Price breakdown by merchant:
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($233.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.89 @ OutletPC)
Motherboard: Gigabyte GA-Z170M-D3H Micro ATX LGA1151 Motherboard ($92.98 @ Newegg)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory ($59.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($89.22 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.49 @ OutletPC)
Video Card: EVGA GeForce GTX 970 4GB FTW ACX 2.0 Video Card ($313.98 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case ($44.99 @ Newegg)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($38.98 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($83.89 @ OutletPC)
Total: $1030.40
HELP!
I just built this new system. Everything powers on, windows installed. Fine. problem is:
When the GPU (EVGA GTX 970) when connected to the PSUs 8pin+4pin my computer wont turn on.
I have the HDMI connected to the motherboard and everything works ok when the GPU is NOT connected to the PSU.
When the PSU is connected to the GPU, the entire PC will flash, but not power on.
Also, when the GPU is not connected to the CPU, the GPUs fan will turn on/off which means its getting power from the PCI slot (which should eliminate the possibility of the Mobo)?
What am I missing? Is this a dud GPU? Or is the power source not powerful enough? They are both from EVGA and 500w power is the minimum requirement so it should work?
