phaseshift
I've got an EVGA Supernova g2 850w, will that be enough for both these beast? The rest of my system is below: - 4770k - Gigabyte Z87X-OC - 8gb Dominator Ram - 250gb SSD - 2x 6tb HDD - 2x GTX980ti
iycanthropy
Re: Power supply for 980ti SLI
Sunday, June 07, 2015 4:59 PM
Definitely, I'm going to be running one 980Ti on a 650w Corsair Power supply. I'm certain 850W will be fine.
Intel Xeon X5650 @4Ghz||EVGA X58 FTW3||24GB Crucial DDR3 Tactical Tracer RAM 1866MHZ||EVGA GTX 980 Ti ACX 2.0+||Asus Xonar DX2||Samsung 840Pro 250GB||1TB/2TB Storage||Corsair TX650W||Corsair 800D||Corsair AIO H60||6x120mm Enermax Everast Advance Fans||2x 140mm Enermax Advance||2x Antec Spotcool 100||Pioneer BDR-205||Windows 8.1Pro x64||
Vlada011
- Ribbons : 11
Sunday, June 07, 2015 5:05 PM
980Ti SLI will work on 850G2 only you will not have space and better leave fan on constantly.
bsmegreg
- Ribbons : 6
Sunday, June 07, 2015 5:18 PM
I would be somewhat concerned as the card uses up to 420W according to this http://www.tomshardware.c...gtx-980-ti,4164-7.htmlBut I would be skeptical of that and would advise you to just try it out because assuming that that number is wrong, then you would only use about 85-90% of your PSU's power rating which is fairly high as its reccomended to only use 80%. So using 90% could cause the PSU to fail within 6-24months at which point you can replace it.
phaseshift
Sunday, June 07, 2015 5:27 PM
bsmegreg I would be somewhat concerned as the card uses up to 420W according to this http://www.tomshardware.c...gtx-980-ti,4164-7.html
That's what I was thinking, I'm probably going to return it and get the 1000w
DeludedRaven
Sunday, June 07, 2015 5:57 PM
Get the evga platinum plus 1k watt psu.
phaseshift
Sunday, June 07, 2015 8:58 PM
DeludedRaven Get the evga platinum plus 1k watt psu.
Is that the p2?
RainStryke
The Advocate
- Ribbons : 60
Sunday, June 07, 2015 9:36 PM
Intel i9 10900KMSI MEG Z490 ACEASUS TUF RTX 309032GB G.Skill Trident Z Royal 4000MHz CL18SuperFlower Platinum SE 1200wSamsung EVO 970 1TB and Crucial P5 1TBCougar Vortex CF-V12HPB x9
DeludedRaven
Yup! The P2, what I'm running! And really dude? I don't know SLI in 3 way seems like you'd need a 1600w PSU. I mean I have the 1k P2 and am going to be running SLI 980ti's and am worried I'm pushing the limits and debating going for the 1200watt.
post edited by DeludedRaven - Sunday, June 07, 2015 9:46 PM
trek554
Sunday, June 07, 2015 9:43 PM
RainStryke You could power that system with a solid 650w PSU. The GTX 980Ti doesn't use up that much power. Review: http://www.guru3d.com/articles-pages/nvidia-geforce-gtx-980-ti-review,8.html The 850w is almost enough for tri SLI GTX 980Ti's.
um that is for the cards only in that chart. you would be a damn fool trying to run 980 TI sli with a 650 watt psu. two oced 980 Ti cards alone can pull over 550 watts. throw in an oced cpu and the rest of components and even a 750 watt psu would get close to tapped out.
Win 10 Pro | i9 9900KF | MSI Gaming Pro Carbon AC | FE RTX 3070 | G.SKILL 32GB DDR4 3200 CL14 | Samsung Evo 860 4TB SSD | Phanteks P500A | Seasonic FOCUS GX-1000| Sound Blaster Zx
bsmegreg
- Ribbons : 6
Sunday, June 07, 2015 10:00 PM
If you want to try it and let us know how it works after the PSU causes an electrical fire and burns down your house, that would be fine. It may not be that bad, but by god that PSU is going to fail when you load windows gadgets.
