MIULER
The present I greet you, and asking for your great help Buy in my country a GeForce GTX 460 2 WIN model graphics card Which already install it but when loading the driver from pc Only recognizes me 2 of 3 monitors that I have available to install And as I understand the characteristics of this model Should work normally and easily with 3 monitors connected in HDMI So I ask your technical help to see what is happening What do I do or how do I connect it or do I need something special to make it work Hoping for your great help and collaboration as soon as possible I thank you PROBLEM WITH GRAPHIC CARD GeForce GTX 460 2 Win
Sres of the forum I ask for your great help as I tell you Just give me image of 2 of my 3 monitors And as explained this model works with up to 4 monitors 3 HDMI and a MINI DVI I ask of your great help to all here I am new I hope of your collaboration Already probe HDMI cables and converters to DVI and all are in perfect condition Also change the monitor for another q gives image and is perfect I think it is some driver or current in the card Here I leave my team's reference forum
MIULER
Re: PROBLEM WITH GRAPHIC CARD GeForce GTX 460 2 Win HELP
2017/03/20 21:47:52
Buenas noches un saludos a todos L3s oído de su gran ayuda a, solventar este inconveniente con mi tarjeta necesito expandir mi imagen a 3 o 4 monitores según las especificaciones técnicas y no lo e podido lograr agradecer de su ayuda a todos los expertos acq en el foro q sepan como hacerlo muchas gracias
2017/03/20 22:21:56
MIULER
2017/03/20 23:26:58
Muchas gracias amigo Por tu respuesta Pero necesito algo más q eso será mucho pedir algo q me especifique mejor en este modelo de de tarjeta como lograr reconocer los 3 monitores o los 4 ya q solo me reconoce 2 monitores muchas gracias Espero no molestar en el foro Se q soy nuevo trato de entre las traduccion de las normas de acá Disculpen si molesto
MIULER
2017/03/21 12:14:51
Thank you very much friend For your answer But I need something more q THAT will be much Ask for something that specifies me better In this model of Card How to achieve v Recognize the 3 monitors or 4 and that alone I recognize 2 monitors thank you very much I hope not to disturb In the forum I know I'm a new deal between the translations of the Norms here Sorry if i upset
2017/03/21 15:05:47
☄ Helpfulby MIULER 2017/03/21 19:15:54
We can work around the language barrier This is mostly a volunteer support group we try to help everyone Which two ports work ? Will any two work ? You have 3-DVI-I ports & 1-HDMI post
2017/03/21 15:15:45
☄ Helpfulby MIULER 2017/03/21 19:16:02
What OS are you using --- Microsoft Windows 7 ? What Nvidia Driver are you using ? What happens when you do these steps ? 1) Open the NVIDIA Control Panel - pop-up menu when you right-click on the desktop 2) Under the Display category, select "Set up Multiple Displays" 3) Check the box next to the inactive display you wish to activate as a secondary display and click apply 4) If your display is not shown, click "My display is not shown..." to force detection
MIULER
2017/03/21 17:09:09
[<font][<font][<font] [<font] Buenas noches, muchas gracias por su ayuda. [<font][<font][<font] hijo [<font] Sólo Los Dos Puertos DVI Juntas que estan en la parter inferior de la imagen q me Muestras amigo [<font][<font][<Font] [<font] Y sólo en el panel me muestra la figura 2 y la figura debería dejar que el panel de la figura 3, como se me ha informado
post edited by MIULER - 2017/03/21 17:19:46
MIULER
2017/03/21 17:11:15
I am using window 10 pro 64-bit Driver used 378.92-desktop-win10-64bit-international-whql I give it on my screen is not displayed and nothing is not detected nothing
2017/03/22 06:46:24
☄ Helpfulby MIULER 2017/03/23 16:34:54
What Monitors are you using ? brand & model number What display resolution are the monitors set to ? TEST - set your Monitor resolution to 1024 X 768 Though this graphics card has 2 GB of RAM, that is only 1 GB for each GPU Have you tried with SLI = ON SLI configuration, check the Maximize 3D performance - currently it is set to Disable SLI Your graphics card has two separate GPUs, in the one card SLI ON may help You may have to contact EVGA directly for technical support http://latam.evga.com/support/ http://www.evga.com/about/contactus/
MIULER
2017/03/22 07:06:38
