DeludedRaven
Re: Power supply for 980ti SLI
2015/06/07 17:55:59
Guys chill. Just answer his fookin question. Is he good with an 825? Or should he jump up to the 1k just to play it safe? I personally think he should jump up to 1k.
jsarver101
2015/06/07 17:58:50
I e already answered this using real world numbers that I have seen with a system that uses almost identical tdp. His 800 watts is fine.
If you have money burning your pocket and you wanna flex epeen (like me sometimes lol) then upgrade.
 Enthoo Elite - Asus Rampage - 9900x 4.6 @ 1.26v - 32GB Gskill Trident RGB 3200mhz - RTX 2080Ti FTW3 - Corsair 1500i - Samsung 960 Evo 1Tb NVMe - Samsung 840 Pro 512 SSD - Samsung 850 Pro 1Tb SSD - Samsung 840 Evo 1Tb SSD- Corsair H110i - ROG Swift @ 1440p w/ Gsync x3
trek554
2015/06/07 17:59:26
DeludedRaven Guys chill. Just answer his fookin question. Is he good with an 825? Or should he jump up to the 1k just to play it safe? I personally think he should jump up to 1k.
he is fine with an 850 watt psu if its a very high quality unit.
Win 10 Pro | i9 9900KF | MSI Gaming Pro Carbon AC | FE RTX 3070 | G.SKILL 32GB DDR4 3200 CL14 | Samsung Evo 860 4TB SSD | Phanteks P500A | Seasonic FOCUS GX-1000| Sound Blaster Zx
DeludedRaven
2015/06/07 18:02:24
Ha-ha there we go! SLI 980s is going to be beast.
bsmegreg
- Ribbons : 6
2015/06/07 18:58:41
As they say, don't fix it unless it's broken. I kind of doubt the 850W would fail, but it's definitely possible and if it does, then you can fix it. I doubt if it did fail that it would be violent and you would likely just come home one day and it might just kind of not start up.
PvtBlackdog
2015/06/07 19:09:48
General rule of thumb is to buy the best PSU you can afford!
RainStryke
The Advocate
- Ribbons : 60
2015/06/07 19:29:40
trek554
RainStryke
trek554
RainStryke
trek554
RainStryke
trek554
RainStryke You could power that system with a solid 650w PSU. The GTX 980Ti doesn't use up that much power. Review: http://www.guru3d.com/articles-pages/nvidia-geforce-gtx-980-ti-review,8.html The 850w is almost enough for tri SLI GTX 980Ti's.
um that is for the cards only in that chart. you would be a damn fool trying to run 980 TI sli with a 650 watt psu. two oced 980 Ti cards alone can pull over 550 watts. throw in an oced cpu and the rest of components and even a 750 watt psu would get close to tapped out.
You can talk about theory's all day. If you want to recommend people get a 1600w PSU to be ready for overclocking and having 20 hard drives, go ahead. But it's ridiculous, that reviewer uses a i7 5960X which uses 1.375v-1.425v to get his operating speed. That's twice the amount of power of a i7 4770K. He could easily get away with a gold/platinum certified 650w PSU on a GTX 980Ti set-up.
perhaps you should learn how to read a little closer. the cpu used in that review is irrelevant and had nothing to do with what I said. that chart is only showing power consumption for the cards. its a FACT that an oced 980 ti can use 275 watts so its simple math to say 550 watts is very possible for two of them if under full load. an oced 4770k can easily use 100 watts or more. that is potentially 650 REAL watts or more right there for oced 980 ti SLI and oced 4770k and I did not even factor in the rest of the components. so NO, a 650 watt psu is NOT enough for an oced 980 ti SLI system.
Talking about reading a little closer. I never said anything about overclocking in my original post. Yeah... 650w is enough unless you want to overclock.
nice try but you are the one that quoted and replied to me when I have said overclocking right from the beginning. and even at stock speeds a 650 watt PSU is going to be pushed to over 90-95% at times. in fact is someone was silly enough to do a full system bench it would easily exceed 650 watts.
