TheSunGod
I have recently built a gaming rig from all brand new parts (besides the GPU which is used, but perfectly functional).
Specs: Mobo: Gigabyte Z390 Aorus Master CPU: i9-9900k RAM: 32GB G.Skill Trident Z Neo 3600Mhz CL16 (2x16GB) f4-3600c16d-32gtznc GPU: EVGA RXT 2080Ti XC Ultra PSU: Seasonic Prime Platinum 850W Boot drive: Samsung 970 Evo Plus 1TB + second exact same drive
After a lot of troubleshooting, asking on forums etc the problem persisted: i am unable to get any signal from the video card when its in any of the PCIE slots, doesnt matter if its through HDMI or DP. I am unable to even get to BIOS, when the card is in there is completely no display at all, and also with the card plugged in (and BIOS settings at "Auto"), i dont get video via onboard, meaning the mobo detects the GPU and automatically disables the IGPU. During that time, the "VGA" LED on my mobo is lit up, meaning it sees that there is SOME problem, although the debug display shows "A0 (IDE Initialization is started)" code (might also be AD - which is "Issue Ready To Boot event for OS Boot"), and the same is displayed when I'm fine in windows via onboard or another GPU.
Everything runs just fine if i take the 2080Ti out of the PC and run it just from the IGPU, zero problems, instant boot, everything detected, even managed to OC the 9900k to stable 5.1Ghz, out of boredom.. The 2080Ti is fine, i used it for the past two months with my old rig (Z77 mobo and i7-2600k) and it was running perfectly okay, i also tested it in two different PCs (also using my PSU in those PCs, to eliminate the PSU as the problem) and it works just fine. I flashed card's bios to the newest one in my friends PC, didnt help. I also tested a 2070 and a 1060 in my new rig, boots fine with no issues, got instant video via DP. I tested the power cable, PSU, i tried if the card is seated in the PCIE slot correctly, nothing helped. I uptaded mobo's bios, no change. If i manually force the PC to use onboard via BIOS, i am able to get video with the GPU plugged in , but the card itself doesnt show up in BIOS, it doesnt show up in device manager, and if i try to install GeForce experience, it says i have no Nvidia GPU plugged it. All of that is quite weird because card's RGB is lit up, the fans are spinning and the backplate is getting warm when i touch it over the die. I also reassembled the thing outside of the case, i reseated the CPU to make sure it was fine, checked the inside of all PCIE slots, they look fine inside. I tried three different PSUs and different cables, to no effect.
Coming to the conclusion - i did a whole ton of troubleshooting, tried every single common fix that people suggested, nothing worked. The problem is still the same with zero change - everything runs fine, until i plug my 2080Ti in my system, then i get no video via any output.. I totally ran out of ideas, everything is fine by itself. The 2080Ti is fine and working in another rig. Mobo's PCIE slot is fine too, as it works perfectly fine with other GPUs plugged in. Also the monitor and cables are fine, im certain.
I hope someone can help me finally fix this without RMAing anything as i'm already very frustrated by the time waste on all of this.
Re: Problems with a fresh build using EVGA 2080Ti XC Ultra, unable to use the card in any
2019/11/27 18:00:24
UEFI issue by the sound of it ..... because the card works in other PCs & other GPUs work in that MB Very strange .... no idea Why the GPU & MB are Failing at BOOT to recognize each other Force IGPU or remove the 2080 Ti & Run DDU ... to cleanup the mess Secure BOOT turned On in BIOS ? CSM ? What GPU was Installed to the MB .... When you installed Windows ? Was Legacy OR UEFI selected when the OS was installed ? Might be time for a clean reinstall of Windows
bp7178
2019/11/27 20:42:55
Do you have another hard drive of some type you can install a fresh Windows 10 on to rule out any OS configuration problems?
Vlada011
- Ribbons : 11
2019/11/28 02:48:34
Maybe is really problem with UEFI installation... If that's problem you should follow guide how to install Windows 10 UEFI on USB Flash with Rufus
And later to follow procedure how to install Windows 10 UEFI on M.2, with CSM Disable, Delete Secure key,...
Nazarus
- Ribbons : 6
2019/11/28 03:57:19
I have an Aorus board myself. My issue ended up being the USB ports I was using for my keyboard and mouse when I booted up the first few times. It was weird. I kept moving them around and eventually everything booted up properly.
Associates: RQAORCJB8JNEFOB/Affiliate: YTOQRPH9OK
TheSunGod
2019/11/28 09:42:05
I dont think this is a Windows issue as I cannot even get to BIOS, I get totally zero video output through the GPU, while I think windows launches up fine (because of the debug code screen which shows the same codes when In in Windows and when I cant get any video with the card in). So the issues and lack of video start even sooner than actually booting up the OS. I will try all the stuff you guys suggested tomorrow though, as well as with the USB ports (it didnt work with everything unplugged either so...) and let you know if anything helped.
AHowes
- Ribbons : 27
2019/11/28 13:34:24
Try unplugging the power from the card.. the pcie power connections from both ends and reinsert them. Possibly they are not fully seated or a wire pushed out the backside of the connector.
Nazarus
- Ribbons : 6
2019/11/28 22:39:33
There is the chance that the cooler to the processor is to tight? I've seen memory have issues with things like not picking up memory in a slot, so I don't see why the bus to the PCI-e couldn't potentially be effected as well. Are you using a riser cable of any sort?
TheSunGod
2019/11/30 17:00:13
PCIE power connectors are fine, im certain about that.
I dont think i screwed the cooler too tight, its a Be Quiet Dark Rock Pro 4 which has special mounting brackets, would be hard to overscrew in those. I'm not using any cables, the system is sitting on an open-bench now, as barebones as it can get. I will try doing the UEFI thing now, maybe it will fix something?
TheSunGod
2019/12/05 13:40:37
Update on the topic: i tried literally everything, i talked to EVGA and Gigabyte support, i tried a lot of fixes and troubleshoots, yet nothing helped. Today, i finally managed to get in touch with the seller (he didnt have any in stock before), returned the card and exchanged it for a Zotac AMP (brand new one though, compared to the fact that the EVGA was used) and it gives me completely zero issues, runs smoothly while also maintaning lower temps and noise levels. For anyone reading this in the future and trying to solve similiar problem - just return the GPU and exchange it for another model (maybe even another piece of the same model might work just fine, i dont know). Nothing besides that was able to solve my issue, and it seems that the motherboard is perfectly fine.
Thank you everyone for attempting to help anyway, i really appreciate that <3
2019/12/09 08:24:56