Good afternoon again, my friend. TV monitors I already have a lot of time with them in use and everything has me fucionado well brand Hair 29 inch resolution VGA 1024 * 768 and HDMI 1080 Not treated with SLI and I only have a card and a single slot Pci express, so noi I get the activation or deactivation of SLI or to be able to configure it, so I get the opsion to configure or verify maximum performance 3D My motherboard will have something to do with this malfunction or it is indifferent is an ASROCK H55ME_LE I already wrote to technical support for days and has not yet received a response In verad friend thank you very much for your help
2017/03/22 08:19:55
☄ Helpfulby MIULER 2017/03/23 16:34:44
Wish I could do more for you. I will give EVGA Tech support a message and see if a Tech will look at this thread
MIULER
2017/03/22 08:27:23
[<font][<font]Amigo que sabe q en el administrador de dispositivos - Salvapantallas una GPU sale con un triángulo amarillo y dice error 43, el servicio técnico me informó que verificará si se deja que el triángulo en una GPU y se lo notificará y transmitir la imagen donde las hojas triangulares los Windonws mirada es la q se detiene la aplicación al trabajo y no sé cómo resolver si sabe o tiene conocimiento apreciaría su ayuda
carlos0420
2017/03/24 09:25:25
Hello, I present the same problem as the friend MIULLER, and I have tried changing the operating system from windows 10 64bits to windows 7 64bits, without solving the problem, change drivers to older versions and it also does not work, only recognizes a gpu in the System devices, I connect a cable to the hdmi and dvi ports of the second integrated card and does not recognize them, even when turning on the computer, I think it could be due to a bios problem of the second card because the nvflash software recognizes it Strangely, I attach an image to observe the detail, it is impossible to find a bios and original drivers of this card. thanks for your help.
2017/03/24 09:32:44
☼ Best Answerby MIULER 2017/03/24 10:41:37
Welcome to the Forums carlos0420 Hey Miuler - question Do All of those output ports Work on your 460 2WIN - If you only use 1 port at a time ?
carlos0420
2017/03/24 09:47:54
Hello friends Gtx Cool and MIULLER, thanks for the welcome and quick reply; I only use one port at a time, but as you see, it only recognizes a card in the system's devices, which puzzles me, I also lost the installation cd and I could not get the original drivers. Thanks for your help.
carlos0420
2017/03/24 09:57:46
Cool GTX Welcome to the Forums carlos0420 Hey Miuler - question Do All of those output ports Work on your 460 2WIN - If you only use 1 port at a time ?
On my card only 2 ports work. The others do not give an image even when starting the computer.
carlos0420
2017/03/24 09:59:57
Hello friends Gtx Cool and MIULLER, thanks for the welcome and quick reply; I only use one port at a time, On my card only 2 ports work. The others do not give an image even when starting the computer. Thanks for your help.
MIULER
2017/03/24 10:43:03
Good friends many thanks and biuen benidos to the forum Well I tell you step by step what I do to do As you know only recon me 2 monitors nothing more in the 2 connections dvi together and nothing that could achieve recognize the other 2 monitors Good for service technician of EVGA gave me a clue the cuyal knew to take advantage of, that was to enter in ADMINISTRATOR OF DISPOSITOVO then in ADAPTERS OF SCREENS, there I realized that I had the 2 GPUs of my video card but only 1 GPU was good and the Another APPEARED A YELLOW TRIANGLE that is meant to not work. Well the obsession to accommodate that problem was as follows 1 right click on the GPU that has the yellow triangle 2 actializar driver software 3 look for driver software on your computer 4 to choose from a list of device drivers on the computer 5 there is select the obsession of your video card, then you give next and follow the steps to install the drivers of your card. And that was all But in Windows 10 for more that did not work I followed the error 43 or the famous yellow triangle in the GPU. Well I decided to format my pc and take it to windows 7 Follow the same step Since the problem of the yellow triangle when installing the drivers persisted The following steps were numbered above and problem solved immediately appeared the SLI, Surround, PhysX configuration and there is active (disable SLI) and ready my monitors were recognized immediately and only what is left is to configure the resolution Here I share my friend what was the solution I hope to share yours if they can solve