Hmm... post #8 is my OP that you quoted. You took my post out of context, started speaking about overclocking and saying I needed to learn how to read. I mentioned your theorizing as a point of taking my post out of context.
are we going to do this forever. I only quoted you to say that was only the power consumption of the cards. nearly anyone with a 4770k and gtx 980 ti will be overclocking so I mentioned that. you then bizarrely quote me and talk about the cpu in that review which again is irrelevant as I just told you those power consumption numbers were for cards only. and then you go on to say a 650 watt psu is sufficient when in fact its really not especially if overclocking.
The OP isn't running dual power supplies or a dedicated power supply for the video card, so it's not bizarre to talk about the system as a whole and it's not irrelevant information because it wasn't just for the cards only. In the Guru3D link I posted it shows the full system usage under a realistic stress test.
- System in IDLE = 92 Watts
- System Wattage with GPU in FULL Stress = 332 Watts
- Difference (GPU load) = 240 Watts
- Add average IDLE wattage ~10 Watts
- Subjective obtained GPU power consumption = ~ 250 Watts
http://www.guru3d.com/art...x-980-ti-review,8.html They show the specifications of the system they are using: http://www.guru3d.com/art..._980_ti_review,12.html Add 250w to that system wattage at full stress and you've got 582w on a X99 system that uses a i7 5960X which has twice as many cores as a i7 4770K and uses twice as much power. So, on a i7 4770K or even a i7 4790K system while playing the latest DX11 games you are looking at a full system load of around 480w load. Techpowerup mentions a possible power usage of 277w when running a benchmark test on FurMark http://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_980_Ti/29.html Then they mention that in game power usage is at 211w from the graphics card alone while playing Metro 2033: Last Light. Personally, I ran a Corsair HX750 with a pair of R9 290X's that show 310w usage per card when using FurMark and that PSU is still running strong today. The OP's 850w PSU is very solid: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story4&reid=377 Even under a 835w load it doesn't even break a sweat... Power efficiency drops to 86.7% but the power regulation stays strong. He has absolutely nothing to worry about unless he's running a bunch of extra things like 6 HDD's, 8 case fans and a water pump.
post edited by RainStryke - 2015/06/07 20:26:55
Intel i9 10900KMSI MEG Z490 ACEASUS TUF RTX 309032GB G.Skill Trident Z Royal 4000MHz CL18SuperFlower Platinum SE 1200wSamsung EVO 970 1TB and Crucial P5 1TBCougar Vortex CF-V12HPB x9
bsmegreg
- Ribbons : 6
2015/06/07 20:04:04
You should expect to see about 200W of power draw for the MoBo+CPU+HDD/SSD. All that together would be 750W which is fine for an 850W, but it is deffinitly borderline and going on to PSU Death Valley.
RainStryke
The Advocate
- Ribbons : 60
2015/06/07 20:29:20
bsmegreg You should expect to see about 200W of power draw for the MoBo+CPU+HDD/SSD. All that together would be 750W which is fine for an 850W, but it is deffinitly borderline and going on to PSU Death Valley.
This isn't 2008. PSU's today are built to operate at or near their rated wattage. Just look at the JonnyGuru review I linked on his PSU. Capacitor ripple is only at 15mV under full load.
bsmegreg
- Ribbons : 6
2015/06/07 20:35:38
It won't live its full life if you use 95% of its wattage for hours out of the day.
RainStryke
The Advocate
- Ribbons : 60
2015/06/07 20:44:55
bsmegreg It won't live its full life if you use 95% of its wattage for hours out of the day.
No, that's not true at all. The thing that kills PSU's is heat. One of the main things in a PSU that causes heat is bad power regulation and high ripple levels. The majority of these newer gold certified PSU's don't have that problem.
Methodical2
2015/06/07 23:51:10
trawetSluaP Max power draw according to Nvidia is 250W per card, so 500W for both. The 850W you've got is going to be fine.