DeludedRaven
Sunday, June 07, 2015 10:02 PM
bsmegreg
You think the 1000w P2 I suggested will work?
RainStryke
The Advocate
- Ribbons : 60
Sunday, June 07, 2015 10:13 PM
trek554
You can talk about theory's all day. If you want to recommend people get a 1600w PSU to be ready for overclocking and having 20 hard drives, go ahead. But it's ridiculous, that reviewer uses a i7 5960X which uses 1.375v-1.425v to get his operating speed. That's twice the amount of power of a i7 4770K. He could easily get away with a gold/platinum certified 650w PSU on a GTX 980Ti set-up.
Sheepona
Sunday, June 07, 2015 10:19 PM
That 420w, is how much is needed not how much it uses. for instance I work with equipment that requires 30Kw, however the systems actual usage is only about 21Kw.
RainStryke
The Advocate
- Ribbons : 60
Sunday, June 07, 2015 10:24 PM
Sheepona That 420w, is how much is needed not how much it uses. for instance I work with equipment that requires 30Kw, however the systems actual usage is only about 21Kw.
That's when you use large scale UPS's and you have to have power for reserve, the higher output is for redundancy for zero down time. I also work in a place like that, except the numbers are much higher. You are also talking about much higher voltages than 12v on a ATX PSU lol... They are nowhere near similar.
ssj92
- Ribbons : 6
Sunday, June 07, 2015 10:27 PM
I ran dual cards (250w tdp each, titan x) and a 5820k @ 4.5Ghz on a 850w before without issues. I think 850w is just right for two 250w tdp cards + a overclocked cpu. 1,000watts would allow more headroom. For 3-way you'd want 1200watts and for 4-way 1500-1600watts. Single 135-195w tdp gpu + overclocked cpu: 550w at least, 650w perfect Single 225-250w tdp gpu + overclocked cpu: 650w at least, 750w perfect Dual 135-195w tdp gpu + overclocked cpu: 750w at least, 850w perfect Dual 225-250w tdp gpu + overclocked cpu: 850w at least, 1000w perfect Triple 135-195w tdp gpu + overclocked cpu: 950w at least, 1200w perfect Triple 225-250w tdp gpu + overclocked cpu: 1200w at least, 1300-1600w perfect Quad 135-195w tdp gpu + overclocked cpu: 1200w at least, 1500-1600w perfect Quad 225-250w tdp gpu + overclocked cpu: 1500w at least, 1600w perfect That's how I see it at least.
Alienware Area-51M Laptop: Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080Alienware Aurora R4 Desktop: Intel Core i9 10980XE | nVidia Titan VAlienware M18xR2 Laptop: Intel Core i7 3920XM @ 4.7Ghz | nVidia Quadro RTX 3000Alienware X14 Laptop: Intel Core i7 12700H | nVidia GeForce RTX 3060
Sheepona
Same concept just a lower scale
trawetSluaP
Sunday, June 07, 2015 10:31 PM
Max power draw according to Nvidia is 250W per card, so 500W for both. The 850W you've got is going to be fine.
Case: Phanteks Enthoo Elite CPU: i9-7900X Motherboard: Rampage VI Extreme RAM: Corsair Dominator Platinum 32GB 3200 MHz GPU: RTX 2080 FE Storage: 960 Pro 512GB, 2 x 840 Evo 250GB PSU: EVGA SuperNOVA 1200 P2 Monitor: HP Omen 27i, MX27AW Custom Watercooling LoopAquaero 6 XT
trek554
Sunday, June 07, 2015 10:56 PM
RainStryke
trek554
perhaps you should learn how to read a little closer. the cpu used in that review is irrelevant and had nothing to do with what I said. that chart is only showing power consumption for the cards. its a FACT that an oced 980 ti can use 275 watts so its simple math to say 550 watts is very possible for two of them if under full load. an oced 4770k can easily use 100 watts or more. that is potentially 650 REAL watts or more right there for oced 980 ti SLI and oced 4770k and I did not even factor in the rest of the components. so NO, a 650 watt psu is NOT enough for an oced 980 ti SLI system.
post edited by trek554 - Sunday, June 07, 2015 10:58 PM
DeludedRaven
Better to be over thasn under!
