AnsweredNu Audio Pro Surround card - does it require PCIe lanes?
Nameless Gentleman
2020/04/03 16:21:43 (permalink)
When the Nu Audio Pro Surround card is connected to a PCIe slot, does it use any PCIe lanes, or is it just drawing power from the board?
  • Ribbons : 270
Re: Nu Audio Pro Surround card - does it require PCIe lanes? 2020/04/03 17:53:53 (permalink)
Yes, of course it uses PCI-e lanes.  How else do you think that it could communicate with your CPU?
Nameless Gentleman
Re: Nu Audio Pro Surround card - does it require PCIe lanes? 2020/04/03 19:25:56 (permalink)
To clarify, I'm talking about the Surround card itself.  I'm wondering if it just communicates over the Displayport cable, or if it is also communicating with the CPU over PCIe.
Vivicector
Re: Nu Audio Pro Surround card - does it require PCIe lanes? 2020/04/03 23:43:24 (permalink)
AFAIK, the additional surround card is only drawing power from PCI-E. Not 100% sure though.
What do you have in mind? We may have a common trouble here...
  • Ribbons : 270
Re: Nu Audio Pro Surround card - does it require PCIe lanes? 2020/04/04 07:49:43 (permalink)
Nameless Gentleman
Oh... I see. I am not sure.
  • Ribbons : 122
Re: Nu Audio Pro Surround card - does it require PCIe lanes? 2020/04/04 08:04:39 (permalink) ☼ Best Answerby Nameless Gentleman 2020/04/04 08:50:00
Nameless Gentleman
Looks like the Answer is No
  "The NU Audio Pro Surround Card receives both its power and data through the mini-DisplayPort Cable connected to the NU Audio Card."
https://www.evga.com/Support/AudioCard/QuickGuide/
(excerpt)
Step 4
Fasten the NU Audio Pro Card and/or the NU Audio Pro Surround Card with screws. Connect the mini-DisplayPort cable to both cards if you now have both the NU Audio Pro Card and NU Audio Pro Surround Card in your system. Regardless of configuration, you must have a NU Audio Pro Card in your system for the NU Audio Pro Surround Card to work properly. The NU Audio Pro Surround Card receives both its power and data through the mini-DisplayPort Cable connected to the NU Audio Card.
Nameless Gentleman
Re: Nu Audio Pro Surround card - does it require PCIe lanes? 2020/04/04 08:50:26 (permalink)
Nameless Gentleman
(excerpt)
Step 4
Think that answers the question then.  Thanks for the help.
  • Ribbons : 122
Re: Nu Audio Pro Surround card - does it require PCIe lanes? 2020/04/04 08:57:14 (permalink)
Your
Happy to Help
