Project: Aluminum Water Cooling Case
Page: < 1234 > Showing page 3 of 4
Spotswood
  • Ribbons : 7
Re:Project: Aluminum Water Cooling Case Monday, November 14, 2011 1:33 AM (permalink)
Slots for wire and tube routing were cut out of the top and bottom shelves.  I attempted to use a pattern router bit, but the deep cut forced the bit's bearing into the 3/8-inch thick particle board, ruining it.
So I switched to using a pattern to guide the base of the router.
The slots along the edge of the bottom shelf were cut in such a way to allow tubing and wiring to pass without significantly weakening the 1/2 x 1-inch u-channel.
Bottom shelf slots:
Top shelf slots:
Finally, two slots were also cut out of a portion of the "false" back:
#61
robhall86
Re:Project: Aluminum Water Cooling Case Monday, November 14, 2011 5:48 AM (permalink)
great job, loving the progress so far, can't wait to see the final.
CM Cosmos 1000
Evga X58 Classified 760 w/ i7 D0 @3.9ghz
samsung ULV 1600 24gb @ 1870
Evga GTX 470 SC+ @ 800/1600/1800
Caviar Black 640gb (Raid 0)
Corsair AX1200
Xonar D2x + AD700/M50sLE
#62
v1ral
Re:Project: Aluminum Water Cooling Case Wednesday, November 16, 2011 10:02 PM (permalink)
Any more updates?
#63
BigH3017
Re:Project: Aluminum Water Cooling Case Thursday, November 17, 2011 6:34 PM (permalink)
Moar please! amazing stuff
#64
muskie32
  • Location: I'd tell you a UDP joke but you might not get it
  • Ribbons : 23
Re:Project: Aluminum Water Cooling Case Thursday, November 17, 2011 7:34 PM (permalink)
Looking good!
#65
Varkon
Re:Project: Aluminum Water Cooling Case Friday, November 18, 2011 2:46 PM (permalink)
nice cant wait to see it finished
#66
Spotswood
  • Ribbons : 7
Re:Project: Aluminum Water Cooling Case Friday, November 18, 2011 9:16 PM (permalink)
The three pieces of "false" back were attached to the bottom shelf via three pieces of 1/2-inch angle and some socket cap screws.
#67
Spotswood
  • Ribbons : 7
Re:Project: Aluminum Water Cooling Case Wednesday, November 23, 2011 8:27 PM (permalink)
Up until now the front of the case has been held on with masking tape, but its now time to attach it securely.  I had originally planned on drilling through holes and bolting the front to the case, but there wasn't much room for my hands to hold onto a nut, so I increased the size of the through hole a bit and pressed-in some PEM nuts.
The front frame consists of 1x1 and 1/2x1 u-channels.
Button head bolts were used to attach the front to the case.
#68
Little Sister
  • Ribbons : 10
Re:Project: Aluminum Water Cooling Case Wednesday, November 23, 2011 11:32 PM (permalink)
very nice
INTEL I7 2600K  -  CORSAIR H100  -  EVGA Z68 FTW  -  CORSAIR DOMINATOR GT 2000MHZ 16GB  -  EVGA GTX 580 3GB SLI X3
WESTERN DIGITAL BLACK 1TB X2  -  CORSAIR FORCE GT 120GB X2  -  PLEXTOR BLU-RAY BURNER  -  CORSAIR AX1200
ENERMAX FULMO GT  -  WINDOWS 7 ULTIMATE X64
#69
Spotswood
  • Ribbons : 7
Re:Project: Aluminum Water Cooling Case Thursday, December 01, 2011 3:40 AM (permalink)
The side panels were cut via the help of a large makeshift square made from a small square clamped to a ruler.
The radiator ventilation cutouts were made with the help of a router template. Some bits of scrap aluminum were bolted to the underside to eliminate any errors with placing the template accurately on the sheets.
Determining where to make the cutouts was easily done via a dab of India ink on the head of a screw and some masking tape.  The panel was repeatedly pushed up against the inked bolt.
#70
Spotswood
  • Ribbons : 7
Re:Project: Aluminum Water Cooling Case Friday, December 02, 2011 5:39 AM (permalink)
In order to accurately drill the bolt holes to attach the perforated aluminum to the side panels, I fabricated a drill template from some left over flat bar stock and a drill bushing I had lying around the shop.
