Re: Power on pin - PSU side on 750P2
2021/02/03 20:09:16
I don't own the PSU, so it is impossible for me to answer. But you having it physically in front of you, it's nothing that a multimeter or a AA battery, a bulb, and a piece of wire can't answer.
Just do a continuity check of each of the pins you know are the correct pins, and see where they connect on the PSU end of the cable.