RainStryke
The Advocate
- Ribbons : 60
Sunday, June 07, 2015 11:05 PM
trek554
RainStryke
trek554
Talking about reading a little closer. I never said anything about overclocking in my original post. Yeah... 650w is enough unless you want to overclock.
jsarver101
Sunday, June 07, 2015 11:07 PM
If it helps I ran 780 sli with oc 3770k with 2 externals and 4 internals along with all other normal accessories without issue for theast two years.
Only reason I updated psu was because I'm now running a 5930k oc which can draw about 400 watts on its own.
 Enthoo Elite - Asus Rampage - 9900x 4.6 @ 1.26v - 32GB Gskill Trident RGB 3200mhz - RTX 2080Ti FTW3 - Corsair 1500i - Samsung 960 Evo 1Tb NVMe - Samsung 840 Pro 512 SSD - Samsung 850 Pro 1Tb SSD - Samsung 840 Evo 1Tb SSD- Corsair H110i - ROG Swift @ 1440p w/ Gsync x3
DeludedRaven
Sunday, June 07, 2015 11:11 PM
jsarver101 If it helps I ran 780 sli with oc 3770k with 2 externals and 4 internals along with all other normal accessories without issue for theast two years.
You're going to really regret it when those SSDs take a crap and you lose all that data!
jsarver101
Sunday, June 07, 2015 11:36 PM
Lol! You don't know much about ssd life span do ya? Btw my build is for games. Nothing that matters. I do real work on my iMac/MacBook Pro.
Thanks for your concern.
O and also my wattage was monitored by corsair link. Never went over the 500 or so mark on previous setup I mentioned.
DeludedRaven
Sunday, June 07, 2015 11:47 PM
jsarver101 Lol! You don't know much about ssd life span do ya? Btw my build is for games. Nothing that matters. I do real work on my iMac/MacBook Pro.
I do sadly. I've had 2 of the EVOs both of them failed on me. Everything gone. Now I smartly use my SSD for boot. Though I suppose you're probably running yours in some kind of RAID config?
jsarver101
Sunday, June 07, 2015 11:54 PM
The rog raidr pcie ssd is in raid as a boot drive only. All others are seperate. They each hold their own game launcher library ie steam, origin, uplay ect.
Both the evo and 840 pro I've had now for over 2 years without issue.
trek554
Monday, June 08, 2015 0:10 PM
RainStryke
trek554
RainStryke
trek554
nice try but you are the one that quoted and replied to me when I have said overclocking right from the beginning. and even at stock speeds a 650 watt PSU is going to be pushed to over 90-95% at times. in fact is someone was silly enough to do a full system bench it would easily exceed 650 watts.
RainStryke
The Advocate
- Ribbons : 60
Monday, June 08, 2015 0:26 PM
trek554
RainStryke
trek554
RainStryke
trek554
Hmm... post #8 is my OP that you quoted. You took my post out of context, started speaking about overclocking and saying I needed to learn how to read. I mentioned your theorizing as a point of taking my post out of context. Also, a i7 4770K system might keep a 650w PSU around 75% load under normal conditions. Just because you overclock and run benchmarks doesn't mean the mass majority of builders do.
post edited by RainStryke - Monday, June 08, 2015 0:35 PM
trek554
Monday, June 08, 2015 0:38 PM
RainStryke
trek554
RainStryke
trek554
RainStryke
trek554
are we going to do this forever. I only quoted you to say that was only the power consumption of the cards. nearly anyone with a 4770k and gtx 980 ti will be overclocking so I mentioned that. you then bizarrely quote me and talk about the cpu in that review which again is irrelevant as I just told you those power consumption numbers were for cards only. and then you go on to say a 650 watt psu is sufficient when in fact its really not especially if overclocking.
jsarver101
Monday, June 08, 2015 0:42 PM