A couple of spacers was used to quickly and accurately place the jig on the work piece (to avoid having to measure/layout the location of the holes).
Some .063 perforated aluminum cut to size:
To accurately cut the rounded corners on the side panels a router jig was fab'd from a piece of the corner round used on the body of the case, 1-inch u-channel and a couple of 1-2-3 block hot glued to some particle board.  Two strips of Mylar from an old drum head was used to smooth out any irregularities.
Tah-dah!
post edited by Spotswood - Friday, December 02, 2011 5:50 AM
#71
knightsilver
  • Ribbons : 14
Re:Project: Aluminum Water Cooling Case Saturday, December 03, 2011 5:20 PM (permalink)
Nice skills.......
#72
Spotswood
  • Ribbons : 7
Re:Project: Aluminum Water Cooling Case Thursday, February 09, 2012 4:56 AM (permalink)
Another requirement for this case is a hidden door latching mechanism.
Look Ma!  No latches!
A length of .125x.75-inch flat bar was bolted to the bottom of the door to act as a lip that will hook into the u-channel along the bottom of the case, for example:
Along the top of the door, there is a piece of angle with three "hooks", which were routed out using a cobbled together router template.
A thick piece of flat bar was filed down to where it'll slide easily inside the u-channel along the top of the case.  To that three "posts" were bolted to it.  When slid forward, the posts will engage the hooks.
#73
w4ss4b3
  • Ribbons : 21
Re:Project: Aluminum Water Cooling Case Thursday, February 09, 2012 10:45 AM (permalink)
Man this is insanely sick! Loving the work man! keep it up
#74
uncle poop
Re:Project: Aluminum Water Cooling Case Thursday, February 09, 2012 1:08 PM (permalink)
i lvoe people with too much money and time on their hands... cool things like this happen...
#75
blood4guts
Re:Project: Aluminum Water Cooling Case Thursday, February 09, 2012 1:55 PM (permalink)
What is the color scheme going to be? Or do you not decide?
#76
Spotswood
  • Ribbons : 7
Re:Project: Aluminum Water Cooling Case Tuesday, April 17, 2012 2:41 AM (permalink)
A large area of the right side panel was cutout for a 16x15-inch acrylic window.
#77
CAxVIPER
Re:Project: Aluminum Water Cooling Case Tuesday, April 17, 2012 3:14 AM (permalink)
Wow this looks really good. I've been considering trying something like this just to have something to do. Planning any custom etch plexi for the windows if you have any?
#78
BigH3017
Re:Project: Aluminum Water Cooling Case Tuesday, April 17, 2012 3:17 AM (permalink)
Coming along nicely!
#79
nvidia3
Re:Project: Aluminum Water Cooling Case Tuesday, April 17, 2012 2:03 PM (permalink)
amazing work log
#80
Spotswood
  • Ribbons : 7
Re:Project: Aluminum Water Cooling Case Monday, May 07, 2012 3:12 AM (permalink)
I made a mistake, placing the false back too far into the case, which required having to re-fabricate the back sheet.  But I figured I could take advantage of the situation by improving the mounting of the motherboard tray, by fastening the tray to the false back with a 7/8-inch long spacer.
I don't remember if I already offered this tip before, but I try to reduce the wear and tear on my 1/2-inch flush cutting router bit by first rough cutting with a 3/16-inch spiral downward cutting bit.
#81
1MadGrunt
Re:Project: Aluminum Water Cooling Case Monday, May 07, 2012 3:26 AM (permalink)
Nice work on the fabrication. Looking forward to seeing final results.
#82
jeffgoatley
Re:Project: Aluminum Water Cooling Case Monday, May 07, 2012 1:21 PM (permalink)
Great work for sure!!! Can't wait to see this completed...+1 already!
