PRECISION X1 and the ongoing LED Control Issues
bonepickerx
2020/12/06 10:37:34 (permalink)
 I have installed several of the Precision X1 versions and LED Sync does not work on any. I have two EVGA FTW3 2080Ti Ultra Hybrids and a the Silver Nvidia NVLink 3 Space Bridge. No matter what I have tried,  Led Sync or any control over the LEDs was buggy at best and does not work 90% of the time. I typically think EVGA is the best but I can also say the guys writing the code for Precision X1 are not accounting for the use of a non EVGA NVLink Bridge.
Here's what worked for me for control of the RGB on the cards, again, I found this on the Nvidia Forum in a Google search, not taking credit just passing it on. I use MSI afterburner for overclocking so Precision is great but buggy. I still think it caused Bios issues on my cards.
Uninstall Precision X1 but DO NOT Uninstall LED Sync, after you uninstall Precision X1, navigate to C:\program files x86\EVGA\ledsync.exe - right click and create a shortcut of LedSync.exe. Open Led Sync and change settings using the standalone Led Sync Application.
Additionally, I think the bridge RGB control problem is that you must have an EVGA NVLink Bridge. Why? After editing the LedSync.cfg file and replacing the 0 with a 1 after ([SLI1] Enable0=1) at the bottom of the .cfg file I still have no control over the RGB settings of the NVLink bridge (again my NVLink Bridge is the Silver NVidia standard, which also is currently only available on Ebay. The 3 slot Link bridge from any manufacturer is out of stock everywhere and the EVGA 3 slot bridge is as rare as Hens Teeth), I do have control over the Cards, RGB is affected with color change or any other flashing/pulsing/breathing options. I have a hunch the problem isn't the software necessarily, I think the problem is the hardware in use in other words if you don't have an EVGA bridge then Precision X1 LED control is not going to work. If you have an EVGA NVLink bridge and two EVGA GPU's and you run across this thread please verify that you have full control over the cards and the bridge RGB settings, by clicking on LED Sync.
MSI Z490 Unify CPU i9-10900KF @ 5.3GHz (1.42V)
32GB Patriot Viper Steel 4400MHz C19(1.5V@ 4233 17,19,19)
GPU's 2 x EVGA 2080Ti FTW3 Ultra-Hybrid SLI OC
SSD Dual Samsung 980 Pro M.2 NVMe in RAID 0
CPU Cooler Arctic Freezer II 420 CLC w/ Noctua 140mm Fans
Power Supply Corsair Ax1600i
OPEN AIR Chassis Custom 80/20 w/ BCI Open Bench Table
10 Replies Related Threads
    stevepieta
    Re: PRECISION X1 and the ongoing LED Control Issues 2021/01/08 16:05:06 (permalink)
    Hi, sorry for the off topic, but I noticed your 80/20 rig at the top spot and it inspired me to copy you for a miniITX build that wasn't cutting it for cooling.
    Could tell me how to source the brackets you used to mount the radiators to the 80/20 t-nuts? What are they called?
    bonepickerx
    Re: PRECISION X1 and the ongoing LED Control Issues 2021/01/08 17:35:25 (permalink)
    stevepieta
    Radiator mounting brackets are from Amazon. Had to drill the holes on one end of the brackets to fit 1/4 -20 bolts to mount to 1” 80/20 single slot. I also bent the 1/4-20 drilled end of the bracket to a true 90 degree on each bracket so the radiators were square to the mounting verticals and mounted perpendicular to the vertical. They are aluminum not steel as stated on Amazon which makes them much easier to machine and bend by hand. I bent them using a bench mounted vise.
    Bracket link:
    XSPC Radiator Standoff Bracket...
    https://www.amazon.com/dp...f=ppx_pop_mob_ap_share
    80 20 base is 22” long, centers are 5” long to fit the bench table. I used the push in T- rubber from 8020 to allow the bench table to sit and not slide on the 8020 base. Verticals are 22” tall. I also added 2 5” cross pieces between the verticals for handles to pick it up. I’ve made changes since I posted the pics on the EVGA mods rigs page. I can send you an updated pic if needed. I ordered all the parts from 8020 in three separate Orders or I’d just send the parts list. Had to make several parts adjustments so it cost me nearly 200.00 with all the changes. I would guess actual cost once completed is really about $140 or $150.00. Cost is a little more than the average case but so much more cooler than an enclosed case which is basically a heat trap.
