Hot!NU Audio Control Panel Icon Disappears and No Way to Change Settings
auron30
2022/07/10 15:23:26 (permalink)
Hi, When I try to open the NU Audio Control Panel on the taskbar, It will close itself when I hover my mouse over it and its icon disappears. I have no way to open it when I would want to turn on the surround sound option and set the sample rate or even change the LED light's color. I'm using Windows 11 and have had no problem with it before and at some point, it just happened. I tried uninstalling, using a registry cleaner, and reinstalling the driver but no luck.
4 Replies Related Threads
    hitdevil
    Re: NU Audio Control Panel Icon Disappears and No Way to Change Settings 2022/07/22 09:47:23 (permalink)
    Hi. I had same issue. For me helped install version 0.2.1.10.
    LCaldas
    Re: NU Audio Control Panel Icon Disappears and No Way to Change Settings 2022/08/11 01:55:12 (permalink)
    same problem here after windows update.
    some times have  a erro 0x0001 and outhers blue screen
    ps: already unistall the "updates" but the painel not open more :(
    LCaldas
    Re: NU Audio Control Panel Icon Disappears and No Way to Change Settings 2022/08/11 05:25:23 (permalink)
    hitdevil
    I will try this version tonight.
    LCaldas
    Re: NU Audio Control Panel Icon Disappears and No Way to Change Settings 2022/08/11 14:20:23 (permalink)
    hitdevil
    Thank you sir, the EVGA_NU_Audio_0.2.1.10_WIN10 work fine