Yep, I agree. Some just like to be on the safe side though and get a much larger PSU (sometimes/most time too large) although it may not be as efficient. OP check out the video below, it may help to relieve your mind. I'd go with the 850 if it were me and think you'd be ok. Here you go: https://www.youtube.com/watch?v=LiWThqgFfI4
post edited by Methodical2 - 2015/06/08 00:09:03
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic" BlackECase: Caselab Magnum STH10 MB: Asus X670E Hero CPU: Ryzen 9 7950x (EK-Quantum Vector²) GPU: Asus 4090 TUF OC (EK-Quantum Vector²) Memory: G.Skill Trident Z5 Neo DDR5 (6000 @64gb) Storage: WD M.2 NVMe 2TB (OS), 2x4TB (Photography), 1TB (Games) Fan Controllers: Aquacomputer Aquaero 6 XT & Octo PSU: EVGA 1200 P2 Monitor: LG 48" UltraGear OLED 4k
Systom
2015/06/08 02:50:54
I've been wondering the same thing, I don't have much experience with this stuff in particular (late bloomer,) but upon internet research, it apparently should be fine, and it's my end result goal, SLI 980 TI Hybrids, same PSU as well. Time'll tell, whenever I'm able to get my hands on a second hybrid anyway.
CPU & GPU: AMD Ryzen 9 5900X / Nvidia RTX 3080 FE (Both EK Water Blocks)MB & PSU: ROG Crosshair VIII Formula X570 / EVGA T2 Titanium 1000wSSD & RAM: Samsung 980 Pro 1TB & Western Digital Black SN850 1TB / G.Skill Trident Z Neo C14 3600MHz 4x8GB (32GB) Case & Fans: Lian Li O11 Dynamic / x9 EK-Vardar X3MRads: Black Ice Nemesis 360GTX 360mm x 54mm / Magicool 360S G2 Ultra 360mm x 45mm
bsmegreg
- Ribbons : 6
2015/06/08 06:21:45
You need 55+ amps on the 12v+ rail.
SlappyFish
2015/10/09 09:53:03
Hey guys! I just read this thread for myself as I had the same question. It appears that the real ANSWER is a 980ti SLI rig will draw 550w at load during gaming. Here is the pudding/proof: I just bought an eVGA G2 850w. Yeaaaa!
post edited by SlappyFish - 2015/10/09 10:03:02
Squall_Rinoa86
- Ribbons : 5
2015/10/09 22:54:15
Personally? Id say go a 1K to play it safe. I went with the 1300 G2 personally for my rig that's holding down 2 970's just because I would rather have over, than under.
Realistically speaking you can run 980 Ti's fine on a 850W PSU, tho id never personally recommend it. Better safe than sorry.
  PSU: EVGA SuperNOVA 1300 G2 My Affiliate Code: AN1FW0VMG6
toyking22
2015/10/10 04:30:21
i run a corsair hx 850 (gold) with not one issue at all, cpu and gpus are over clocked
Cpu= I7-9700k Cpu cooler= Nzxt Kraken x62 GPU= Evga Hybrid 2080 ti Motherboard= Asus Prime Z390 a (dont recommend) Ram= G.SKILL TridentZ RGB Series 16GBSsd/Hdd Samsung 970 pro 2T / Intel 660 1t Monitor= Gigabyte M28U 144Hz 28" 4K Power Supply= EVGA SuperNOVA 850 PQ
Mekhed
2015/10/10 04:45:21
toyking22 i run a corsair hx 850 (gold) with not one issue at all, cpu and gpus are over clocked
Hi toyking22 How many watts is your system pulling folding those 980ti's?