    8020 Parts List
    4132-Black 4 Ea. $18.88
    4081-Black 8 Ea. $59.68
    3382 32 Ea. $6.72
    1001-Black-FB 22" 4Ea. $50.04
    1001-Black-FB 5" 4Ea. $17.40
    2015-Plain 8Ea. $9.60
    2828 1 Ea 12" $1.20
    3358 8Ea. $12.40
    65-3058 8Ea. $1.36
    3342 16Ea. $4.80
    XSPC Universal Radstand V2, 120mm $23.99
    Open Bench Table (OBT) Black Anodized $199.99
    Screw Kit for OBT $49.00
    Total Open Bench Case Cost: $412.19 Plus Shipping
    post edited by bonepickerx - 2021/01/09 08:36:35
    stevepieta
    Re: PRECISION X1 and the ongoing LED Control Issues 2021/01/10 21:13:57 (permalink)
    Wow, thank you so VERY much for the detailed write up!   I wish I would've reached out to you before trying to work out what to order from your pics from the page (was before you even added the video and other ones).
    I was wondering what that rubber piece on the bottom was from - thanks for providing the info on that too.   I was curious - did you try to work out a way to secure the Open Bench Table to a T-nut in the base rails?  I suppose the rubber keeps it from sliding, but I think ideally it seems like there might be a way to fasten it, no?
    I ended up buying both the original and MiniITX versions of the OBT - my board is miniITX, and after I bought the original one, I thought that would be cool as a bench kit for some other development boards and projects (raspPI, Arduino, STM32's, etc).  I think I'm going to attempt PC build with mini-ITX OBT using yours as inspiration.  I can hang so much more off the larger one, and can get creative with a bunch of different standoffs M3 screws.
    I've been trying to source some M3 t-nuts, and 6-32, but it seems most of the standard sizes for 8020 are M4 and 8-32 and bigger.  Have you used more 'standard' PC building sizes with your 8020 stuff?
    Thanks for the updated picture - its so killer man, thank you so much for posting and providing me the additional details.  I had never heard of 8020 before this, and I'm not sure how I lived life without it.  I've 10 different ideas.  I was lucky enough to get an AMD 5900 from Antonline during the initial release, and running it in a mini-ITX case on air isn't doing it justice.  OBT and 8020, I think, will let me push this little space heater of mine.
    bonepickerx
    Re: PRECISION X1 and the ongoing LED Control Issues 2021/01/11 10:05:53 (permalink)
    Yea 8020 is awesome stuff. I started using it in the early 2000’s when I worked in R&D at Los Alamos. I used it for all kinds of experimental systems through 2015 when I left the DOE. I did think about taking the drawings from online and having the table legs re-cut and adding in 1/4-20 mount holes to mount to the 8020 frame base. The table is actually quite secure on the 8020 while sitting on the T rubber cover. Additionally the cabling helps to secure it into place as well as the water pipes. Good luck with it. I adapted the PC fasteners to the 8020 rather than trying to adapt the 8020 to the PC standard sizes. The drawings for the open bench table are available on maker sites, and free for use if personal use is the only manufacturing changes you make. You can also post updated, redlined and changed drawings on the maker site. I had to prototype the whole thing and I sunk more than 500.00 getting the way I wanted it. So I think I’m done sinking money into it.
    post edited by bonepickerx - 2021/01/11 10:11:11
    bonepickerx
    Re: PRECISION X1 and the ongoing LED Control Issues 2021/01/11 10:23:00 (permalink)
    You know you could have a set of clamps made that go over the legs and mount to the t slots. Also you could maybe use a verticals corner brace and drill/tap a hole in the side of the table legs. The right angle triangle verticals/horizontal mount would work if it’s verticals mounting hole is not taller than the top of the table leg.
    stevepieta
    Re: PRECISION X1 and the ongoing LED Control Issues 2021/01/18 13:51:03 (permalink)
    Thanks again for all the fantastic help on this man.  My kits coming along, waiting for some more parts.
