Power supply makes motherboard flicker
imSteven
2019/12/12 13:14:33 (permalink)
I have the EVGA 750W G3 Supernova PSU. When I turn on the power supply, and connect all the cables, it makes the motherboard or some part in there flicker with a bright light. Is this supposed to happen?
8 Replies Related Threads
    bob16314
    • Ribbons : 761
    Re: Power supply makes motherboard flicker 2019/12/12 18:12:07 (permalink)
    You're going to be asked, so I'll be the first..Exactly what/which light is flickering and what mobo do you have?
    Soooo...
    1. Exactly what/which light is flickering?
    2. Did you use ONLY the cables that came with the 750W G3 as you should have?
    3. It did NOT flicker before you installed the 750W G3?
    4. The only thing that SHOULD flicker is the HDD light when there's drive activity, and that is completely normal
    imSteven
    Re: Power supply makes motherboard flicker 2019/12/12 19:23:31 (permalink)
    MOBO : Z390 Aorus Pro Wifi
    Tbh, not sure what's flickering but it happens when I turn on the power supply and I guess the power connects to something inside which causes it. I only used the cables that came with the PSU, and did not flicker at all till power came through. I'm not sure where the HDD light is, but even if I have to computer turned off and my drives aren't running, I see the flicker once power flows from PSU to motherboard.
    wmmills
    • Ribbons : 40
    Re: Power supply makes motherboard flicker 2019/12/12 23:17:41 (permalink)
    imSteven
    Yeah, looks normal from what i looked up, you have RGB all over the mobo and the DIMM slots are all lit up too. Is it not running correctly or some type of user experience problem?
    https://www.gigabyte.com/Motherboard/Z390-AORUS-PRO-WIFI-rev-10#kf
    MOBO: EVGA x299 Dark, CPU: I9 10900X, RAM: Patriot Viper RGB 3600 32gb, SSD: Samsung 860 EVO 1TB, M2: Samsung 970 EVO+ 1TB, PSU: CoolerMaster M2 1500, CPU HSF: EVGA 240 CLC HSF~ P/P EK Furious Vardar, G-CARD:EVGA RTX3090 FTW3 Ultra Gaming w/Hybrid kit and Noctua IPPC 3000 P/P, CASE: LIAN-LI PC-V2010B w/ Window mod, OS: Windows 10 Pro 64bit, MON: Alienware AW3821DW
     New EVGA product? Register it NOW with this link:
    http://www.evga.com/register/default.asp?affiliatecode=4QFQRAMOII
     Help Our Vets From K-2!
    [link=https://strongholdfreedom
    imSteven
    Re: Power supply makes motherboard flicker 2019/12/13 11:41:21 (permalink)
    wmmills
    imSteven
    Everything seems to be running fine but the white light scares me as if it's some kind of spark and I'm not trying to fry any of the parts.
    • Ribbons : 122
    Re: Power supply makes motherboard flicker 2019/12/13 12:27:53 (permalink)
    Look @ MB then Look in Manual - to see what the LED is indicating
    bob16314
    • Ribbons : 761
    Re: Power supply makes motherboard flicker 2019/12/13 17:16:36 (permalink)
    Sounds like a Standby Power LED that means the mobo is getting +5V Standby voltage and is ready for operation, but that's usually a steady light and not blinking or flickering..The mobo manual is less-than-informative about the onboard LEDs.
    Contact Gigabyte Support..See the first post in this thread over at the Gigabyte Forums..Or use the eSupport inquiry.
    CraptacularOne
    • Ribbons : 222
    Re: Power supply makes motherboard flicker 2019/12/13 18:26:42 (permalink)
    More important question: Why are you continually turning the power switch on PSU off? There is no need to do this at all. When you power the system down there is no point at all in also switching the power supply to the "off" position.
    Intel i9 14900K ...............................Ryzen 9 7950X3D
    MSI RTX 4090 Gaming Trio................ASRock Phantom RX 7900 XTX
    Samsung Odyssey G9.......................PiMax 5K Super/Meta Quest 3
    ASUS ROG Strix Z690-F Gaming........ASUS TUF Gaming X670E Plus WiFi
    64GB G.Skill Trident Z5 6800Mhz.......64GB Kingston Fury RGB 6000Mhz
    MSI MPG A1000G 1000w..................EVGA G3 SuperNova 1000w
    imSteven
    Re: Power supply makes motherboard flicker 2019/12/15 17:51:16 (permalink)
    CraptacularOne
    You have a point. I do not continually do this but I did it because I saw a flicker of white light the first time and so I had to further test this theory since I had just built the pc.
    bob16314
    Contact Gigabyte Support..See the first post in over at the ..Or use the .
    Thanks for the help, Bob. I hope it's just an LED light of some sort due to the fact my computer seems to be working fine for the time being.