carlos0420
2017/03/24 11:08:16
MIULER Good friends many thanks and biuen benidos to the forum Well I tell you step by step what I do to do As you know only recon me 2 monitors nothing more in the 2 connections dvi together and nothing that could achieve recognize the other 2 monitors Good for service technician of EVGA gave me a clue the cuyal knew to take advantage of, that was to enter in ADMINISTRATOR OF DISPOSITOVO then in ADAPTERS OF SCREENS, there I realized that I had the 2 GPUs of my video card but only 1 GPU was good and the Another APPEARED A YELLOW TRIANGLE that is meant to not work. Well the obsession to accommodate that problem was as follows 1 right click on the GPU that has the yellow triangle 2 actializar driver software 3 look for driver software on your computer 4 to choose from a list of device drivers on the computer 5 there is select the obsession of your video card, then you give next and follow the steps to install the drivers of your card. And that was all But in Windows 10 for more that did not work I followed the error 43 or the famous yellow triangle in the GPU. Well I decided to format my pc and take it to windows 7 Follow the same step Since the problem of the yellow triangle when installing the drivers persisted The following steps were numbered above and problem solved immediately appeared the SLI, Surround, PhysX configuration and there is active (disable SLI) and ready my monitors were recognized immediately and only what is left is to configure the resolution Here I share my friend what was the solution I hope to share yours if they can solve
Hola amigo miuller, te comento que tu problema tiene una solucion muy sencilla, estuve leyendo en foros que debes desactivar la opcion de sonido del puerto dvi, en la configuracion del panel de nvidia puedes hacerlo no tiene mayor complicacion, como eres una de las pocas personas que tiene esta tarjeta quisiera pedirte un favor, podrias darme una copia de tu bios y confirmarme si ella viene con 1 bios para cada nucleo, puedo explicarte en pocos pasos como hacerlo, espero haberte sido de ayuda en tu problema, si es asi por favor ayudame en el mio, muchas gracias. Hi friend miuller, I commented that your problem has a very simple solution, I was reading in forums that you must deactivate the sound option of the port dvi, in the configuration of the nvidia panel you can do it has no major complication, as you are one of the few People who have this card would like to ask you a favor, you could give me a copy of your bios and confirm if it comes with 1 bios for each nucleus, I can explain in a few steps how to do it, I hope I have been of help in your problem, if so by Please help me, thank you very much.
carlos0420
2017/03/25 09:09:13
Hola el problema del triangulo amarillo en uno de tus controladores es debido a una conflicto entre el sonido de nvidia y el controlador grafico, debes entrar al panel nvidia y desabilitarlo, reiniciar y revisar si el problema se resolvio, si es asi confirmame por favor, te comente anteriormente que necesito un poco de ayuda de tu parte, si te sirvio mi ayuda, por favor haz lo mismo conmigo. Hello, the problem of the yellow triangle in one of your controllers is due to a conflict between the sound of nvidia and the graphics controller, you must enter the panel nvidia and disable it, restart and check if the problem was solved, I told you earlier that I need a little help from you, if I helped you, please do the same with me.
carlos0420
2017/03/25 09:13:43
Anyone who can provide me the bios and the original drivers of the gtx 460 2win, please? Alguien que pueda facilitarme el bios y los drivers originales de la gtx 460 2win, por favor?
MIULER
2017/03/25 09:17:27
carlos0420
Good morning friend I already solved the inconvenience It was not any of the cases that you indicate Thank you very much for your help but I have already solved it Of course I can help with the bios. Tell me step by step well specified How do I copy the vias of my video card Thank you very much, I hope your answer
MIULER
2017/03/25 09:23:55
carlos0420 Anyone who can provide me the bios and the original drivers of the gtx 460 2win, please? Alguien que pueda facilitarme el bios y los drivers originales de la gtx 460 2win, por favor?