Win 7 64-bit - Corsair Obsidian Series 800D with Extended Water Cooling Case - Intel Core I7 2700k @ 4.40GHz - Asus Maximus IV Extreme-Z - 16G's G.Skill DDR3-2133 11-11-11-13 1.6v - Corsair HX1000i 80+ Platinum  PSU - 2 EVGA GTX 780's in SLI with Hydro Copper-1 Quad & 1 Triple Rad with 2 Swiftech - MCP655 Pumps 1 Bitpower 150 Reservoir - 1 Bitpower 250 Reservoir - 1 Swiftech Apogee for CPU - 4 Intel SSD 320 Sata II 120Gb in Raid 0 - 3 Acer G235h Monitors - 1 Asus VG248QE Logitech G910 Keyboard - Logitech G502 Laser Mouse - Creative Sound Blaster Z & Sennheiser PC Headset 350 SE - 5.1 Panasonic A/V Receiver - Polk Audio Speakers & Sub Woofer
www.jeffgoatley.com/mymodrig
#83
Spotswood
  • Ribbons : 7
Re:Project: Aluminum Water Cooling Case Monday, May 28, 2012 3:31 AM (permalink)
A PSU mounting plate was routed out of a piece .10-inch thick aluminum sheet with the help of a custom template.
In order to accurately transfer the locations of the PSU mounting holes, threaded hole transfer punches (mcmaster.com part # 3385A31) were threaded into a PSU.
And then the PSU was carefully centered and pressed into the sheeting, with the end result being a perfect squarely mounted PSU.
#84
malVizio
  • Ribbons : 8
Re:Project: Aluminum Water Cooling Case Monday, May 28, 2012 3:55 AM (permalink)
amazing build 'till now...can't wait to see it done!
Case:Silverstone FT02
M.B.:EVGA DARK X79/PSU: Corsair HX1000
GPU:EVGA GTX980Ti SC /RAM:32GB DDR3 Corsair
CPU:Intel i7 3930K+Noctua NH-D14
FANS:3xSilverstone SP200mm
SSD/HDD:2xSamsung EVO 850 256/1xPNY 256gb/Seagate 500gb
MICE:Razer DA Elite/KB:Collermaster Rapid I/
HP:Shure SRH440/Logitech G633
Screen:Dell Ultrasharp 2711U
#85
knightsilver
  • Ribbons : 14
Re:Project: Aluminum Water Cooling Case Monday, May 28, 2012 3:58 AM (permalink)
Putting casters on that beast?
#86
Spotswood
  • Ribbons : 7
Re:Project: Aluminum Water Cooling Case Monday, June 04, 2012 3:06 AM (permalink)
The case itself weighs ~50 pounds, so casters are required.
Another router template was made to cutout the areas for the PSUs out of the back sheet.  A guide was clamped to the bottom of the template to keep the cutouts perfectly aligned along the bottom.
post edited by Spotswood - Monday, June 04, 2012 3:12 AM
#87
MVanden Berghe
Re:Project: Aluminum Water Cooling Case Monday, June 04, 2012 8:15 AM (permalink)
Amazing to see this develop...
Haf X Blue
Asus P8Z68 Deluxe Generation 3
I7-2600 OC 4.5GHZ
Raystorm CPU Block, XSPC 360 Rad (3 X AP-15 Fans)
Scythe Kaze Master PRO Fan Controller
16GB Vengeance Memory
SLI EVGA 680 GTX with EK Nickel Plated Water Blocks along with Backplate
SSD M4 128GB
SSD M4 256GB (game files)
WD 1TB Black (storage)
Razer Black Widow Keyboard
Razer Black Mamba Mouse
Dell 2408FWP Monitor
Kingwin LZG 1000
Windows 7 Ultimate
#88
Spotswood
  • Ribbons : 7
Re:Project: Aluminum Water Cooling Case Sunday, August 19, 2012 0:32 PM (permalink)
Turned out that I needed to cut one more slot out of the bottom shelf. But the last time I used my wooden "small slot" router template, I somehow managed to crush one edge, so I quickly cobbled together a new out of some left over t-slot extrusion.  I'm really loving using these t-slot extrusions to make router templates - fast and accurate!
Here's a teeth-shattering video of me cutting out the slot: http://youtu.be/-3V7PWJReus
#89
Spotswood
  • Ribbons : 7
Re:Project: Aluminum Water Cooling Case Monday, September 10, 2012 1:14 AM (permalink)
Performed the mind-numbing task of fastening the bottom and top sheets to the case frame via flat head socket cap screws.  Through and countersink holes were drilled into the sheet and transferred to the case frame via a self-centering counterbore drill bit.
Bottom sheet all fastened:
And top sheet all drilled out:
#90
