DivinEvil
    Re:Project: Aluminum Water Cooling Case Monday, June 06, 2011 0:53 PM (permalink)
    Looking forward to this build.
    #27
    Spotswood
    • Ribbons : 7
    Re:Project: Aluminum Water Cooling Case Monday, June 06, 2011 2:31 AM (permalink)
    Next up is to cut the front sheet.
    In order to cut-out all of the openings for the 5.25-inch drives accurately, a custom router template is required.  I used .5x1-inch u-channel and .25x1.25-inch flat bar to frame the openings on .5-inch particle board.
    The aluminum bits guided my flush trimming router bit.
    The aluminum bits were removed and the particle board template was used to cut the .10-inch thick aluminum sheet.
    Now I just need to square all of the corners and cut to width.  Ugh.
    #28
    Hypn0t1q79
    EGC Admin
    Re:Project: Aluminum Water Cooling Case Monday, June 06, 2011 2:59 AM (permalink)
    Thats An Awsome Case.
    Where In NH are you from?
    #29
    Spotswood
    • Ribbons : 7
    Re:Project: Aluminum Water Cooling Case Monday, June 06, 2011 3:01 AM (permalink)
    Hypn0t1q79
    Thanks!   I'm in Nashua.
    #30