Friend, I have the 2 things. I can give you the driver And the copy of the bios But tell me how to copy the bios from my graphics card If it damages the bios of mine Tell me step by step how to do it
carlos0420
2017/03/25 09:42:59
☄ Helpfulby MIULER 2017/03/25 23:28:56
MIULER
Muchas gracias por ayudarme, no te preocupes que copiar el bios no es peligroso. Cuando copias el bios, no pasa nada que pueda dañar tu tarjeta, de hecho es bueno que tengas una copia de seguridad, por si te pasa lo que a mi. necesitaras un programa gpu-z, te adjunto la imagen de donde dar el click para hacer una copia de tu bios yl el programa, gracias por tu tiempo.
carlos0420
2017/03/25 09:45:36
☄ Helpfulby MIULER 2017/03/25 23:28:45
MIULER
Muchas gracias por ayudarme, no te preocupes que copiar el bios no es peligroso. Cuando copias el bios, no pasa nada que pueda dañar tu tarjeta, de hecho es bueno que tengas una copia de seguridad, por si te pasa lo que a mi. necesitaras un programa gpu-z, te adjunto la imagen de donde dar el click para hacer una copia de tu bios y el programa, gracias por tu tiempo. Thank you very much for helping me, do not worry copying the bios is not dangerous. When you copy the bios, nothing happens that could damage your card, in fact it is good that you have a backup, in case it happens to you. You need a program gpu-z, I attach the image where to give the click to make a copy of your bios and the program, thanks for your time.
post edited by carlos0420 - 2017/03/25 10:20:18
MIULER
2017/03/25 20:21:50
carlos0420
MIULER
GOOD NIGHTS FRIEND CARLOS ACA I AM SENDING YOU THE COPY OF MY GPU-GF104, I WOULD LIKE YOU TO EXPLAIN ME AS IT IS POSSIBLE THEN TO MOUNT THE COPY OF MY BIOS ON YOURSELF, AS IS THE PROCESS EXPLICATE PLEASE THANK YOU NOW I NEED YOU TO SEND ME OPERATING SYSTEM POSEES TO SEND YOU THE ORIGINAL DRIVER, REMEMBER THAT THIS TYIENE CARD PROBLEM WITH WINDOWS 10 ONLY WORKS PERFECT WITH WINDOWS 7 I HOPE YOUR ANSWER https://www.dropbox.com/s...%202WIN-GF104.rom?dl=0
carlos0420
2017/03/26 08:26:05
MIULER
carlos0420
Hola en este manual te explica paso por paso como recuperar cambiar o recuper bios de una tarjeta de video,muchas gracias por el bios, cuando uses nvflash usa el comando nvflash -a o nvflash --list , tengo la duda de si son 2 bios por tarjeta o un solo bios por tarjeta. el sistema operativo que tengo es windows 7 64bits. quisiera saber que version de controlador estas usando tu? porque a ti si te reconoce 2 tarjetas de video y a mi solo 1. si puedes has una captura cuando hagas el comando. Hello in this manual I explain step by step how to recover change or recover bios of a video card, thank you very much for the bios, when you use nvflash use the command nvflash -a or nvflash --list, I am in doubt if they are 2 bios by Card or single bios per card. if you can have a capture when you do the command.
The operating system I have is windows 7 64bit. I would like to know which driver version you are using? Because to you if you recognize 2 video cards and my only 1.
MIULER
2017/03/26 09:11:18
[<font][<font][Quote = carlos0420] [<font][<font][Quote = MIULER] [<font][<font][Quote = carlos0420] [<font][<font][/citar] [<font][<font]En Este Manual de Hola te Explica Paso Por Paso Como Recuperar change o Recuper bios De Una Tarjeta de vídeo, Muchas gracias por el BIOS, Cuando utiliza nVFlash EE.UU. El Comando nVFlash -ao nVFlash --list, tengo la duda de si hijo de 2 por bios Tarjeta O Un Solo bios por Tarjeta. [<font][<font]El Sistema Operativo es Que Tengo windows 7 64bits. [<font]quisiera saber la versión Que de Controlador Estas Usando tu? [<font]Porque a ti si te reconoce 2 Tarjetas de vídeo ya en solitario MI 1. Si Puedes tiene Captura Una CUANDO hagas el comando. [<font][<font]Hola en este manual explico paso a paso cómo recuperar cambiar o recuperar BIOS de una tarjeta de video, muchas gracias por la BIOS, cuando se