Re: Power Supply for a Vostro 3910?
2024/07/30 08:27:00
I would just buy the Dell upgrade PSU. Dell likes to use non-standard sizes and connectors, and by the time you are done hacking up your PC and cutting and splicing wires, you may wish you just bought the one which fits, works, and appears proper.
How much is 'very expensive'? I saw some options which didn't seem unreasonably-priced. Maybe I was looking at the wrong part number or something.
Poor planning on your part. Dell knows what they are doing.
