Not sure if I'm using the correct plug from Power Supply to GPU
Mtbaer02
2022/08/06 14:17:41 (permalink)
I just completed a new build and have no display. Power Supply is EVGA 700BR with multiple possible plugs to use for the GPU (GEFORCE GTX). Wondering if the GPU needs to be plugged in a certain way to ensure power.
2 Replies Related Threads
    arthurz21
    Re: Not sure if I'm using the correct plug from Power Supply to GPU 2022/08/06 20:02:45 (permalink)
    What card do you have and how did you connect it?
    bill1024
    • Ribbons : 65
    Re: Not sure if I'm using the correct plug from Power Supply to GPU 2022/08/06 21:00:39 (permalink)
    Yes you want to use the cable that has PCI-E 6+2 pins.
    The cable is directional, the end with 6+2 goes into the GPU, the other end into the PSU.
