AnsweredPower cables interchangeable?
barryzee
2024/08/02 13:21:44 (permalink)
So, I own two EVGA power supplies for my 2 desktops; 1 Supernova 750GT and 1 Supernova 850GXC. Are the cables that came with the power supplies interchangeable between the 2?
EVGA_JaysonC
RMA Management
Re: Power cables interchangeable? 2024/08/02 13:30:37 (permalink) ☼ Best Answerby Cool GTX 2024/08/03 11:00:45
barryzee
Hello,
Thanks for reaching out. The 750 GT and 850 XC models have nearly similar cables.
The GT line does have a different 24 pin MB cable that is pinned different than that of the XC.  We would recommend using the MB cables that come with each unit to their respective models to ensure compatibility.
Regards,
-Jayson- EVGA USA RMA Dept.
Reddit - u/EVGA_JaysonC   Twitter/X - @evga_jaysonc - email:support@evga.com