    I was able to find some M3 t-nuts to secure the OBT to the extrusions, using the two small holes on each of the legs.  Happy with the result, with the added mechanical strength (be happy to mail you a few, if you'd like).
    I had some follow-up questions, if you have some time.
    1.  I see what appears to be chrome feet on the updated picture - where did you source them?
    2.  I ran across a radiator mounting video on the install guide for the 420.  . I was wondering if you experimented with mounting the large radiator differently?  I was thinking of doing it horizontally, instead of vertically like you did.  Appreciate any experience you can share with respect to its orientation.  Last time I built something with a AIO was 7 years ago - that embedded video in the arctic link about was very informative to me.
    -Steve
    bonepickerx
    Re: PRECISION X1 and the ongoing LED Control Issues 2021/01/19 05:07:29 (permalink)
    stevepieta
    -Steve
    Send me a pic man. Also what are the specs on the M3? Chrome feet are stereo isolation feet from Amazon 4 Sets Speaker Isolation Stand... https://www.amazon.com/dp...f=ppx_pop_mob_ap_share
    Radiator horizontal will work it’s just that mine is a 420 and too big to mount horizontal it will be offset and the tube might be in the way but now you got me thinking. I may do a redesign. Depends on the hoses. I could mount in the middle. I am just wondering if the vertical 80/20 will block airflow radiator would have to be mounted in the center and would look odd. But fluid pipes could be in the back than.
    DeepakR
    Re: PRECISION X1 and the ongoing LED Control Issues 2021/05/09 21:16:12 (permalink)
    I have the same issues as you described.
    I find that as of recently the standalone LEDSync.exe control is causing erratic and severe flickering of the card LEDs.
    Did you find a workaround. I did contact EVGA as well and will reply if they give me a reasonable answer/workaround.
    BTW I have the EVGA NVLink SLI Bridge and 2 x EVGA RTX 2080 Ti FTW3 Ultra
    ntzphyr
    Re: PRECISION X1 and the ongoing LED Control Issues 2021/05/24 07:43:15 (permalink)
    I was able to resolve the rgb issues with this version of Precisionx and it might have worked with previous versions.
    I first installed only LEDsync. Opened LEDsync from Program files(x86) > EVGA > LEDsync > LEDsync app. Applied my desired settings, in my case both set to blue.
    I then installed Precisionx normally and opened it when it finished installing. My LEDs reverted to disco rainbow.
    I then opened Task Manager and ended LEDsync task in the details tab. I again booted LEDsync from the Program files (x86) folder and reapplied settings. My settings are now persistent through restarts.
    I imagine its possible to install both PrecisionX and LEDsync at the same time for this to work, I'm just too happy with my settings {and too lazy) to try it.
    Edit: I've just realized LEDsync is opening with windows and is present on the task bar, I can live with that! :)
    post edited by ntzphyr - 2021/06/25 07:58:52
    CPU: i9 10900k
    Corsair H150i Elite Capellix cpu cooler
    ROG Strix Z590-A gaming WiFi
    GPU: EVGA GTX 1080TI FTW3
    Corsair Dominator Platinum 32 GB
    Power Supply: Corsair HX1000i
    Monitor X 2 : ASUS 27" VS 278
    Keyboard: Corsair K95 Platinum RGB
    Mouse: Corsair M65 ultra Wireless
    Headset: Corsair Virtuoso SE
    VR: Samsung HMD Odyssey Headset
    MxMatrix
    Re: PRECISION X1 and the ongoing LED Control Issues 2022/08/26 11:08:21 (permalink)
    Thnx all put to the solution, running the led sync setup from the x1 map, then starting it from it's own map solved it.
    EVGA GTX 1070 ACX FTW SC / EVGA GTX 750Ti ACX FTW SC