utiliza nVFlash utilizar el comando -a nVFlash o --list nVFlash, estoy en duda si son 2 BIOS usando una tarjeta o biografías individuales por tarjeta. [<font]si usted puede tener una captura cuando se haga el comando. [<font][<font]El sistema operativo que tengo es Windows 7 de 64 bits. [<font]Me gustaría saber la versión del controlador que está utilizando? [<font]Debido a que si reconoces 2 tarjetas de video y mi único 1. [<font][<font][/citar] [<font][<font]Ok gracias amigo, mira [<font][<font]he instalado el original de mi instalación cd [<font][<font]Y entonces no reconocía una GPU [<font][<font]Lo que hice fue ir a [<font][<font]1 la administración de equipos de [<font][<font]adaptadores de pantalla 2 [<font][<font]3 seleccione la GPU que sale el triángulo amarillo [<font][<font]4 le di al día, [<font][<font]5 buscar el equipo para el conductor y luego [<font][<font]6 elegir entre una lista de controladores [<font][<font]7 seleccione el controlador que se instaló la versión 8.17.12.6658 (01/07/2011) [<font][<font]8 di inmediatamente siguiente, hasta q lo instala [<font][<font]9 pide que reinicie y luego aparece instala la GPU instala bien [<font][<font]y trabaja el 2 GPU perfectamente [<font][<font]10 de sonda continuación, establezca las 4 salidas y todos ellos funcionó a la perfección [<font][<font]11 de configure 4 monitores y perfecto junto al que se ve en un escritorio ampliado [<font][<font]12 luego dejar sólo 3 monitores porq un cable fue tomado de una amigo [<font][<font]13 luego descargar GeForce Experiencia [<font][<font]14 y la actualización a la última versión 21.21.13.7892 (03/16/1017) y todo funciona bien [<font][<font]Así que de esta manera cada paso fue lo que hice [<font][<font]y todo fue perfecto [<font][<font]Acaben para cargar el controlador le envío YO SOY comprimir en un archivo ISO Estoy llegando HERMANO DROXBOX me va a enviar USTED [<font][<font]1 CD OPRIGINAL Q primero debe instalar [<font][<font]2 LA ACTUALIZACIÓN DE LA VERSIÓN DE ÚLTIMO 378.92-escritorio-Win8-win7 -64bit-internacional-WHQL [<font][<font]3 Y GeForce_Experience_v3.4.0.70 [<font][<font] https://www.dropbox.com/s...nce_v3.4.0.70.exe?dl=0
post edited by MIULER - 2017/03/26 09:13:43
MIULER
2017/03/27 04:08:28
[<font][<font][Quote = carlos0420] [<font][<font][Quote = MIULER] [<font][<font][Quote = carlos0420] [<font][<font][/citar] [<font][<font]En Este Manual de Hola te Explica Paso Por Paso Como Recuperar change o Recuper bios De Una Tarjeta de vídeo, Muchas gracias por el BIOS, Cuando utiliza nVFlash EE.UU. El Comando nVFlash -ao nVFlash --list, tengo la duda de si hijo de 2 por bios Tarjeta O Un Solo bios por Tarjeta. [<font][<font]El Sistema Operativo es Que Tengo windows 7 64bits. [<font]quisiera saber la versión Que de Controlador Estas Usando tu? [<font]Porque a ti si te reconoce 2 Tarjetas de vídeo ya en solitario MI 1. Si Puedes tiene Captura Una CUANDO hagas el comando. [<font][<font]Hola en este manual explico paso a paso cómo recuperar cambiar o recuperar BIOS de una tarjeta de video, muchas gracias por la BIOS, cuando se utiliza nVFlash utilizar el comando -a nVFlash o --list nVFlash, estoy en duda si son 2 BIOS usando una tarjeta o biografías individuales por tarjeta. [<font]si usted puede tener una captura cuando se haga el comando. [<font][<font]El sistema operativo que tengo es Windows 7 de 64 bits. [<font]Me gustaría saber la versión del controlador que está utilizando? [<font]Debido a que si reconoces 2 tarjetas de video y mi único 1. [<font][<font][/citar] [<font][<font]Buen hermano mañana [<font][<font]Déjame un correo electrónico para enviar el archivo [<font][<font]Puesto que se tarda mucho tiempo en cargar por Dropbox [<font][<font]Para enviarlos a través de Gmail [<font][<font]espero su respuesta [<font][<font]likn cd : https://www.dropbox.com/s...%20460%202WIN.isz?dl=0
post edited by MIULER - 2017/03/27 16:57:11