 "Kaos" ASUS RAMPAGE V EXTREME | Intel Core i7-5930K | Corsair H110i GTX | 2x 1080TI Hybrid & 1080 Hybrid | HyperX 32GB 3000 | Supernova 1200 | Corsair 780T"BigDawg" Asus Maximus VI Formula | i7-4790k | Corsair H100i | 2x RTX 2080 Ti FTW3 Ultra | Mushkin Redline 16GB 2400 | Supernova 1300 | Antec 1200
DirtySouthWookie
2015/10/10 05:18:34
My SLI reference cards pull about 900w from the wall with the entire system being measured at 80%+ load. I use a 1200w to be safe.
Zuhl3156
- Ribbons : 34
2015/10/10 05:30:43
Mekhed
I don't know if this helps you or not but my twin 980 board setup in my Z97 i7-4790k build draws 541w from the outlet when Folding using Kill-A-Watt similar to the above post.
20219348762341
2015/10/10 05:46:26
Unless budget is big factor than that obviously it's understandable but if that's not the case, why some people like to run their systems to be on PSU that is so close to its threshold. Whiter today's PSUs are highly efficient or not it bound to happen that you pushing your PSU to its stressful limits that just a matter of time its asking for help as it cant keep up, and if it doesn't get it .. well you might be replacing your PSU or other components sooner or later.
post edited by AWK16 - 2015/10/10 05:50:06
Mekhed
2015/10/10 06:44:40
Zuhl3156
Mekhed
I was just curious. ...my system with a pair of 780tis pulled a little over 700 watts and scored abut 540k to 580k ppd....pulled those in favor of a pair of 970s folding a little over 600k ppd and using about 420 watts. Was curious how close to the 90% of the 850 he was getting. My guess would be he has plenty of room there.
post edited by Mekhed - 2015/10/10 08:59:09
Mekhed
2015/10/10 06:44:40
Zuhl3156
Mekhed
I was just curious. ...my system with a pair of 780tis pulled a little over 700 watts and scored abut 540k to 580k ppd....pulled those in favor of a pair of 970s folding a little over 600 ppd and using about 420 watts. Was curious how close to the 90% of the 850 he was getting. My guess would be he has plenty of room there.
Mekhed
2015/10/10 06:46:42
Sorry....my phone seems to want to double post occasionally
Zuhl3156
- Ribbons : 34
2015/10/10 06:53:11
Mekhed
I'm always curious about my power consumption. It's been a while since I used my Kill-A-Watt but I routed my PC through it for my mandatory energy audit by my electric company. My PSU is Platinum rated and my understanding is that a PSU is most efficient at 50% of its rated output so I should be at that golden sweet spot for efficiency.
Mekhed
2015/10/10 07:51:04
My understanding is psu's were designed to be most efficient at 80% and you didn't want your pc to pull more than 90% of what the psu is designed to provide. I always buy quality psus cause I don't want ever to have to trouble shoot a marginal psu. Solid clean power efficiency is most important to me. It's why I upgraded to maxwell from that power hog kepler. Don't like $300+ power bills. If energy was free I'd fold 25 hours a day
Zuhl3156
- Ribbons : 34
2015/10/10 08:02:29
I think your PSU size should tailored so that your minimum amount of draw falls into 40% of its rated output and your maximum draw around 70%. I think that would be the ideal choice when making your final decision.
Mekhed
2015/10/10 08:37:29
Thank you very much Zuhl.....I'm kinda into overkill anyways...currently my 1200 p2 doesn't seem to make any heat and is silent so I know it's not working hard at all but my future upgrade plans will put a strain on it
Crimson AL
2015/10/10 12:19:26
I measured mine at the plug at with 2 980 SC Hybrids in SLI oc'd as far as they'd go and still be stable and an OC'd 4970k and it only drew like 774 or so. That is oc'd to the max which isn't an everyday use so it'd be fine but personally I'd like a little more headroom so I went with the EVGA 1200 PSU. I'm actually running 3 980 ti SC hybrids on that same 1200 PSU at the moment. I have a 1600 I bought with that 50% off thing EVGA had just because but haven't used it yet.
post edited by Crimson AL - 2015/10/10 12:22:40
- Ribbons : 115
2015/10/10 12:44:39
Between 850-1000w will be fine.
