Problems with Changing the LED Color on my RTX 2070 Super
Ty101
2019/09/12 17:26:06 (permalink)
Having just installed my new RTX 2070 Super, I have been trying to change the color of the LED on the side of it to no avail. I have download Precision 1 from EVGA and it recognizes my card and however, the LED tab does not display the right card and the limited options it does give me does not have any effect on the card, even when I hit apply. This can be best observed in the image attached to this post.
How can I resolve this?
2 Replies Related Threads
    EVGATech_DanielM
    EVGA Tech Support
    Re: Problems with Changing the LED Color on my RTX 2070 Super 2019/09/12 19:09:24 (permalink)
    Which Super card did you purchase? There is a model with no LEDs on it.
    Hoggle
    Re: Problems with Changing the LED Color on my RTX 2070 Super 2019/09/12 21:58:40 (permalink)
    On the right side near the bottom of the X1 software do you notice the LED Sync button under HWM and Boost Lock? Try pulling that up and changing the RGB color to static then select the color you want to display. Sync might also already be open down by the clock and if it is synced it seems the LED option in X1 will not apply a change to the card.
